LinkBack (3) | Thread Tools |
#21
15.2 @ 89.89
Can you put 4v heads on a 2v block?
#22 |
1994 Mustang 5.0
1996 Mustang V6
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
![]() -04 IRS - Magnaflow - Wheel Replica - Autometer - FTBR - FRPP - SCT - Brembo - PRO 5.0 - BOI- |
#23 |
Genibus Nitito Canus
u can put any mod motor head on any mod motor block....except the v10 stuff
Red 1996 GT: JLT RAI, Steeda Underdrive pullies, Stewart Waterpump; nothing to brag about Black 2009 45th aniverary edition GT 5 speed: K&N CAI, BBK Twin 62mm Throttle Body, BBK Underdrive Pullies, muffler delete ![]() |
#24 | |
1994 Mustang 5.0
1996 Mustang V6
+1
#25 |
Priest of the Car Gods
So are '99s and '01s. All N/A Cobras are aluminum block, all factory boosted Cobras ('03 and up) are iron block. There are two different aluminum blocks used in Cobras; the Teskid and the WAP. Teskids are considerably stronger, and were used up though '99, I understand there are some early production '01s that have Teskids as well.
No. C-ports started with the '99s. There are a few different versions of the C-port heads, though, so '99 Cobra heads are different than '03 Cobra heads or Mach heads, but they're all C-ports. The only Cobras that use B-ports are '96-98.
O o /¯/______________________ |BLAAAAAAAAAAAAAAAAAAAAAAAAARGH!!! \_\ Buy my Bronco, special deal for MM folks |
#26 |
I thought that Romeo 2v and Windsor 2v heads did not interchange? I'm not as edumacated on 2Vs, lol.
#27 |
1998 Mustang GT
13.046@107.49
I believe the heads interchange, but the valve covers don't
#28 |
they are interchangeable but u need the correct valve covers and timing cover
#29 |
1997 Mustang GT
Faster than an s4
Correct. one has a 13 bolt valve cover and the other has an 11 bolt. The actual heads mount up to either. Windsors also have press on gears that everyone hates.
Aztec Gold 97GT. MM CC Plates, Panhard Bar, SFC's & Tower Brace Eibach Sway Bars H&R Race Springs/Bilstein Shocks MAC CAI, LT's, Catted H and Pro-Dumps KB Boost-a-Spark 04' PI Motor Author of The Official Suspension Guide |
#30 |
Lots of good information in this thread. I feel like it should be stickied, just because there's no extra BS in it..and the fact that there's a lot of interesting information
![]() Cammed 2v Built By MustangMatt More mods than times your daughter has slept around |
#31 | |
1994 Mustang 5.0
1996 Mustang V6
<---Damn i did it to
#32 |
15.2 @ 89.89
to turn a 2v engine into a 4v what would need to be done? is it as easy as just the heads and cam and intake?
#33 |
Heads, Cams, intake, exhaust manifolds/headers, and I'm almost positive you need to swap the wiring and ECU, though I have people say elsewise.
#34 |
yes in the same way a blower install is basically a intake swap, lol. to best answer is search it
#35 |
I still contend that putting 4v heads on a GT shortblock is, well, stupid.
The aftermarket for 4vs is tiny compared to 2vs, and you're gonna make one incredibly heavy motor (second heaviest mod motor shortblock + heaviest mod motor heads). Not only is the car going to handle worse (all that extra weight up front), but you've just negated some of the power gain by having to push that extra weight. On top of that, you lose the forged crank that makes the 4v shortblock able to reliably turn the rpms that the 4v heads need to make power. All that to save, what, a couple hundred bucks over pulling a whole motor?
#36 |
15.2 @ 89.89
I want to do either a 4v swap but i was wondering if there was another away around it
#37 |
what do u mean way around it? if u want 4v heads, u either swap them onto ur block or swap in a whole motor. if u dont want to do 4v heads, then u can do a PI swap (if u dont have it already) or bolt on a set of Trickflow Specialites heads (require PI intake and are still 2v heads)
#38 |
1992 T-bird SC
There is another thing too. The 97-98 Mark VIII engines can be used as well. Those have the Teksid block, the B heads and an iron crank. The cam profiles are slightly different from the cobra and the intake is slightly different.
1992 Thunderbird SC 5 speed. |
#39 | |
Not huge differences
#40 |
1992 T-bird SC
It works fine with the manual tranny. The IMRC's on the 93-96 use a vacuum based setup, the 97-98 use electric just like the cobra.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/96-98/142461-4v-2v-differences.html
| 4.6L block - 2003-04 Mach 1 Registry Owners Club | This thread | Refback | November 19th, 2009 09:52 PM | |
| 4.6L block - 2003-04 Mach 1 Registry Owners Club | This thread | Refback | November 19th, 2009 06:00 PM | |
| 4.6L block - 2003-04 Mach 1 Registry Owners Club | This thread | Refback | November 19th, 2009 04:43 PM | |
Threads Similar to: 4v and 2v differences
| differences in hp | Codeman | V6 Mustangs | 5 | June 20th, 2009 12:57 PM |
| Differences between '85 and '92 WC-T5? | Burn'nRubber | 5.0 Mustangs | 4 | March 14th, 2008 08:54 PM |
| 4.6L differences | mmvi | 4V / SVT | 8 | February 1st, 2008 06:12 PM |
| what are the differences... | PiggySmallz | 2005 - 2010 | 12 | September 5th, 2007 05:47 PM |
| What are the differences? | 01silversnake | 99-04 | 0 | June 27th, 2007 03:59 PM |
