correct injector size
Old January 14th, 2010, 06:37 PM   #1
stockstang is on a distinguished road
alrigtht i have a stock 4.6 2v with only bolt-ons and im wondering if 24lb injectors will work well with what i have. it has long tube headers, offroad h-pipe, flowmaster mufflers, trick flow upper plenum, i think 75mm throttle body, cold air intake, bbk under drive pulleys
Old January 14th, 2010, 11:13 PM   #2
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.99 @ 113.9mph
sharkbait is a splendid one to beholdsharkbait is a splendid one to beholdsharkbait is a splendid one to beholdsharkbait is a splendid one to beholdsharkbait is a splendid one to beholdsharkbait is a splendid one to beholdsharkbait is a splendid one to beholdsharkbait is a splendid one to behold
iTrader: 9 reviews
Youll either need a tune or a calibrated mass air flow sensor.
You can run 80lbs injectors aslong as you have to correct mass air
Your really not running enough mods to have to bump the fuel system up. But if you want to it should work just fine
374rwhp 456rwtq @ 8psi
Old January 14th, 2010, 11:15 PM   #3
HMUSN's Avatar
iTrader: 9 reviews
^ exactly. Your 19 pound injectors are just fine with those mods.
Old January 16th, 2010, 01:33 AM   #4
97Dustang's Avatar
97 GT and 03 Cobra
12.75@105
97Dustang will become famous soon enough
save the money and put it towards a p.i. swap first
2003 COBRA FOR SALE PM FOR DETAILS
Old February 9th, 2010, 05:36 PM   #5
1998 Mustang GT
N/A
tyler1987 is on a distinguished road
Ok guys I know this post is a little old but did not want to make a new thread about the same oh thing. So I am wanting to upgrade my injectors to 42lb I have a 4" ram air intake with a after market plenum and under drive pullys. I am wanting to know if it will give me a little more HP with the bigger injectors then if I wanted to know if I would be running to rich I am upgradeing the fuil rails and putting a stand alone fuil mangment system then tunning it with 4.10 gears. So would all this work just fine are should I go smaller injecters?
Old February 9th, 2010, 05:44 PM   #6
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.99 @ 113.9mph
iTrader: 9 reviews
Tyler, going to 42lbs would be a horrible idea.
First off your mods dont even start to push the boundries of the stock fuel system. Second with any injectors you will need a calibrated mass air or a tune. Which will cost around 400+.
If you want you can put 30lbs with a calibrated mass air and your car will run fine. But you will not gain any HP
Injectors are a supporting mod. They give you the ability to make more, but they do not add any power.
Really go spend the money on a Pi swap and youll love life
Old February 9th, 2010, 06:15 PM   #7
1998 Mustang GT
N/A
Well I am planing on getting it tuned so that would be no big deal i have looked a little into a pi swap but looks like about 1,000.00 for the heads then I think it would be a pain in the a** to change them out my self so what would it run to have someone els do it? I am steal new to this so thanks for the help man.
Old February 9th, 2010, 06:30 PM   #8
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.99 @ 113.9mph
iTrader: 9 reviews
Hey tyler. Again you really really really dont need 42lbs. 42lbs will get you to 600hp or so. Again your not making 600 or anything close
Also what you need is to find a wrecked 99-04 mustang and take there heads/intake/cams and that alone will net you 260rwhp (total) and have your compression ratio up to around 10:1. Which isnt a bad idea and it bolts straight on!
You really should decide on your long term goal.
Old February 9th, 2010, 06:36 PM   #9
1998 Mustang GT
N/A
Ok what would you say if I wanted to put stage two cames with the pi head swap would that put me up to about 300rhp with my diablo chip and tune?
Old February 9th, 2010, 06:42 PM   #10
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.99 @ 113.9mph
iTrader: 9 reviews
Well the diablo chip and the tune will be one in the same. Because all the chip is, is a tune.
With a Pi swap you cant run as big of cams as you could with a non pi swapped gt. With cams iv seen people make about 290rwhp with the full pi swap. I would look into injectors if you are planning on going that far. But again, your going to need a tune when you get the cams.
Also id do some calling around right now. See what the local tuning shops use for there tuning. Some use SCT others use Diablo.
Old February 9th, 2010, 07:18 PM   #11
1998 Mustang GT
N/A
the shop i am going to is diablo so i know that one told me it would be about 400 with chip and tune so do you think i could do stage 2 cams with the pi swap and should i go up to 30lb injectors?
Old February 9th, 2010, 07:58 PM   #12
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.99 @ 113.9mph
iTrader: 9 reviews
I found this guys stuff. He has the same type of setup that you are looking at going with.
97GT4.6's 1997 Ford Mustang GT
tell me if it helps or if you have questions
Old February 9th, 2010, 08:28 PM   #13
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all
iTrader: 13 reviews
Why not use some stage II patriots?
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old February 9th, 2010, 08:56 PM   #14
2001 Mustang GT
TheHambone will become famous soon enough
When choosing an injector.. you need to look at your long term plan.. If you will need 60's later on... then get the 60's now.. you can always tune the injector down, but you can do shit when your out of injector. Why buy 42's now and then 60's later.. I dunno about you guys, but I like to buy things once.. just my opinion.
Old February 9th, 2010, 10:11 PM   #15
1998 Mustang GT
N/A
Them patriots stage II are about 1600 for them and i can get a full pi set up for the car for 500 if i go with 99-04 but i don't no what the power difference?
Old February 9th, 2010, 10:18 PM   #16
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.99 @ 113.9mph
iTrader: 9 reviews
IF you know who to talk to. You can get the 99-04 heads ported to make them flow just like the patriots. Arnt patriots just ported pi heads anyway?
You could go with 60s...hell you could go with 80s just make sure you have a good tuner.
Old February 9th, 2010, 11:27 PM   #17
2001 Mustang GT
Call around man.. I bought my trick flows for 1700 bucks.. a full out stage 2 or 3 cant even compete..
Old February 9th, 2010, 11:39 PM   #18
1998 Mustang GT
N/A
So trick flows are the shit hey what would be the hp gain with them?
Old February 10th, 2010, 11:06 PM   #19
1998 Mustang GT
N/A
So I have decided to go with the pi head swap with 42lb injectors with stage II cams and 4:10gears in the back end. Looking know to see who can port my pi heads know to see if it will be worth it. Just want to thank all you for you help on telling me what would be good and what would be bad so thanks you have been a huge help. Hope to update here soon so i can tell you all what I am running at the track woot woot cant wait lol.
Then there was one.
Old February 10th, 2010, 11:10 PM   #20
MM's Mad Scientist
acmillr's Avatar
Slow Fella
acmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to behold
Why oh WHY would you put 42# injectors in this set up. I do not understand why people think that they need huge injectors. The smaller, the better as far as tuning goes. You will gain zero power going with bigger injectors. In fact, unless you swap pumps, you aren't going to be able to use the injectors anywhere close to their potential anyway.....
Threads Similar to: correct injector size
best injector size crappy_head 99-04 8 May 30th, 2008 02:53 PM
injector size? TKOTLARZ 94-95 12 March 1st, 2008 01:31 PM
Injector size HELP! NOSLO5.0 5.0 Mustangs 6 January 18th, 2008 10:52 AM
Injector Size imported_Gt_Jay 5.0 Mustangs 12 November 14th, 2007 03:09 PM
injector size? 92_LX_5.0 5.0 Mustangs 6 February 11th, 2007 02:42 AM
