stage 2 cams
Old February 28th, 2010, 10:30 PM   #1
POWA! 24/7 fukkers
V8POWA!'s Avatar
1 @ 1
V8POWA! is a glorious beacon of lightV8POWA! is a glorious beacon of lightV8POWA! is a glorious beacon of lightV8POWA! is a glorious beacon of lightV8POWA! is a glorious beacon of lightV8POWA! is a glorious beacon of light
stage 2 cams
thinkin about getting these cams
Comp Cams Stage II Xtreme Energy XE270AH Camshafts (96-04 4.6L 2V) at AmericanMuscle.com - Free Shipping!
do i need everything they recomend? probably better to get it i assume....link some things i should get.
so what is the 2000 plus stall speed converter for automatic transmissions?
tuned computer?
and new valve springs?
thankss fellas. and what headers would be good.
Old February 28th, 2010, 10:56 PM   #2
BAD98GT will become famous soon enoughBAD98GT will become famous soon enough
yes u def need to get the valve springs and the tuner, the cams produce more lift than what stock spring can provide, therefor IF(highly doubtful), IF it dont mess anything up your engine will make a tapping sound which is the valve springs are being pushed beond its limits, and can break or cause damage to the heads/etc, and yes you will need a tuner also, cause ur computer has no idea what u have done to the motor, it will equalize your intake/exhaust, so it understands and can adjust for the mods u have done and get the max potential out of ur cams
Old February 28th, 2010, 10:58 PM   #3
im using the bbk shorty headers now, alot of people dont care for the shorty's they prefer the long tube headers, the long headers will produce a more deeper sound if im not mistaken.
Old March 1st, 2010, 12:47 AM   #4
POWA! 24/7 fukkers
V8POWA!'s Avatar
1 @ 1
ah ok. what is a good tuner to get...and valve springs. the long ones will be louder too then right..
Old March 1st, 2010, 12:51 AM   #5
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.99 @ 113.9mph
sharkbait is a splendid one to beholdsharkbait is a splendid one to beholdsharkbait is a splendid one to beholdsharkbait is a splendid one to beholdsharkbait is a splendid one to beholdsharkbait is a splendid one to beholdsharkbait is a splendid one to beholdsharkbait is a splendid one to behold
iTrader: 9 reviews
with cams youll need a dyno tune. Call around and ask shops what they charge. They normall will hook you up with the tuner and your tune at one time
374rwhp 456rwtq @ 8psi
Old March 1st, 2010, 01:06 AM   #6
POWA! 24/7 fukkers
V8POWA!'s Avatar
1 @ 1
wuts the stall converter? do i need one? how much do they run for?
Old March 1st, 2010, 01:10 AM   #7
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.99 @ 113.9mph
iTrader: 9 reviews
Stall convters.....
ok umm pretty much how they work, in your car right now... if its an auto... the transmission under 1800 rpm slips per say, then at 1800 and above the converter locks up and makes the connection between the trans and the engine solid. Putting a higher stall in lets you launch at a higher rpm, but also makes those lower rpms less usable.
This explanation is horrible and id recommend googling it.
I wouldnt really worry about the stall though, you have to drop the trans to install it
Old March 1st, 2010, 09:54 AM   #8
1996 Mustang GT Vert
Blower Head is on a distinguished road
A stall converter allows your engine to wind up higher before it really takes hold. So to choose a stall converter you need to determine the rpm you really start to make power to determine the correct stall speed. Before I got mine I called the company and they asked how my car was set up to determine the correct stall speed. A converter will run around $700 or so depending on the brand. As stated earlier you need to pull the tranny to install one.
96 GT vert, Aftercooled Vortech, Lightning MAF,42# injectors, saleen cams, Bullitt intake, tune by Hitech, Magnaflow catback and O/R xpipe, Cobra brake upgrade, lowered bilstein suspension w/MM c/c plates and subframe connectors 3000 stall and 3.73's
Old March 1st, 2010, 11:26 AM   #9
13.64@101mph
if im right comp cams sells beehive springs for $189.99 that can handle upto .550" lift and trickflow if im right for like $229 or something like that sells some beehive springs that can handle upto .600" lift..
whats the limit for the stock relief on these cars guys? im thinking at some point going cms stage II's
1990 GT- 5.0L |BBK Shortys|VRS O/R X| SLP LM1 Catback|BBK CAI| Centerforce Clutch|MGW Short Throw| Alum D/S| 3.73's| Steeda Springs...about as stock as a 5.0 comes now a days..much more to come
Old March 1st, 2010, 01:04 PM   #10
tfofkyle's Avatar
96 Mustang GT
tfofkyle will become famous soon enoughtfofkyle will become famous soon enough
ModularHeadShop Bullet Cams NA cams
cams for if you dont wanna mess with the stall, and ones for if you do
Old March 1st, 2010, 05:59 PM   #11
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all
iTrader: 13 reviews
Iv'e got a set of lightly used XE 278 AH cams for half that price if your interested just PM me.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old March 1st, 2010, 06:30 PM   #12
13.64@101mph
yeah but whats required with that big of a cam? im interested!
Old March 1st, 2010, 06:37 PM   #13
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
3.55 gears, intake, exhaust, spring upgrade, 2400 stall and you may need to have your pistons notched. You can have your pistons notched with the motor in the car though.
From the looks of what you have in your sig, you would just need the springs and to get your piston notched.
MODS IN GARAGE
NCMM ORIGINAL
Old March 1st, 2010, 06:38 PM   #14
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
Oh, they already have cam gears on them too.
MODS IN GARAGE
NCMM ORIGINAL
Old March 1st, 2010, 06:41 PM   #15
POWA! 24/7 fukkers
V8POWA!'s Avatar
1 @ 1
fuuck...i do not wanna pay 700 for that converter. and im not going to...
would i be good if i get gears and new valve springs? is there anything else that i need or should get with that cam
Old March 1st, 2010, 10:26 PM   #16
13.64@101mph
3:73s, pi intake, jlt cold air, lt's, cat x, slp lm1's, 5spd..
but as far as the pistons notch..anyone know what the legit relief limit is? these 278H's are the .550 lift right? cuz im going to do the comp beehives with it!
Old March 1st, 2010, 10:51 PM   #17
POWA! 24/7 fukkers
V8POWA!'s Avatar
1 @ 1
hey quit /thread jacking. this is my thread, gtfo.....
Old March 1st, 2010, 11:21 PM   #18
ujslost's Avatar
I suggest if you put the larger cams in to get the stall converter, do it right the first time. You can get a converter cheaper than $700 if you shop around
Old March 1st, 2010, 11:35 PM   #19
13.64@101mph
whoa whoa whoa lol who said he was really talking to you and not me..you wanted the dinky little 270h...cant handle the big guy! lmao
Old March 1st, 2010, 11:39 PM   #20
POWA! 24/7 fukkers
V8POWA!'s Avatar
1 @ 1
i know nothing about cams.....even sizes, thats why i am asking a question cause i dont know that a fucking big size is.....
Threads Similar to: stage 2 cams
hitech stage 2 or crower stage 2 cams? Boostang 96-98 2 March 15th, 2009 06:33 PM
BBR Stage 2, FRPP Hot Rod, Comp Stage 4 or Comp Thumper Cams ivan48humble 2005 - 2010 179 December 8th, 2008 03:19 AM
Thumper cams or Stage II SPR cams. 07stanggt 2005 - 2010 26 August 17th, 2008 08:42 PM
Comp Cams SPR stage 2 cams on the way!!! RStrick0352 2005 - 2010 10 August 9th, 2008 03:06 AM
