Clutch!!
Old February 11th, 2010, 06:10 PM   #1
Steelsoldi3r is on a distinguished road
Help With my Clutch-Help
Hey guys it seems like my clutch is worn out...could i just adjust it? and if so how would i adjust it? also if it is a worn out clutch what would be the best one to buy that is also a desent price? Thanks
3.55 gears, Cai, magnaflow exhaust, advanced timing to 12 degrees,underdrive pullies, throttle body spacer, plenum intake spacer, BBK o/r H-pipe, king cobra clutch....havent gone to the dyno, more to come
Old February 11th, 2010, 06:15 PM   #2
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all
iTrader: 13 reviews
A king cobra clutch is a great low cost replacement for stock. Just make sure to go ahead and replace the t.o.b. as well.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old February 11th, 2010, 06:19 PM   #3
what do u mean by t.o.b?
Old February 11th, 2010, 06:46 PM   #4
red01's Avatar
red01 is on a distinguished road
tob = throw out bearing. Comes with 99% of the clutch kits you buy.
1997 Mustang GT
04 PI 2V, bolt ons, gears, tune
255/292
www.covertmotorsports.net
Old February 11th, 2010, 06:47 PM   #5
Hardon Enflooziast
98FireyGT!'s Avatar
'94 GT Vert
Havn't tried...
98FireyGT! is a glorious beacon of light98FireyGT! is a glorious beacon of light98FireyGT! is a glorious beacon of light98FireyGT! is a glorious beacon of light98FireyGT! is a glorious beacon of light
Send a message via MSN to 98FireyGT!
tob = tongue on butthole
No, for real though, USE A OEM TOB!
All the others can cause problems.
Bridget: 98 Mustang GT - PI Swapped, J-Mod and B&M Shifter...wrapped it around a tree sparing a deer - RIP
Sephie: 94 Mustang GT Vert - Full 03 cobra suspension and brakes, Magnaflow catback, K&N drop in filter, timed at 12*, SS brake lines,
Old February 11th, 2010, 06:58 PM   #6
ok, and is there anyway to adjust the one i have now? and if not how hard is it to replace the TOB and clutch?
Old February 11th, 2010, 08:38 PM   #7
LGHTNG02GT's Avatar
4V swapped '02 GT
(2v) 13.9@101
LGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the rough
iTrader: 10 reviews
you should be able to adjust it some. all you have to do is pull up on the clutch pedal and push it all the way in. (this is assuming you dont already have an adjustable clutch cable and aftermarket quadrant) how many miles do you have on the car??? to replace a clutch you have to at least drop the tranny. clutch kits are maybe 200-400 depending on what you want. i went with a SPEC clutch and just got a Ford Throw out bearing.
BSD 100MPH Club
YMR #8975
4v Swap and a little Purple Bottle
MM Nitrous Club #7
MM Cobra Club #87
Old February 11th, 2010, 08:44 PM   #8
I have around 108k to 110k miles and idk if the guy b4 me has changed the clutch or not...how would I find out If it's an aftermarket clutch or not? And how do adjust it?
Old February 11th, 2010, 08:59 PM   #9
tfofkyle's Avatar
96 Mustang GT
tfofkyle will become famous soon enoughtfofkyle will become famous soon enough
theres no way to tell if the clutch is different other than taking out the trans and looking.
as for the adjustment, ill break it down into the 3 parts for you:
1. look underneath your dash above the clutch pedal. you should see a triangle looking plastic piece - thats your clutch quadrant. chances are if its not plastic - youve got an aftermarket quadrant that doesnt "click" when you pull up on the pedal and push back down. no aftermarket ones that i know of are automatically adjustable like the stock one is. with good reason too, because the stock one tends to bend and can even break if you shift too hard or fast causing missed shifts (ive experienced this myself)
2. jack up the car and find the clutch cable on the drivers side of the transmission. there should be a small rectangular box held on by one bolt. slide it off. dont breathe in the clutch dust - its a carcinogen. if you have a stock, nonadjustable clutch cable, the part where it slides into the clutch fork will be plain. if its adjustable, youll see two adjustment nuts on it. depending on the clutch cable, they usually allow you to tighten up or loosen the cable pretty easily.
3. lastly, pop the hood and look on the driver side firewall near the hydroboost unit. theres a black cable that runs into the firewall there. if it looks black and dull and plastic-y, once again, its probably stock and non-adjustable. if its some type of shiny, chances are its an aftermarket firewall adjuster. this also allows you to adjust the cable tightness, in much more preciseness than the cable underneath.
most people do an adjustable cable and a firewall adjust. they use the cable adjustment to make large adjustments and use the firewall adjuster to fine-tune it, so to speak. although some companies (maximum motorsports comes to mind) say that any aftermarket cables are junk and only ford oem cables are decent - leaving you only with the firewall adjust to set the cable.
personally i havent had the chance to experience my adjustable cable/billet quadrant/firewall adjuster combo from american muscle yet, as i jumped right into my npi head/pi cam/pi intake swap just before i got them in. but from the reviews, it seems if you dont have some type of aftermarket adjustment, it is an awesome difference in how the car drives and feels.
