Advice on next mod - Page 2
Old November 9th, 2009, 01:20 PM   #21
BYAHHHH!
Scott2001GT's Avatar
2001 Mustang GT
13.874
i have 4:10s in my auto
Old November 9th, 2009, 01:40 PM   #22
1998 Mustang GT Vert
AdaBoNGT is on a distinguished road
Yeah im not going any higher than 4.10. Either 3.73 or 4.10
Old November 9th, 2009, 01:49 PM   #23
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Mach Boy has a spectacular aura aboutMach Boy has a spectacular aura about
Originally Posted by 97mustanggt View Post
if its manual get a aftermarket shifter, and some suspension work, all that power u want is worthless if you cant stick it to tha ground.
No offense but what power? He's making less than 200rwhp. Do a PI swap with cams if you can afford it and then go suspension.
Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector)
Old November 9th, 2009, 01:52 PM   #24
97mustanggt's Avatar
97GT & 97Snake & 00L
T.B.A
97mustanggt will become famous soon enough
fine fine, haha just get some sticky tires cause even tho tha power aint that high still spins out like a bitch
97 Cobra & 00 Lightning
Beauty & The Beast
I rev next to hybrids so they can hear me kill the environment
MM Cobra Club Member #77
MM Lightning Club Founder
Old November 9th, 2009, 03:23 PM   #25
zigbigadoru's Avatar
97 Mustang GT
slower than the speed of smell
zigbigadoru will become famous soon enoughzigbigadoru will become famous soon enough
pi swap with cams
Originally Posted by XTCNAGT View Post
That's what you get for excercising.
You think my lungs and chest hurt when I drive down the road for a triple baconator? No. You know why? Cause I'm smart.
Time for a nap.
Old November 9th, 2009, 04:34 PM   #26
Less than 200rwHP? I'm pretty sure i'm easily @ 200+ rwHP. A stock automatic '98GT definitely less than 200rwhp around 180rwhp.
Old November 9th, 2009, 05:41 PM   #27
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
Do the swap yourself and you'll have enough left over for the gears or exhaust. There are write ups in the forum sticky that will walk you through the swap.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old November 9th, 2009, 07:04 PM   #28
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
With a 17% drivetrain loss you're looking at roughly 35-40hp lost from the base 225hp on a 96-98 Mustang GT. UDPs and a CAI might net you 10 rwhp if you're lucky. Or you could swap over to the PI heads and be at 230rwhp plus the hp picked up from the UDPs and CAI. Hate me if you want but the numbers don't lie and for a few hundred bucks that's a hell of a deal.
Old November 9th, 2009, 09:14 PM   #29
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
200ish rwhp is about right. i would look into the pi swap. if you on a budget, atleast to the intake manifold and pi cams. you could do the headers and mid pipe as well with the left over $$$.
Old November 10th, 2009, 12:19 AM   #30
Sorry Mach Boy, you must have missed when i said what mods i had. I agree a stock 98 GT would be less than 200rwhp. I have a CAI, catback flowmaster exhaust, ford racing pullies, and an SCT tuner set @ 93 octane performance. Also all the fluids in my car are Royal Purple which gives a few (pretty much meaning less) HP.
Old November 10th, 2009, 08:58 AM   #31
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
The oil will add nothing measureable so don't even mention it or people will laugh in your face and ask if you have any stickers that add HP. If the UDPs, CAI, and catback added 15rwhp I'd be extremely surprised. The tune will add a few as well, but is it a canned tune or was it dyno/track tuned? Whatever that's not the point. The point is if you get the PI swap you're picking up 40hp. And with your weight advantage you will be able to hang with a lot of the turbo 4 bangers out there as well as the PI GTs.
Old November 10th, 2009, 09:01 AM   #32
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
its not uncommon for npi cars to be get 200ish rwhp with minor mods.
Old November 10th, 2009, 09:12 AM   #33
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Right I'm not stating that. It is likely that he is right around 200. Not much above or below. He still doesn't have a high flow midpipe which would be the biggest gain as far as bolt ons go. But a PI swap is the best thing he could do for minimal cash without doing nitrous.
Old November 10th, 2009, 03:38 PM   #34
Being very ungenerous and taking 20% off stock HP id only need 250hp to get 200rwhp. So seeing as before i even got my tuner i was keeping up with an stock '04 GT (260hp) makes me think i was a little closer to the 200rwhp then since '04 GTs make 208 rwhp. I also had another person in my car and the '04 was just the driver.
As for my next mod i think PI swap is set in stone, after that comes the x-pipe/LT headers.
Old November 11th, 2009, 02:19 PM   #35
I've been hearing the only major difference between PI and NPI is largely the CAMs. What would the difference be if i did the full PI swap vs some good comp CAMs?
Old November 11th, 2009, 06:22 PM   #36
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
Most of the power gained from the pi swap comes from the cams and intake. The advantage to adding the heads comes in the higher compression ratio from the different head size.
MODS IN GARAGE
NCMM ORIGINAL
Old December 24th, 2009, 08:39 PM   #37
13.3 @107 2.1 on street tires
will2045 is on a distinguished road
Send a message via AIM to will2045
Originally Posted by 96sickstang View Post
i am sellin my new still in box bbk longtube headers with a o/r x pipe if ur interested hit me up
still got this cause im interested now if so.
Old December 24th, 2009, 08:44 PM   #38
how much gain did you notice after the under drive pulleys? im in a very similar spot, just got my 96GT yesterday and am already looking for suggestions for more power. its totally stock right now. sorry im invading your thread but this is exactly what im trying to figure out. i was considering the motor swap to a 351W but id rather just do it this way and save a little blood. let me know how any of these worked out for you and what you would reccomend after doing all this because im anxious to get started on this, thanks man.
Old December 24th, 2009, 11:26 PM   #39
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
sharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud of
iTrader: 10 reviews
I only made 227 rwhp running 6psi
But im the baddest 227rwhp car on the road =)
410rwhp 520rwtq @ 12.9 psi
Threads Similar to: Advice on next mod
First Mod: need advice/ vedor info fastopaquezebra 2005 - 2010 11 January 28th, 2009 04:39 PM
Next mod need advice BigC004 99-04 23 June 12th, 2008 09:41 PM
Mod List Advice btrokc 2005 - 2010 18 December 9th, 2007 01:31 AM
Need advice on next mod. auburntiger7231 99-04 13 August 5th, 2007 11:15 PM
Newbie here. Looking for advice on mod motors! ujslost 96-98 5 March 18th, 2007 10:30 PM
