BBk shorty header problem
Old March 10th, 2010, 01:34 AM   #1
96 Frankenstang
jg42122 is on a distinguished road
I am trying to install some shorty headers, on my 96 gt, the drivers side went in fine, but the passengers side keeps getting stuck on the side of the car, and wont fit. Are their any write ups or documents online?
Old March 10th, 2010, 01:49 AM   #2
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.99 @ 113.9mph
sharkbait is a splendid one to beholdsharkbait is a splendid one to beholdsharkbait is a splendid one to beholdsharkbait is a splendid one to beholdsharkbait is a splendid one to beholdsharkbait is a splendid one to beholdsharkbait is a splendid one to beholdsharkbait is a splendid one to behold
iTrader: 9 reviews
use a hammer?
374rwhp 456rwtq @ 8psi
Old March 10th, 2010, 05:13 PM   #3
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all
iTrader: 13 reviews
I know sometimes you have to undo the motor mounts and jack up the engine a little bit to get the headers into place.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old March 10th, 2010, 06:52 PM   #4
96 Frankenstang
Yes but if I undo the motor mounts and jack it up won't that put the weight of the engine on the Headers when I sit it back down?
Old March 10th, 2010, 08:30 PM   #5
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
Are you saying the header will not fit in the space, or are you saying you cannot get the header into position? Once you have it in position and have the bolts in it should fit in the engine bay. If not, take a hammer to the point where it is making contact and "massage" the space to make it fit.
It can be a beeotch to get into position, but it really should fit. What brand are you installing?
MODS IN GARAGE
NCMM ORIGINAL
Old March 10th, 2010, 08:59 PM   #6
BAD98GT will become famous soon enoughBAD98GT will become famous soon enough
i have the bbk shorties and there is only an inch or so for space.(tight fit on pass side) unbolt the motor mount and raise a little bit, be careful on dropping it back down, it has like one spot where it will fall back into place, only with an inch to spare, use a lil elbow grease, it'll go!
Old March 10th, 2010, 09:22 PM   #7
96 Frankenstang
Thanks I am using BBK I have my headers off doing a head swap as well so I am trying to install them both as one piece, driver side went on fine, but the passengers side is where the trouble is.
Old March 10th, 2010, 09:24 PM   #8
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
Yeah, that's the hard side.
MODS IN GARAGE
NCMM ORIGINAL
Old March 11th, 2010, 12:03 AM   #9
jasons_98gt's Avatar
1998 mustang GT
jasons_98gt is on a distinguished road
Send a message via Yahoo to jasons_98gt
any luck yet? i put shorties on my car but didnt take the heads off went did it up from top when the engine was lifted had to finess her a lil but to lower it back down though
Old March 11th, 2010, 12:47 AM   #10
96 Frankenstang
I did not get to go at it this eveningbusy with work, Friday should be the day! How do you go about unbolting the motor mount
Old March 11th, 2010, 01:26 AM   #11
1998 mustang GT
look at the k frame you will see where the motor mounts are
directly below theres a bolt on each side undo the bolt and you can jack the motor up with a block of wood and carjack on the oil pan
Old March 11th, 2010, 01:37 AM   #12
JohnC's Avatar
1997 Mustang GT
13.56@102.94
JohnC will become famous soon enough
I installed mine out of the car like in 2005. If I recall correctly, I don't see how you can get to the lower/center bolts on the passengers side with the engine mount on anyway.
So if I am recalling right, I suggest removing the engine mount and/or even dropping the K.
I TQ'd every bolt I could, and tried my best to match the TQ load by hand on the ones I couldn't get my socket/TQ-wrench on. I don't have any header exhaust leaks and they've been on the car since 2005 and just over 22,000 miles.
1997 Mustang GT
Aluminum Block PI swap & 4R70W to TR3550 swapped.
Best 1/8: 2.04 60ft 8.74@81.85 &
Best 1/4: 2.045 60ft 13.56@102.94
all on stock 245-17's
My Garage
Threads Similar to: BBk shorty header problem
JBA Shorty header noise roopj 2005 - 2010 V6 5 August 3rd, 2009 01:35 PM
bbk shorty header ? riceburnin03 99-04 4 March 3rd, 2009 12:05 AM
Shorty Header Install njstang 99-04 6 February 18th, 2009 04:15 PM
Shorty Header ? 07vert 2005 - 2010 14 February 23rd, 2008 01:56 PM
