1998 mustang gt
Running lean????? need input!
hey guys i need help this is what i got... just put a new intake set up on... ported c&l upper plenum, ported 70mm throttle body, 80 mm mass air meter, and cold air intake... seems i lost power over stock now it bogs down whenever i try to get on it... heres my thoughts would a diablosport tuner slove my seemingly air fuel ratio problems???
Hooo Ha Ha
Now was this new mass air tuned? If not thats your issue right there. The tuner would help you out aslong as you can get a tune for your new 80mm mass air.
![]() 374rwhp 456rwtq @ 8psi |
1998 mustang gt
well the car came with the maf and ran much better before i put the t/b plenum set up on last week.. it seems to be getting worse as the days go on...
1998 mustang gt
how does one tune for his maf??
Hooo Ha Ha
First how do you know its running lean?
Also check for vacum leaks. Use your hands and look around for leaks around the work you just did. Thos modes should of cause you to run lean. Maybe somethings lose and its sucking in air and bypassing your maf...which causes you to run lean. With a tuner you can add some fuel to your mixture.
1998 mustang gt
my check engine light came on two codes came up maf something or other basically vacuum or too much air i guess.
Hooo Ha Ha
Ok so check for vacum leaks, its the cheapest alternative. You really shouldnt have any MAF problems if it worked before. Which leads me to believe its a vacuum leak.
You can tune your MAF meter. You can will probobly need a tune emailed to you or have your car dyno tuned if you want to go that far. But i think if yours ran great then you dont need any of that
1998 mustang gt
changed my tps and iac motor seemed to almost solve the problem
2001 Cobra
14.2@102 (I suck)
just getting a cold air kit and a new catback will require a tune. a dyno tune is your best bet
![]() 2001 Cobra with SRA swap, modded for twisties ![]() MM Cobra Club Member #76 |
#10 | |
Hooo Ha Ha
Also correction to my last post. You can tune your ECU to compensate for the MAF. You need special equipment to tune them
#11 | |
Hardon Enflooziast
![]() If you say so...
![]() Bridget: 98 Mustang GT - PI Swapped, J-Mod and B&M Shifter...wrapped it around a tree sparing a deer - RIP Sephie: 94 Mustang GT Vert - Full 03 cobra suspension and brakes, Magnaflow catback, K&N drop in filter, timed at 12*, SS brake lines, |
1998 mustang gt
i was wondering about a diablosport preditor... can you get a dyno tune and use that to program the ecu???? also i just ordered msd coils and those e3 spark plugs
Hardon Enflooziast
Sure can, but check with your tuner before you order it, they might use the SCT, and that'd suck to buy a tuner you don't need lol.
2001 Cobra
14.2@102 (I suck)
naw I was reading about this in like Popular Mechanics. the computer on the car tested could handle a cold air, or exhaust, but when both were put on the computer needed slight adjustment to MAXIMIZE the increase in flowrate. In otherwords, the computer had to be tuned to fully utilize them correctly. I mean, we're talking gains of like 5 hp anyways...
1998 mustang gt
well that kind of explains my troubles... i have custom exhaust too... next step tuner then headers... msd is in the mail
What kind of tuner would be best and for a desent price? where can i find cheap ones?
3.55 gears, Cai, magnaflow exhaust, advanced timing to 12 degrees,underdrive pullies, throttle body spacer, plenum intake spacer, BBK o/r H-pipe, king cobra clutch....havent gone to the dyno, more to come |
1998 mustang gt
i found the diablosport for 282 at rpmoutlet.com... i have two dynos close to me... one uses sct the other diablo... guess i'm lucky to have my choice
Hooo Ha Ha
Steel you dont want the cheapest tuner. Its one of those things that you dont want to skimp on.
Getting a bad tune can blow your engine... so just get a nice one like diablo or SCT. Before you go out spending all this money. Try cleaning your MAF sensor. the can cost 6 bux at auto zone. its says Mass Airflow cleaner. Then check all your hoses. Really a tune/tuner is a little far for your mods.
Threads Similar to: Running lean????? need input!
| 99 GT Running Lean? | luis84 | 99-04 | 3 | April 28th, 2009 01:42 PM |
| running lean. | daschaffa17 | 2005 - 2010 | 11 | April 22nd, 2009 12:55 PM |
| Running lean | ByPopularDemand | V6 Mustangs | 1 | March 18th, 2009 08:30 PM |
| running lean | silvergtstang99 | 99-04 | 4 | May 27th, 2008 07:21 PM |
| Running Lean | 1982matthew | 5.0 Mustangs | 2 | April 23rd, 2008 05:01 PM |
