#21 |
1998 GT suckaaa
4 tickets @ 1 stop
I put the car up on the lift, and saw some fluid dripping, I noticed it was white/purple. So I opened up my valve cover to check out how it looked under there... And it looked like I poured milk in instead of royal purple.
I don't really know where I can go from here. I already spent quite a bit on this swap. Idk.. Just didn't make for a good day I guess.
Military Crew
Completely stock... I promise. ![]() |
#22 |
Hooo Ha Ha
Calm down first. Deep breath.
First drain it all out. Just open it and get it all out of there. Then id grab some of the cheapest oil you can get and run it threw there a few times. Just to clean it out. Then lets work from there. Now is all of this after the pi swap?
![]() 374rwhp 456rwtq @ 8psi |
#23 |
1998 GT suckaaa
4 tickets @ 1 stop
yea it is
Military Crew
#24 |
Hooo Ha Ha
Are all your headbolts tight? Maybe a head gasket leak?
#25 |
1998 GT suckaaa
4 tickets @ 1 stop
I torqued them all, in the right sequence, and did the XXlbs, turn a 1/4 turn, undo one whole turn, Torque to XXlbs, turn 1/4 turn deal.
I didnt check the heads for flatness though.
Military Crew
#26 |
When the engine is cold and you start it up do you have air bubbles appearing in your radiator? This could indicate a blown head gasket that is leaking coolant when you shut your engine off and it cools off. Other possible causes are a crack in a head, cylinder liner or block. Did you ever overheat the engine severely? This may have caused a crack in the block or head. Remove the spark plugs after the engine has cooled and observe each cylinder If you are blowing a mist or coolant this would narrow it down to a head gasket or a head. Otherwise, you are f-----.
You have a cracked block
#27 |
96 Mustang GT
theres your problem. always always always at least have the heads checked to make sure you dont have to tear it apart again. my brother just went through a second head gasket on his taurus because when they replaced everything they didnt bother checking the heads at all. even the slightest scratch on the heads will be problematic. also, when installing, get as many sets of hands as you can and take your time positioning because scratching the head surface on a dowel can cause a similar problem. im having my npi heads which were freshly rebuilt (from the last owner) resurfaced one more time just to make sure theyre safe. i know how you feel about the swap. my engines down to the shortblock and i dont wanna do this again. lesson learned though.
#28 |
1998 GT suckaaa
4 tickets @ 1 stop
Im not losing coolant though. I was last week... like crazy, but now... its staying at a constant level.
Military Crew
#29 |
96 Mustang GT
#30 |
1998 GT suckaaa
4 tickets @ 1 stop
No not yet, I have to wait until the AutoSkills center on base opens up (tuesday).
And thanks! Ill take whatever compliments I can get on a car I cant drive!
Military Crew
#31 | |
13.64@101mph
1990 GT- 5.0L |BBK Shortys|VRS O/R X| SLP LM1 Catback|BBK CAI| Centerforce Clutch|MGW Short Throw| Alum D/S| 3.73's| Steeda Springs...about as stock as a 5.0 comes now a days..much more to come |
#32 |
1997 Mustang Gt
13.76 @ 102.5mph
the squeking sounds like the alternator. mine does the same thing after the pi swap. We put like a whole can of wd40 and it still doesn't go away...ehhh
Pi Heads, BBk Longtubes, 3.73 Gears, Mac pulleys, CAI, Short shifter, Intrax Springs 13.76 @102.5mph 14.0 @ 99mph npi 12.6 @ 108mph w/75shot
#33 |
95 & 97 GT
Just wondering, did you reuse the old headbolts? My car has no O2 sensors, they are off, not even connected, passes inspection every year, I guess my diablo chip is bad ass!
Your bogging down is from the water in the cylinders.
![]() 97gt Pi swapped, sreamin demon coils, taylor wires, diablo chip, cai, 3.73s. 9.3 in 1/8 with no traction. ![]() Boosted 95GT under construction. |
#34 |
95 & 97 GT
If Iam not mistaken I think I saw you are missing a clamp on your CAi by the maf. It will suck in air causing it to bog like that too.
#35 |
1998 GT suckaaa
4 tickets @ 1 stop
the clamp is there now, haha. I lost it... then found it the day after the pics/vids
Military Crew
#36 |
95 & 97 GT
You did use new headbolts right?
#37 |
1998 GT suckaaa
4 tickets @ 1 stop
oh hell yea. Spent 90 bucks on those damn things.
Military Crew
#38 |
96 Mustang GT
dont quote me on this, but look it up if you feel interested. but the factory style torque-to-yield bolts i believe can be retorqued up to 5 times total. from the factory they are torqued down twice (as per the ford manual) and can probably at least be torqued down another two times during a head swap. after the fifth time though, theyve stretched too far and need to be replaced.
#39 |
1998 GT suckaaa
4 tickets @ 1 stop
I'm going to quote you on that. Dont try and stop me.
Military Crew
#40 |
96 Mustang GT
Threads Similar to: Car is bogging down/ has little power (Videos)
| Car Bogging when hot | Ticket-Me-Yellow | V6 Mustangs | 1 | April 9th, 2009 09:44 PM |
| Couple Videos Of My Car | 9greeNotch3 | 5.0 Mustangs | 74 | December 17th, 2007 02:26 AM |
| My Car Is Still Bogging Out | 98 gt | 96-98 | 4 | November 15th, 2006 03:01 PM |
| Car Is Bogging Out | 98 gt | 96-98 | 5 | November 12th, 2006 10:07 AM |
| Videos Of YOUR Car | sAJ1420 | Multimedia | 43 | October 7th, 2006 01:57 PM |
