stock temperature gauge
Old November 2nd, 2009, 09:37 AM   #1
1996 mustang gt
96sickstang can only hope to improve
Ya I have had this problem for some time now but I dnt know wat can be wrong my temperature gauge in my cluster don't work at all the needle stays under the c and doesn't move at all I replaced the temperature sensor but still nothing do u guys have any advice wat I can do
Old November 2nd, 2009, 06:42 PM   #2
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all
iTrader: 13 reviews
Are they stock guages? If it had aftermarket guages it is possible the needle was put on to far and is stuck in that position. Other than that I'd check the circuitry going across the back of the guage pod to check for a crack or break in it.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old November 2nd, 2009, 06:51 PM   #3
FucusRuckus
CobraPhoenix's Avatar
08 Ford Fuckus
n/a
CobraPhoenix is a splendid one to beholdCobraPhoenix is a splendid one to beholdCobraPhoenix is a splendid one to beholdCobraPhoenix is a splendid one to beholdCobraPhoenix is a splendid one to beholdCobraPhoenix is a splendid one to behold
stock gauges are inaccurate at best
Originally Posted by 08blkgt500 View Post
Originally Posted by vastang757 View Post
for a deaf guy, i thought you'd know more sign language than that...
Check Garage For Crews
Old November 2nd, 2009, 11:23 PM   #4
1996 mustang gt
well its the stock gauge and has never had any aftermarket gauges install the stock gauge was workin before i had my gauges put in but since then it hasnt worked
Old November 2nd, 2009, 11:26 PM   #5
FucusRuckus
08 Ford Fuckus
n/a
so you replaced the sending unit? maybe it doesnt work with the factory gauge? unless i misunderstood you
Old November 2nd, 2009, 11:32 PM   #6
1996 mustang gt
i replaced the water temperature sensor but it didnt help the needle still didnt move
Old November 2nd, 2009, 11:34 PM   #7
FucusRuckus
08 Ford Fuckus
n/a
sounds like either the wiring or the gauge itself. id just route in an aftermarket cluster if you can, stock gauges are usually always off anyway, but as far as the need not moving at all idk like i said wiring or gauge, there cant be much else that can go wrong, unless the sending unit you put in there is bad which is possible
Old November 2nd, 2009, 11:57 PM   #8
1996 mustang gt
well mayb it is the unit
Old November 3rd, 2009, 12:01 AM   #9
FucusRuckus
08 Ford Fuckus
n/a
just test the wires and gauge first, the the unit, im not sure exactly how you would go about doing it, but thats where id start
Old November 3rd, 2009, 12:15 AM   #10
1996 mustang gt
ok it seems confusing
Old November 3rd, 2009, 08:01 AM   #11
FucusRuckus
08 Ford Fuckus
n/a
yea ill try to find a write up if someone doesnt beat me to it
Old November 3rd, 2009, 09:38 AM   #12
1996 mustang gt
Ya that would b nice I couldn't find anything
Old November 3rd, 2009, 06:23 PM   #13
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
1. Take out your entire cluster
2. Bang it on the ground
3. put it back in and see if it works now.
Just kidding. But i'm sure you feel like doing it.
MODS IN GARAGE
NCMM ORIGINAL
Old November 3rd, 2009, 06:27 PM   #14
MM's Drunken Sailor
deedub97GT's Avatar
single turbo in the works
as fast as i can push it!
deedub97GT is a splendid one to beholddeedub97GT is a splendid one to beholddeedub97GT is a splendid one to beholddeedub97GT is a splendid one to beholddeedub97GT is a splendid one to beholddeedub97GT is a splendid one to behold
Send a message via Yahoo to deedub97GT
you could check the thermostat to see if its stuck shut. if coolant isnt flowing past it your temperture wont read. that would also mean your probobly overheating
MILITARY CREW GSM3
Old November 4th, 2009, 09:40 AM   #15
1996 mustang gt
Well its not the thermostat cuz I just replaced it and I never had problems with it.
Threads Similar to: stock temperature gauge
Replace Stock V6 Gauge With Gt Guages? Can It Be Done? Lanchero302 V6 Mustangs 23 March 19th, 2009 01:52 PM
AutoMeter transmission temperature gauge knightster420 V6 Mustangs 3 August 17th, 2007 11:32 PM
temperature gauge issue 2004GT Audio/Video 2 May 13th, 2007 09:54 PM
Temperature Gauge lwhitetrash88l V6 Mustangs 4 April 14th, 2007 11:06 PM
