transmission header clearance
Old February 6th, 2010, 04:28 PM   #1
djstaab's Avatar
'90, '98, and '06 GT's
djstaab is on a distinguished road
Send a message via AIM to djstaab
i have a 98 gt and i just got my motor back from the machinist. i put bbk long-tube headers on and the motor is back in. my question is how do i get the transmission to clear the headers? i'm sure you all know how cramped that engine bay is. i don't think i can get to the header bolts without removing the engine again. any ideas? thanks.
Old February 6th, 2010, 07:22 PM   #2
tfofkyle's Avatar
96 Mustang GT
tfofkyle will become famous soon enoughtfofkyle will become famous soon enough
remove the engine or drop the k member. i believe the passenger side header is the one thats screwing you over. if you can remove it things should clear.
Old February 10th, 2010, 04:16 AM   #3
92 notch
9.56
mvp performance is on a distinguished road
Take the motor mount nuts off jack passenger side of motor up three inches and loosen header bolts on passenger side. The trans will clear the header then put starter on and tighten header back down. This is how we did it. Yes its a tight pain in the rear but you can do it without pulling motor or dropping the k. Look at the bbk instructions on their site. Good luck
Old February 10th, 2010, 02:09 PM   #4
NO_PI_NO_POWER's Avatar
1997 Mustang GT
12.501@116.35
NO_PI_NO_POWER will become famous soon enough
Send a message via AIM to NO_PI_NO_POWER Send a message via Yahoo to NO_PI_NO_POWER Send a message via Skype™ to NO_PI_NO_POWER
My buddies and I have manuals, and we just put the porta power on them and spread em just enough.
1997 GT
1989 LX ~Dangerously Quick/Needs Battery
Old February 10th, 2010, 04:52 PM   #5
ModMustang97GT's Avatar
1997 Mustang GT
Faster than an s4
ModMustang97GT has a spectacular aura aboutModMustang97GT has a spectacular aura aboutModMustang97GT has a spectacular aura about
The BBK's I don't believe has as much play in them as the MAC's. With the MAC LT's you just spread them apart and pull the tranny. With the BBK's I believe you have to at least loosen the Passenger side header.
You should just get a tubular K member (I love when people suggest this $1400 upgrade like its an after thought).
Jacking up the motor is the easiest way to do it without dropping the K member. However, you are still in for some knuckly busting. If I were to do it all again, i'd just get the arm that holds up your engine while you install the LT's by dropping the K member. Or I'd just get a Tubular K member. Not worth the whole mess of jacking up the motor and smashing my knuckles on the garage floor for a week. F you are your sheetmetal K member Ford!
Aztec Gold 97GT.
MM CC Plates, Panhard Bar, SFC's & Tower Brace
Eibach Sway Bars
H&R Race Springs/Bilstein Shocks
MAC CAI, LT's, Catted H and Pro-Dumps
KB Boost-a-Spark
04' PI Motor
Author of The Official Suspension Guide
Old February 10th, 2010, 05:00 PM   #6
1997 Mustang GT
12.501@116.35
Oh, yeah we have Mac Long Tubes.
1997 GT
Threads Similar to: transmission header clearance
LT Header Clearance? LaserRed97GT 96-98 4 April 16th, 2009 01:51 PM
header clearance 408gt91 General Tech 1 August 23rd, 2007 10:52 AM
LT header clearance blk98gt 96-98 4 June 27th, 2007 07:17 PM
header clearance? 95wip 94-95 3 April 10th, 2007 11:56 AM
header clearance My67_fastback Classic Mustangs 6 February 25th, 2007 05:03 PM
