Oil Filter Housing
I have a 98GT. Is there a way to get the oil filter housing back on with the motor in the car? I cannot, for the life of me, get to that back bolt.
1998 GT suckaaa
4 tickets @ 1 stop
Yes, I've done it. I had to replace the gasket between the housing and the block. Let me tell you... it was a bitch. Took like 6 hours.
Good luck man..
Military Crew
Completely stock... I promise. ![]() |
95 & 97 GT
You have to unscrew the center part where the filter screws in it is a hex socket.
![]() 97gt Pi swapped, sreamin demon coils, taylor wires, diablo chip, cai, 3.73s. 9.3 in 1/8 with no traction. ![]() Boosted 95GT under construction. |
1998 GT suckaaa
4 tickets @ 1 stop
i dont remember doing that?
Military Crew
95 & 97 GT
mine had an oil cooler, his probably does too. Mine was cracked and leaking oil into the coolant, I just got a regular filter housing and sealed it real good, no problems ever since.
so all i did was bend a chinese wrench and it was easy after that. took awhile cause i could only do a quarter turn at a time.
Threads Similar to: Oil Filter Housing
| Type of oil and Oil Filter does my Mustang use? | horizontalkev | V6 Mustangs | 28 | June 8th, 2009 10:48 PM |
| Oil filter housing bolts? | 03_StangGuy | 99-04 | 2 | April 18th, 2009 08:26 PM |
| oil in spark plug housing | conrad | 96-98 | 2 | August 25th, 2008 09:48 AM |
| Will this STOCK AIR FILTER HOUSING WORK for 2004 V6 | warrior86 | V6 Mustangs | 4 | September 26th, 2007 12:09 AM |
| Taking off stock Air filter housing | RandoGT | 96-98 | 6 | August 3rd, 2007 03:20 AM |
