battery relocation
Old March 20th, 2010, 10:53 PM   #1
zigbigadoru's Avatar
97 Mustang GT
slower than the speed of smell
zigbigadoru will become famous soon enoughzigbigadoru will become famous soon enough
battery relocation
okay so im trying to finish up my battery relocation, among other things, and i need to know some things to get. i bought a "kit" from a member on here but he screwed me out of the major parts, ie the cables and stuff to actually hook it up.
i THINK i have all of the other hardware to bolt it onto the car (not 100% on this) but if someone could give me some idea as to the other parts i need to finish this up would be helpful.
i know i need a positive and negative wire, as well as a connector for the battery and the positive wire to hook up to. also need a thing to connect the negative wire to and then bolt? the thing to the car so it completes the ground. i would really like to know which wire is ok to use and which connectors and whatnot to use. for example 2#, 1#, 1/0, 2/0, etc etc.
this website has a bunch of cables and attachments that i think would help me complete it but im just not 100% on the ones i need to order. https://weldingsupply.securesites.co...:4:UNDEF::::PA
Originally Posted by XTCNAGT View Post
That's what you get for excercising.
You think my lungs and chest hurt when I drive down the road for a triple baconator? No. You know why? Cause I'm smart.
Time for a nap.
Old March 21st, 2010, 03:13 PM   #2
97 Mustang GT
TTT
Time for a nap.
Old March 21st, 2010, 07:27 PM   #3
koessl's Avatar
1998 GT suckaaa
4 tickets @ 1 stop
koessl will become famous soon enoughkoessl will become famous soon enough
I've heard of people using the welding cable instead... not a bad idea.
I would use the 1/0 gauge. Its rated for quite abit more current than you'll need. But it also is big enough to counter the added resistance that you'll get from using the longer cables.
Military Crew
Completely stock... I promise.
Old March 22nd, 2010, 12:40 AM   #4
97Dustang's Avatar
97 GT and 03 Cobra
12.75@105
97Dustang will become famous soon enough
a lot of people just use speaker wire.
2003 COBRA FOR SALE PM FOR DETAILS
Old March 22nd, 2010, 12:48 AM   #5
koessl's Avatar
1998 GT suckaaa
4 tickets @ 1 stop
I wouldnt want to have to rely on speaker wire to carry that kind of current that far.
Military Crew
Old March 22nd, 2010, 01:14 AM   #6
97 Mustang GT
ok do you guys have any other suggestions for wires? i just assumed those welding wires would be good and it would have all the neccessary parts to go with it but if you guys have something better im all ears.
Time for a nap.
Old March 22nd, 2010, 12:46 PM   #7
Proud American
MustangMatt96GT's Avatar
I used welding wire on mine... go to a welding shop and get 1/0 wire....
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
Never Lift Racecars
Old March 22nd, 2010, 02:32 PM   #8
97 Mustang GT
for both positive and negative terminals? what about the connections/connectors? positive? negative?
Time for a nap.
Old March 22nd, 2010, 06:43 PM   #9
Proud American
The welding shop should have ring terminals that fit each guage wire... thats what i did on the one ends and then on the other end I put it on the battery post... remember if you are going to go to any drag strip you will now need a shut off switch and you will have to run a wire from the alternator back to the battery and not to the fuse box..., that way the car will instantly die when you hit the kill switch.
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old March 23rd, 2010, 12:41 PM   #10
97 Mustang GT
check. i dont think i will do that in the begining but at some point i will. ok ill check it out
Time for a nap.
Old March 24th, 2010, 05:29 PM   #11
97 Mustang GT
ok welding shops are hella expensive. like 2x what that website is, so my question is how much wire will i need? 20ft? 25ft? 15ft? and what gauge should i go with? 1/0? 2/0? 2#?
Time for a nap.
Threads Similar to: battery relocation
battery relocation Codeman V6 Mustangs 67 February 24th, 2010 11:27 PM
Battery relocation itschristorres8 Audio/Video 1 November 9th, 2008 07:13 PM
Battery Relocation F8L GT 99-04 7 October 11th, 2008 01:19 AM
Battery Relocation ThreeHonks302 5.0 Mustangs 4 February 28th, 2008 08:47 PM
Battery relocation whitemustang02 Audio/Video 2 February 20th, 2008 12:39 AM
