CEL from runnin lean
Old December 19th, 2009, 10:36 PM   #1
Thumbie's Avatar
2001 Cobra
14.2@102 (I suck)
Thumbie is a jewel in the roughThumbie is a jewel in the roughThumbie is a jewel in the roughThumbie is a jewel in the rough
Took it to a shop to see what teh check engine light was all about, dude said bnak 12 and bank 22 show lean. any info on what this mean/what I should do about this? any help will be repped
2001 Cobra with SRA swap, modded for twisties
MM Cobra Club Member #76
Old December 19th, 2009, 10:44 PM   #2
13.64@101mph
first off im wondering why they didnt tell you anything other than the codes, what kinda help is that? secondly im starting to wonder if these years are famous for this...did he tell you the exact code they threw out? usually with running lean, it has to with either the injectors not pulsing, or being blocked or a bad one or two. OR it could be a bad o2 sensor telling the system to run lean! im going through the same issue kind of and mines turned into detonation, so watch out and get this fixed asap. running lean is very bad for the motor!
1990 GT- 5.0L |BBK Shortys|VRS O/R X| SLP LM1 Catback|BBK CAI| Centerforce Clutch|MGW Short Throw| Alum D/S| 3.73's| Steeda Springs...about as stock as a 5.0 comes now a days..much more to come
Old December 19th, 2009, 10:47 PM   #3
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.99 @ 113.9mph
sharkbait is a splendid one to beholdsharkbait is a splendid one to beholdsharkbait is a splendid one to beholdsharkbait is a splendid one to beholdsharkbait is a splendid one to beholdsharkbait is a splendid one to beholdsharkbait is a splendid one to beholdsharkbait is a splendid one to behold
iTrader: 9 reviews
Run some fuel system cleaner. Clean the MAF sensor.
Take out the injectors and make sure there not clogged. Get some new o2 sensors.
Seafoam it.
Then see what happens
374rwhp 456rwtq @ 8psi
Old December 19th, 2009, 10:49 PM   #4
13.64@101mph
i'd do the seafom before cleaning the injectors, cuz like it my case he could end up having to do it again if the seafom breaks something big away!
Old December 20th, 2009, 12:52 AM   #5
Thumbie's Avatar
2001 Cobra
14.2@102 (I suck)
seafoam...motor treatment? gotit will pick some up tomorrow as well as MAF cleaner.
thanks guys.
Threads Similar to: CEL from runnin lean
lean really lean plaese help 331 stroker stangzilla 331 94-95 8 January 30th, 2010 07:58 PM
those of u runnin c4?.... flatlinerford 5.0 Mustangs 1 October 13th, 2009 01:27 AM
Anyone runnin these wheels? STANGATUDE 99-04 2 March 13th, 2009 12:37 PM
runnin shoes graystang01 The Clubhouse 19 June 17th, 2008 09:35 PM
runnin 13s stangrr 96-98 23 January 13th, 2007 05:58 AM
