fuel pump keeps shutting off - Page 2
Old March 11th, 2010, 04:04 PM   #21
1998 Mustang GT
mike-oat is on a distinguished road
Send a message via MSN to mike-oat
The shop said they have checked the pats, the injectors, fuel lines, they said the car runs real good n carburator cleaner and that soemthing elctronically is telling the fuel pump to shut off every 1 min 30 Sec exactly
michael oatman
Old March 11th, 2010, 04:54 PM   #22
1998 Mustang GT
Originally Posted by jasons_98gt View Post
if you have stock fuel rails, there is a port you can hook a guage to and check your fuel pressure at the fuel rail....you should have about 20-30 psi with the key turned on, and the pressure should stay there until 15-30 min after you turn the key off. if you dont have pressure or the pressure fluxuates, the fuel pump is no good or you filter or the fuel lines are blocked, could also be the sending unit on the fuel pump. also check your inersia switch in the trunk.
had that happen before and the fuel pressure regulator was bad
got a fuel rail from a 97 with the removable regulator
any new news on the car yet?
michael oatman
Old March 23rd, 2010, 02:50 PM   #23
kingflirt1 is on a distinguished road
well i dont know anything about the newer mustangs but i had my 90 mustang gt for 13 years now and one subject never came about is the fuel pump relay, on my 90 is on the bottom driver side seat. hope it could be that and good luck
Threads Similar to: fuel pump keeps shutting off
Boost-A-Pump or GT500 Fuel Pump? stanglifemike 2005 - 2010 64 September 21st, 2009 02:17 PM
Fuel pump voltage and new fuel pumps? 03_StangGuy 99-04 1 June 19th, 2009 04:29 PM
Fuel pump question. Stock GT pump to GT (supercar) pump. Nate's4.6 99-04 15 May 14th, 2008 03:25 PM
Suggestions on Fuel Cell's & Fuel Pump bstang 2.3 Mustangs 5 January 21st, 2008 10:04 AM
fuel pump fuel pressure stuff JBIGBOOTSY 5.0 Mustangs 2 April 26th, 2007 04:31 PM
