1997 Mustang GT - Roush
MAF swap
Alright so I just installed the trick flow 70mm throttle body/plenum combo the other day. I already had the K&N CAI, ford racing PI intake manifold, BBK headers, magna flow exhaust, pulleys, ect....anyways I was told I should upgrade my MAF before I send out for an SCT chip. I found one for cheap off a 93-95 cobra. Now would a ford racing 70mm MAF, bolt onto my 97 gt? and if it does, would my original sensor fit as well? or would I have to purchase the sensor that went with the 70mm MAF off the cobra? and lastly, would the 70mm MAF off the cobra work well with 19lb injectors or 24lb injectors?
93-95's had the 5.0 not sure if the mass air flow sensors are the same on 4.6's or not
Hooo Ha Ha
They wont work from a 93-95
The connecters will be different because ours cam with a temp sensor in the maf i think. Ours has 6 connects i think and they have 4
![]() 374rwhp 456rwtq @ 8psi |
apparently the 5.0 one will hook up fine, I guess my real question is about the sensor. is my stock 4.6 sensor fine, or would I have to use the 5.0 one?
!FACEPLATED!
You should be fine with the stock MAF and injectors so far
![]() MM Bracket Racing Crew Co-Founder ~Its a Drag Car, Not a Show Car~ |
Threads Similar to: MAF swap
| Which one is easier??a rear end swap or engine swap? | Bies08 | V6 Mustangs | 42 | May 11th, 2010 05:33 PM |
| MAF swap | SWEET2KSTANG | 99-04 | 44 | September 19th, 2009 02:47 AM |
| A little MAF swap help? | Ryan Paymaster | 4V / SVT | 2 | August 15th, 2008 01:31 PM |
| SVO - Vane to MAF Swap | sudo95 | 2.3 Mustangs | 6 | January 24th, 2008 06:48 PM |
| maf electronics swap | usmcsawgunner | 5.0 Mustangs | 1 | December 24th, 2007 02:18 PM |
