2003 Cobra
Mods
I am a 0-100 kinda guy
I got a 96GT what will my 0-60 time be cut to if I have the 4:11's installed A dramatic difference? Like i said i am big on the sit ur ass back in the seat through the gears I also have a few sensor problems, whats a good shop to take it to get these type things fixed, just any regular shop? |
4.10's will help your 0-60 alot. Just keep in mind that alot of people tell you to do all kinds of engine mods and never work to make the suspension better. 0-60 can get better from suspension upgrades alone. My stock intake/head/cam npi ran high 13/low 14 all day. Mods were off road h pipe,frpp shorties, pullies, underdrive pullies, tubular k member, jlt cold air, 4.10 gear and rear upper and lower control arms. This was on a set of street tires with only the spare tire and jack removed, I was able to cut 1.90 60' times.
gears intalled
hey guys well i finally gotmy gears installed 4.10 motive, i really dont hear very much whinning at all when driving up to speed but when i am slowing down i hear the gears whine kind of loud. the gears say that they require a 500 mile breack in would this kind of help the winning, also when I put it in reverse i hear a clunkk kind of loud. does anyone have any ideas as to what the clunnkk could be >?????? any opinions or advise would be apreciated.
A clunk may be a u-joint.
is there a way to check the u joints for damage or is it a part that just needs to be replaced to c the results??
Lift the rear tires off the ground, leave car in gear or apply e brake, rotate driveshaft by hand. If it is bad you'll have play or you will see excessive movement in the joint. Also the 500 mile rule only applies to bearing replacement, I have 30000 on my gears and beat the snot out of them from the minute they were installed, whinning is from a bad installation.
2003 Cobra
boomer, can i run your setup of mods on my 96 gt?
And is there anything I need extra to make the mods work? I want to go with the setup you listed basically. Give me some good detail name brands because im going to try order it all offline then find a shop to install anything I cant figure out with a hanes manual. |
2003 Cobra
Oh and I need some help on the sensor advice. Cause im throwing codes mainly MAF codes
But I dont wanna get ripped off and I dont know exactly what name/brand I need to replace it with. Also after you replace the sensors do you have to get it tune'd And last but not least where do you exactly get a "tune" or is it just a tune-up? Or more of a diagnostics tune? |
nHuman, pm sent I'll get to it for you.
2003 Cobra
Thanks boomer
#11 | |
Rear upper control arms (metco motorsports) mca 0003 uca Lakewood 50/50 rear (foxbody) shocks MOROSO (foxbody) rear progressive rate drag spring Metco motorsports frame rail connectors PA racing chromoly tubular k member and adjustable a arms Maximun motorsports caster camber plates. I bought these used but I'm pretty sure they are strange adjustable struts and coilovers. Bolt ons were as follows: Jlt cold air intake Accufab upper plenum Accufab 70 mm Throttle body Steeda underdrive pullies Ford racing header (shorties) BBK offroad H-pipe dynomax mufflers with dumps at the axle Ford 4:10 ring and pinion After tuning the suspension (rear) on street tires at the dragstrip I was able to run a best of 13.78 (with factory upper and t-body). I then wanted more and bolted on a P.I intake with Accufab upper and throttle body and was able to crack off a nice 13.53 after a 1.95 60' on sreet tires. With the addition of P.I cams, e/t streets and weld wheels it took no time to run a high 12. That combo in full N/A street trim with ported heads, custom cams and ect. was able to run a final 11.90's 1/4 mile before the trans expired on the dyno. Hope some of this helps you !!!!
1996 Cobra (Mystic)
The gears shouldnt whine very much at all. If the whining dosent stop take it back to where you got it installed. Whining usually means there isnt enough backlash between the gears. This can cause them to over heat and fry you rear end.
1996 COBRA MODS: 4.10 Gears MAC Exhaust MAC H-Pipe CAI MAF Pro 5.0 shifter Eibach Sport Line Tuned |
2003 Cobra
Is the Ford 4:10 ring and pinion all you need to put in gears on a 96 GT?
1996 Cobra (Mystic)
You can get away with just the ring and pinion but you are much better off replacing the carrier bearings and races, along with the pinion bearing and race with everything out. The bearing and race kit should costs under $50. Just my two cents
Threads Similar to: Mods
| 2.3T Mods | Ga_50_foxbody | 2.3 Mustangs | 55 | July 11th, 2007 02:56 PM |
| mods?? | mb03stang | 99-04 | 6 | July 6th, 2007 03:30 AM |
| mods | 06dkkiser | V6 Mustangs | 10 | June 26th, 2007 08:44 PM |
| mods | Mustang RacR94 | V6 Mustangs | 5 | March 30th, 2007 06:23 PM |
| 07 top 5 mods for under 400$ | TDog | 2005 - 2010 | 22 | February 9th, 2007 11:39 PM |
