#21 | |
02 Mustang GT
#22 | |
13.64@101mph
you did the pi swap yourself..how hard is timing one of these things?
#23 | |
02 Mustang GT
#24 | |
13.64@101mph
#25 |
95 & 97 GT
I don't have a lift either, I just use jackstands and put the front wheels under the car for extra safety, and with my floor jack, some 4x4 blocks, got to it, within 1 1/2hrs had the k-member off, I have air tools, it is more intimadating than anything,I work on med duty diesels and they have so much crap in the way and I was still intimadated with my timing chains, but they aren't that bad, just put it at TDC mark your chains, but u will see they are already marked, then back the motor 45* counterclockwise, this is safemode, all the pistons are below the deck.
![]() 97gt Pi swapped, sreamin demon coils, taylor wires, diablo chip, cai, 3.73s. 9.3 in 1/8 with no traction. ![]() Boosted 95GT under construction. |
#26 | |
1996 GT Convertible
13.88@100.71
Also I knew I was pulling the motor this spring and was only going for the 1 summer without one. With the heads off you should have better luck getting it out, maybe.
![]() Mods: Katzkin Leather, MMR stage II heads w/PI cams, PI intake, Accufab 75mm TB & Plenum, CAI, Ram HDX clutch, Pacesetter LT's & X pipe, Pypes hi-flo cats, Flowmaster cat back,3.73 gears, Sct SF3 tuner, Mamba M2's |
#27 | |
1996 GT Convertible
13.88@100.71
PI Headswap Write-up The 2nd post in the thread deals with timing. ![]() There's a ton of links in there too.
#28 |
95 & 97 GT
Same here, that dipstick is a PITA lucky I had an extra one cause I also broke mine. All I can say is go for it and take it step by step, also what year are your heads from cause the timing cover uses thicker bolts, in a few spots like on top of the heads mine are from an 01.
#29 | |
13.64@101mph
#30 | |
13.64@101mph
#31 | ||
02 Mustang GT
^^ this is what im following as i do my swap.
#32 |
95 & 97 GT
When I did the other lt installs yea i disconnected steering shaft and dropped the kmember, it is the easiest way.
#33 |
13.64@101mph
its not much different underneath these from foxbodys right? cuz i put in a upr tubular set-up when i did the 408w in the last car..if im right its just disconnected the struts from the bottom, then its all the k-frame itselfs bolts from there?
so can i lift the nose of the car up as high as i can, then drop the k-frame down with motor attached as far as i need to be able to install the LT's..or does my driveshaft have to come off?
#34 |
02 Mustang GT
is disconnecting it strictly to gain room to tighten up the headers ? or do you actually have to disconnect it to fit the header down in there ?
#35 |
95 & 97 GT
When I drop the Kmember the motor is still up with my engine hoist and before I just used a floor jack with a piece of wood on the oil pan an a long enough 4x4 on the edge of oil pan in the front for extra safety. once you remove kmember it is a piece of cake, just remove all 13mm bolts from the manifolds, most likely you are going to have to remove the studs because the majority of them will not work with the headers. On the BBK longtubes you have to cut a piece of one of the studs on the driverside toward the firewall and use one of the stock studs on the first hole.
My first install I followed this guys write up . http://www.mikefordmustang.com/write.../index.html#23
![]() 97gt Pi swapped, sreamin demon coils, taylor wires, diablo chip, cai, 3.73s. 9.3 in 1/8 with no traction. ![]() Boosted 95GT under construction. Last edited by 4.slo?; March 4th, 2010 at 02:19 AM. |
#36 |
1998 GT suckaaa
4 tickets @ 1 stop
i attached the header to the head and slowly lowered the pair together down to the block with an engine hoist.
Military Crew
Completely stock... I promise. ![]() |
#37 |
02 Mustang GT
makes me feel a lot better!
#38 | |
13.64@101mph
thanks alot..thats probably one of the best write ups i've seen!
#39 |
1998 GT suckaaa
4 tickets @ 1 stop
im not sure it should. It was still a terrible time dealing with the drivers side. The passengers side was easy.
I thought timing this was easy though. It was real straight forward, and probably the easiest part in the whole ordeal for me.
Military Crew
Completely stock... I promise. ![]() Last edited by koessl; March 4th, 2010 at 03:22 PM. |
#40 | |
13.64@101mph
see im totally quivering in my boots over the timing lol...installing the headers not so much..idc about if it takes me 2hrs for one
Threads Similar to: longtube header install
| Longtube header question | ndfrspd | 99-04 | 4 | May 22nd, 2009 03:21 PM |
| Mac Longtube Header install | Srt2stang725 | 2005 - 2010 | 31 | April 2nd, 2009 11:26 PM |
| longtube header install question | russell16 | 99-04 | 5 | September 21st, 2008 02:54 PM |
| JBA Longtube Header Package!! | Derek@DRI | 2005 - 2010 | 1 | May 12th, 2008 01:03 PM |
| longtube header install time | thecloneranger | 2005 - 2010 | 3 | February 19th, 2008 12:37 PM |
