1998 Mustang GT
N/A
PI Heads
I am looking at putting my newly ported with stage 3 cams into my 98gt but was wondering how hard the swap is with not pulling the motor and if any one could send are give me a link to a sight that I can get the cam gear holder so I do not have to retime the hole thing.
![]() Then there was one. |
Timing isnt that hard and you have to take the front cover off to get the head off anyways. I did it with the engine in the car and didnt have any problems.
1998 GT suckaaa
4 tickets @ 1 stop
Wait, do you have these aftermaket cams in a set of PI heads that are going on your NPI motor?
Or are you PI swapped and just want to swap your cams now? edit: I just looked at your garage, no reference to PI heads.... soooo Yea, youll have to pull the front cover and timing components to do this. Dont worry about the extra tool. That would be nice if you were just putting in cams, but thats not the case. It would be a waste of money, timing these things are easy.
Military Crew
Completely stock... I promise. ![]() Last edited by koessl; March 24th, 2010 at 02:27 PM. |
1998 Mustang GT
N/A
Hey sorry guys eben gone for a bit. I have the pi heads and I am putting the stage 3 cams in them. I do not habe them in the car just yet planning on the port and poliss atm with patriot sping kit. What would you say i would gain out of the full swap i have the intake on there atm just not the heads with the cams i want. I figur i would at least get 60-70hp is that about right? The flow is supost to be something like 285 after ported that is what they stated at least is that about right?
1999 Mustang GT
You should really check valve to piston clearance with those cams and flat top pistons.
1998 GT suckaaa
4 tickets @ 1 stop
Supposedly you should pick up a nother ~40 by use of stock PI heads/cams. I have no idea what effect your "stage 3" cams will do.
who makes the cam?
Military Crew
Completely stock... I promise. ![]() |
May want to look into notching the pistons for valve clearance, don't want them valves tappin the pistons, as far as the head swap, pretty easy, the only problem i had was the oil dipstick tube, good luck....
1998 Mustang GT
N/A
will be comp cams and how will i be able to check for the clearances it is just stock pistons and stuff so not sure thanks for the help guys.
2001 Cobra
14.2@102 (I suck)
stick a breaker bar on the front crank pulley and turn it around at least 4 times and if you hear your valves getting broken then you got a problem lol
![]() 2001 Cobra with SRA swap, modded for twisties ![]() MM Cobra Club Member #76 |
1996 mustang gt
13.07@104.66
you will have ptv clearance issues with stage 3 cams even stage 2 have ptv issues the must be degreed correctly
Threads Similar to: PI Heads
| GT 40 X Heads. Need Help Deciding On These Heads, Or AFR`s | BillR1970 | Parts | 8 | May 12th, 2009 09:01 PM |
| 351W heads vs gt40p heads? | mustangsoldier | 5.0 Mustangs | 16 | December 10th, 2008 11:00 PM |
| GT40 heads vs GTP heads | 99TurboV6Stang | 5.0 Mustangs | 9 | September 18th, 2007 09:34 PM |
| RHS heads , are they good cylinder heads? | hitorx | 5.0 Mustangs | 25 | May 12th, 2007 09:55 PM |
| Boss 302 Heads Same As Cleveland Heads? | ken5_0 | Classic Mustangs | 8 | September 25th, 2006 03:18 PM |
