mil eliminators
Old November 8th, 2009, 04:08 PM   #1
xtian96gt is on a distinguished road
mil eliminators
running an off road x pipe but cut 2 of the 4 cats on my mustang..welded on :/ now check engine light comes on at times then turns off..but with the mil eliminators do they help turn of the light?and can help pass inspection thanks
Old November 8th, 2009, 04:37 PM   #2
mmikeclass06's Avatar
another dahm ford
mmikeclass06 is on a distinguished road
i live in a emissions county here in austin tx and run a catless h pipe with roush side exit. the MIL's will tell your computer that the exhaust is reading correct, and will keep your engine light off. as long as your cars engine hasent been abused and is worn it should (not promising) pass emissions. that is if they do a exhaust reading. but if they dont and just check ur lights, look at your exhaust, you should be fine
97' 3.8 to 4.6 swap all stock
67' mustang gt coupe
88' ranger, just a clean ass truck
48' jeep cj2 the work hogg
Old November 8th, 2009, 04:40 PM   #3
appreciate that.
Old November 9th, 2009, 05:59 PM   #4
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
Call a shop and ask if they do a visual inspection on the exhaust or just a computer read.
With a set of mil's you should really pass either way because you have the 2 cats if they do the visual.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old November 9th, 2009, 10:24 PM   #5
97GT4.6's Avatar
97 GT
14.2@99.8 @ 4800 ft
97GT4.6 has a spectacular aura about97GT4.6 has a spectacular aura about97GT4.6 has a spectacular aura about
Send a message via AIM to 97GT4.6
Cammed 2v
Built By MustangMatt
More mods than times your daughter has slept around
Old November 12th, 2009, 11:20 AM   #6
1slow97's Avatar
1998 GT
1slow97 is on a distinguished road
I have a pypes catless x-pipe and the plug in MIL's from American Muscle and sometimes the oxygen sensor will throw a code a make the check engine light come on. I gave it a squirt of nitrous the first time and it went away, But this time it stayed on. Any advice on what to do?
Old November 12th, 2009, 05:18 PM   #7
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
Did you read the code? What is it for exactly? Maybe it's a bad front 02 sensor or a bad set of mil's.
MODS IN GARAGE
NCMM ORIGINAL
Old November 12th, 2009, 05:29 PM   #8
330CubeGt's Avatar
1997 SVT COBRA
1996 Mustang V6
330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light
iTrader: 14 reviews
you can make you own mil elims let me know if interested and i can find you the write up...
-04 IRS - Magnaflow - Wheel Replica - Autometer - FTBR - FRPP - SCT - Brembo - PRO 5.0 - BOI-
Old November 12th, 2009, 11:08 PM   #9
1slow97's Avatar
1998 GT
i forget the exact code but it was the back passenger side sensor. But on the way home today the light turned off
Old November 12th, 2009, 11:57 PM   #10
MM's DRUNKEN SAILOR
deedub97GT's Avatar
single turbo in the works
as fast as i can push it!
deedub97GT is a splendid one to beholddeedub97GT is a splendid one to beholddeedub97GT is a splendid one to beholddeedub97GT is a splendid one to beholddeedub97GT is a splendid one to beholddeedub97GT is a splendid one to beholddeedub97GT is a splendid one to behold
Send a message via Yahoo to deedub97GT
hey u thinki might be able to get that? thanks.
MILITARY CREW GSM3
i love throbbing meat
Old November 16th, 2009, 09:57 AM   #11
BAzombie's Avatar
1996 GT Convertible
13.88@100.71
BAzombie will become famous soon enough
How to Make MIL Eliminators for your Mustang
Mods: Katzkin Leather, MMR stage II heads w/PI cams, PI intake, Accufab 75mm TB & Plenum, CAI, Ram HDX clutch, Pacesetter LT's & X pipe, Pypes hi-flo cats, Flowmaster cat back,3.73 gears, Sct SF3 tuner, Mamba M2's
Old November 16th, 2009, 03:12 PM   #12
330CubeGt's Avatar
1997 SVT COBRA
1996 Mustang V6
iTrader: 14 reviews
^ Thanks...
Old November 18th, 2009, 03:42 PM   #13
1996 mustang gt
unkown
jchr96gt is on a distinguished road
did you fix ur engine light?from the mil
Old November 19th, 2009, 09:57 AM   #14
1slow97's Avatar
1998 GT
Mine has went off and hasnt came back on yet
Threads Similar to: mil eliminators
mil eliminators jchr96gt 96-98 6 June 2nd, 2009 10:47 PM
So you want mil eliminators? Seabee 99-04 4 August 16th, 2008 08:07 PM
Where can i get MIL eliminators?? 06GTMustang89 2005 - 2010 8 August 13th, 2008 09:38 PM
Do i need mil eliminators fordman1989 General Tech 4 July 17th, 2007 09:33 PM
MIL Eliminators HessiaN257 Modular Mustangs 4 June 11th, 2007 08:47 PM
