1997 mustang gt
uknown
Vac Leak Help????
finally started my car today after sitting all winter fired right up after charging the battery. my car has been having idol issues for a while now but when i was looking at the car today my dad noticed that there were these 2 little tubes and one of them had split. it definitely is sucking air can feel it when i put my finger over it. does anyone know what this tube is called or where i can get it? its a really skinny small tube near the IAC valve. it goes from one to 2 small tubes. any ideas?
reducing coupler or "Wheys"
Hooo Ha Ha
use some tape....
and just bring it to autozone and be like i need this
![]() 374rwhp 456rwtq @ 8psi |
1998 GT suckaaa
4 tickets @ 1 stop
picture of said tubes?
Military Crew
Completely stock... I promise. ![]() |
1998 GT suckaaa
4 tickets @ 1 stop
reps for being wicked thorough.
Military Crew
1997 mustang gt
uknown
yea Thanks bad98gt that defenetly looks like it going to have to order that.
both of mine were broken as well.. and it made my hvac controls not work, and the idle was really messed up.. i just fixed them by finding rubber tubing..
are you talking about these babies?
![]() Cammed 2v Built By MustangMatt More mods than times your daughter has slept around |
1997 mustang gt
uknown
yah mine just idles from 500 to 1000 and its done it for a while and i looked everywhere found a leak fixed it and it was still doing it its just a tiny little tune that tore apart so hopefully this is going to fix the problem and im finally going to have a normal idle
#10 | |
1996 STEEDA
Highly Intelligent Modular Young Gun! Get off my D1 SON!! |
Rollin' 18/ pushin' 2
I used shrink tubing to fix mine.
1997 mustang gt
uknown
how did the shrinking tube hold?
pull the tube off an take it to autozone.
98 mustang gt bbk cai, bbk x pipe and 78mm bbk tb, steeda pulleys, pi intake, 4.10 Gears
an they gave me some tube for freeeeee!
nevermine i thot i was a different vac tube
It's been on there for about 3 years now with no problems at all. Just make sure you get one pretty close to the same size so it will hold tight when you heat it up.
1997 mustang gt
uknown
yea i actually got some heat wrap in the basement putting the car on the road tomorrow so ill let u kno how that works after. thanks for the help
1997 mustang gt
uknown
shrink rapped the line but still nothing i put a cold air intake on at the same time and checked all the other tubing and couldnt find the leak. im probably just going to go down to autozone and see how much all those lines are. and if that dosnt do it i honostly dont know what it could be
Threads Similar to: Vac Leak Help????
| What is this vac line for? | Hydration | 5.0 Mustangs | 20 | November 18th, 2009 01:21 AM |
| Finding vac leak. | nolife | 5.0 Mustangs | 19 | November 14th, 2009 08:11 PM |
| 90 GT vac lines | fastregalwe2 | 5.0 Mustangs | 5 | November 14th, 2009 01:15 AM |
| Shop Vac | JASonic | The Clubhouse | 16 | May 24th, 2008 09:28 PM |
| Evaporative Emission System Leak Detected (very small leak) | Juggalo_X | V6 Mustangs | 11 | April 25th, 2007 05:46 PM |
