#21 |
Hooo Ha Ha
Clogged injectors?
![]() 374rwhp 456rwtq @ 8psi |
#22 |
Smelly Fists, Socking Cocks
Millenium Falcon
where are they spraing the carb cleaner?
#23 |
Rollin' 18/ pushin' 2
I still say the problem has to be in your alarm system or your wiring. If your getting fuel, your getting air and your getting spark then it should run.
Don't you miss the ole' carburator sometimes?
#24 |
1990 MUSTANG GT
13.55 @100.64
might be something in the tank and its blocking the pick up tube... or an electrical problem.... if the cut off in the trunk is working then i would trace all wires and check current on those wires..
![]() 1993 Mustang GT(stock) SOLDhttp://s458.photobucket.com/albums/qq309/mpmarkv/ 1998 Mustang GT(sold):http://s458.photobucket.com/albums/qq309/mpmarkv/1998/ 1991 Mustang GT(sold)http://s458.photobucket.com/albums/q...v/1998/others/ [/SIZE] |
#25 |
It runs for a mintue then shuts off but they said if they spray carb cleaner it will keep running.. They didnt say where they was spraying it.
michael oatman
#26 | |
I would imagine they sparayed it into the intake at the throttle body.
#27 |
1990 MUSTANG GT
13.55 @100.64
check fuel filter, lines check the injectors.... its a process of elimination... all things related to it... but usually when a pump goes bad it just stops working so it might be electrical... prior to the pump... there are relays and fuses for them so check those too...
#28 |
The shop said they have checked all of that. If they dont figure it out by friday then im going to pull it out of the shop it is at now.
michael oatman
#29 |
the car was wrecked in the front but was fixed do you think that might have something to do with it
michael oatman
#30 |
The shop said they have checked the pats, the injectors, fuel lines, they said the car runs real good n carburator cleaner and that soemthing elctronically is telling the fuel pump to shut off every 1 min 30 Sec exactly
michael oatman
#31 |
michael oatman
Threads Similar to: 1998 GT Mustang
| 1998 mustang | brianstang | 96-98 | 25 | August 13th, 2007 10:58 PM |
| My 1998 mustang | Ccash00 | 96-98 | 2 | July 25th, 2007 11:07 AM |
