P0171 Error after pi intake and o/r h pipe
Well, I finally need to ask for some information that I haven't been able to find on the site. I have been surfing this site since I bought my Mustang 4 months ago and have found so much useful information. I want to say thank you for all of that before I ask my question!
I just did the pi intake swap and switched to a catless H pipe all at the same time. The install went perfect and everything worked out. But Unfortunately I now have a check engine light the code is P0171 saying the system is lean Bank 1. I used a fix for the rear o2 sensors to pull them out of the exhaust so that will not throw a code. The engine scanner is saying that the catalyst system is within efficiency so I dont think that is the problem. And I dont understand how it would be the upper o2 sensor. Any help would be appreciated, if there is anything else needed please let me know. Thanks!!! |
what did you do to the rear o2's? did you use mil eliminators? or leave them out of the exhaust pipe?
The rear o2 sensors are in spark plug non foulers. They just pull the sensor out of the stream of exhaust so that the air is only slightly blowing over it. Seems to work well so far
haha just noticed your from pittsburgh too!
oh shit what part you from? your intake isnt sucking air anywhere is it?
recheck your front o2's i had one break on me one time and i was getting that code by breaking i mean where the metal tip with the wires goe into the part that threads in wiggle that back and forth if its loose replace it |
I live right outside of washington. Where you from? Also one is wiggling but it is th back o2 on the opposite side. and I dont think it is leaking all fresh gaskets and torqued properly.
on the northside. not far from 3 rivers. Did you drill and tap that hole for the coolant sensor near the thermostat housing? although that will give a different code but just though id through that in there. I would say recheck your O2 connections and see if theres something you missed somewhere
yep drilled and tapped them, and im familiar with the northside, I goto Pitt. Might be living in the northside next year. And ya I tapped the coolant sensor in. I am gonna recheck the sensor connection, but it isnt throwing an o2 sensor code. Supposedly the car was chipped when I bought it. I am wondering if the chip is leaning out the mixture and thats the problem?
hmmm never had that happen before but its possible
yeah i noticed you said a lean code, thats why i was thinking maybe a vacuum line or something may have got missed how the car run otherwise? |
Ya that is what I thought, I think it may be vacuum but the lines are all connected. I am going to check again for any vacuum leaks. And the car is running like a bat out of hell. So much better. The only problem is that it is much slower to return to idle. I figure this is because of the increased air flow and the lack of back pressure in the exhaust system.
1998 Mustang GT Vert
Was just reading and noticed you two were from pittsburgh lol. I am also from around the area, i live in West Mifflin right by Kennywood Park. But during the week i live on campus at Duquesne University. Small world eh? lol
98 GT conv. LT headers, Mac prochamber w/ high flow cats, BBK 78mm TB, FRPP pullies. FRPP 4.10's. Flowmaster cat back. CAI. SCT tune w/93 octane race tune. Next: PI Intake with MHS stage III ported PI heads/Stage 3R Bullet Cams (waiting on install) |
Pittsburgh REP!
gotta love pgh... not solving my problem lol but still awesome. Maybe sometime we can all meet up somewhere, nice little pittsburgh mustang gathering! Fix my error! lol
true...its one of those things its hard to figure out without looking at it
Oh lol I wasnt saying meet up so you can fix my error! I am gonna try to have that done tomorrow! I meant just chill or go cruise or something!
Well, no vacuum leaks in the engine compartment. It sounds like something may be leaking inside the cabin coming from the heater system, there is a high pitched suck every time you touch the gas. I dont think that is causing the code though. I cleared it and am going to see if it comes on again. If anyone else has any suggestions i appreciate it.
1996 Mustang GT, Underdrive pulleys, BBK cold air, PI intake swap, O/R H pipe, Borla Cat back, lowered 2 inches |
95 & 97 GT
You have a vacuum leak, check your lines that go to your a/c heater control, those lines go to the engine. That will throw P0171 it is getting unmetered air and the ecm is not compensating for it.
![]() 97gt Pi swapped, sreamin demon coils, taylor wires, diablo chip, cai, 3.73s. 9.3 in 1/8 with no traction. ![]() Boosted 95GT under construction. |
Well it seems as if that code has fixed itself. I don't know what it was maybe just a hiccup from the whole install of everything. The only trouble now is passenger side downstream o2 is throwing a code. That is from me breaking it when installing the spark plug nonfoulers. They cause the two o2 sensors to hit into each other. Does anyone know of any part that move them offset. I know this is a vague and confusing statement but I think someone has had to run into this before
Threads Similar to: P0171 Error after pi intake and o/r h pipe
| P0171..p0420... | Cesar2cool | 99-04 | 2 | January 5th, 2010 06:20 PM |
| Acceleration Issues - P0171 | cgyarring | V6 Mustangs | 3 | November 16th, 2008 07:54 PM |
| code P0171 | bbrewer03 | 96-98 | 6 | December 2nd, 2007 07:52 PM |
| P0171,P0174 | Clay | 99-04 | 4 | October 2nd, 2007 06:58 PM |
| p0171 code | 96gtponyred | 96-98 | 7 | August 24th, 2007 01:03 AM |