Old February 11th, 2010, 09:28 PM   #10
ok well i didnt see firewall adjustment, didnt see triagle thing above pedal, i pulled up on it and it didnt click....wtf do i do now? this car is starting to make me mad. Help!
Old February 11th, 2010, 09:40 PM   #11
ok well i did see a white plastic quadrant....any help? what do i do know since its plastic?
Old February 11th, 2010, 09:45 PM   #12
tfofkyle's Avatar
96 Mustang GT
is the clutch slipping? or making noises? or whats the deal with it? you say "worn out" but that can mean any number of things. if you've "overheated" it by banging through the gears more than a couple times, and its a stock, or organic style clutch, chances are youve glazed the clutch surface and its not engaging as hard as it did before. if it doesnt go back to normal after a couple hours cooling off completely, youve really messed up the clutch surface and are going to have to replace.
as for replacements, if youre on a budget like i was, and dont rag on your car too bad, go down to autozone or murrays or wherever and get a stock replacement kit. while youre there get a remanufactured flywheel (it was actually cheaper for me to do this than to have my stock flywheel resurfaced)
to ensure longevity of whatever you get, id suggest you get at the minimum an aftermarket quadrant (the triangle thing) and a firewall adjuster. that way you can easily adjust how it engages and the quadrant will ensure you dont burn up your new clutch due to a broken quadrant.
otherwise, if you wanna shop online, heres what id go with:
86-00 Mustang Sve Mongoose Clutch Kit, 10.5" 10 Spline For 5.0L & 4.6L at LRS - Same Day Shipping!
and
Mustang Clutch Adjuster Kit (96-04) at AmericanMuscle.com - Free Shipping!
without seeing the car in person, i cant really help much more...
Old February 11th, 2010, 09:49 PM   #13
ok well if i have the car in reverse and the clutch is pushed all the way in i would give it a little gas and it would make a klunking noise like it was engaging...also i will be rolling really slow and have the clutch pushed all the way in and i cant put it in gear it just scratches...also i start out in first gear sometimes it jumpes foward and backward...idk any help? if i do replace the clutch could i get a king cobra clutch andwith what kind of TOB? Also when i push it in it makes awierd noise but i think thats normal...kinda like a rusty hinge noise when u open a door....?
Old February 11th, 2010, 10:12 PM   #14
tfofkyle's Avatar
96 Mustang GT
lol none of that sounds normal at all. replace everything asap or have a shop do a clutch job for you. sounds like what happened when my tob went out on my stock clutch. and whatever clutch kit you get, use the regular ford oem throwout beaing.
Old February 11th, 2010, 10:24 PM   #15
ok thanks ALOT!! giving rep...so im thinking about getting king cobra clutch with stock oem TOB.....Will itwork?
Old February 11th, 2010, 11:32 PM   #16
ok well if i get this clutch... Mustang King Cobra Clutch Kit at AmericanMuscle.com - Free Shipping! with this clutch adjuster kit.. Mustang Clutch Adjuster Kit (96-04) at AmericanMuscle.com - Free Shipping! Would all that go together and would that be all i need? also would the TOB in that be ok since its a ford racing TOB?
Old February 12th, 2010, 02:10 AM   #17
LGHTNG02GT's Avatar
4V swapped '02 GT
(2v) 13.9@101
iTrader: 10 reviews
yep, those are what you are looking for. some will say to stay away from an adjustable clutch cable tho. i got one from Steeda and havnt had a problem with it. i would assume that because its a Ford Racing clutch, it would have a Ford bearing so you should be ok to use the one in that kit.
BSD 100MPH Club
YMR #8975
MM Nitrous Club #7
MM Cobra Club #87
Old February 12th, 2010, 10:28 AM   #18
tfofkyle's Avatar
96 Mustang GT
appreciated. youll love the new clutch. makes driving the car a lot more fun when everything works correctly lol.
Old February 12th, 2010, 11:05 AM   #19
Haha yea I bet am thanks alot, about am hour ago I was sitting at a red light and couldn't put it in gear...the people behind me were probaly mad lol...but I'm gonna go with the ford racing clutch kit and the cable
adjuster...
Threads Similar to: Clutch!!
Clutch noise? New clutch install mtbr101 99-04 0 December 8th, 2009 11:08 PM
Clutch Or Clutch Cable OR Shifter??? 96GtGoodz 96-98 21 July 27th, 2009 03:59 AM
clutch replacement- replace whole clutch assembly or just clutch disc? WilltheThrill 4V / SVT 12 December 13th, 2008 01:18 AM
CLUTCH AND CLUTCH CABLE MAJOR PROBLEMS Hububula 5.0 Mustangs 3 May 28th, 2007 11:08 AM
Getting My Clutch Quadrant, Adjustable Clutch Cable and 97Cobra 4V / SVT 3 May 2nd, 2007 03:33 PM
