changing two twin cam heads?
Old February 26th, 2007, 02:29 AM   #1
knightwise2000 is on a distinguished road
ok here go's has anyone tryed to take the twin cam heads off a lincon 4.6l an put it on a 1997 GT can it be done and if so what do I need to change I have a doner motor from a mark 8 I think. thank you for any help you guys can give me.
Old February 26th, 2007, 11:37 AM   #2
BlackSunshine
Guest
Posts: n/a
I can't wait to hear a reply on this I have been wondering about this forever I know where there are 3 mark 8's with good engines but totalled bodies....
Old February 26th, 2007, 02:01 PM   #3
Boomer is on a distinguished road
Send a message via AIM to Boomer Send a message via Yahoo to Boomer
The answer is yes, you are going to need the front cover intake and all the p-arts other than the shortblock. Keep in mind you will have a slightly lower compression ratio and the early mark intakes and heads are not real power making items. You will end up with about the same as doing a P.I cam and intake swap as far as power at 10 times the cost and headaches of wiring, if you want the 4 valve power look for a complete cobra engine.
Old February 27th, 2007, 01:16 AM   #4
thank's Boomer for the info you have saved me from what could of been a nightmare. keep it shifting
Old February 27th, 2007, 01:17 AM   #5
thanks Boomer that info realy helps.
Threads Similar to: changing two twin cam heads?
changing injectors kenevil331 5.0 Mustangs 3 July 29th, 2007 09:27 PM
changing up my new to me 95 GT 5.0 H.O. CUL8TER 5.0 Mustangs 6 July 24th, 2007 08:14 PM
Changing a link stanglifemike The Clubhouse 29 July 16th, 2007 02:03 AM
changing the whole gearbox from 5 man into 6 man Evilspark 2005 - 2010 1 June 12th, 2007 12:57 AM
Changing a V8 to a V6 cleary Classic Mustangs 18 April 12th, 2007 09:59 PM
