OBD 2 Laptop PC Software for ABS and Airbags?? - Forums at Modded Mustangs
post #1 of 13 Old April 7th, 2010, 04:27 PM Thread Starter
RacingRyan's Avatar
Question OBD 2 Laptop PC Software for ABS and Airbags??
Hey, so I bought a OBD 2 plug with a USB jack on the other end that plugs into my laptop. It works very well with the free software, it tells me my check engine light codes and RPMs and blah blah blah. I found software online for like $200 that can check into the engine more and tell me why my ABS light is on and reset my airbag module. But is there any free or cheaper software??
Also I would like to download it so I won't have to wait for shipping if possible...
RacingRyan is offline
post #2 of 13 Old April 8th, 2010, 11:45 AM
Trick Tuners's Avatar
I'm not sure that the abs and air bag circuits are controlled or resetable by the ecu. My guess is that there is a circuit that tests those circuits to determine they are functioning correctly. If you cure the problem, you will clear the code. If i had a abs code, i would check the fuses, and the signal wheels at each tire.
Trick Tuners is offline
post #3 of 13 Old April 8th, 2010, 09:27 PM Thread Starter
RacingRyan's Avatar
Well I'm 100% positive that the ABS and Airbags are controlled by the OBD 2 plug because I talked to a Ford dealer guy.
Also, this ebay software says it can communicate to the ABS and Airbags through the ODB 2 - USB plug that I have... I just don't want to wait for shipping and I would like it free is possible?
COMPLETE CAR DIAGNOSTIC TUNING SOFTWARE OBD 1 & 2 : eBay Motors (item 120550397487 end time Apr-29-10 00:48:59 PDT)
post #4 of 13 Old April 11th, 2010, 04:14 PM
where did you get this said cord that connects your obd2 to your labtop?
link?
ForestGRN_Ghost is offline
post #5 of 13 Old April 11th, 2010, 11:23 PM
Thumbie's Avatar
yeah then I can roll around and pretend to be fast and furious
2001 Cobra with SRA swap, modded for twisties
1997 BMW M3 Sedan 5-Speed
2000 Porsche 911 Carrera
^All sold
Current: 2006 4Runner V8 SportEdition4WD, 1968 Chevelle SS 396 4-Speed
MM Cobra Club Member #76
Thumbie is offline
post #6 of 13 Old April 12th, 2010, 11:01 PM Thread Starter
RacingRyan's Avatar
Well the OBD 2 to USB cable is off of ebay here:
OBD-II OBD2 Car Code Reader USB Interface EOBD CAN-BUS : eBay Motors (item 260401756768 end time Apr-23-10 19:14:45 PDT)
It works really well for me and is pretty high quality. If you have the right software it can do anything.
post #7 of 13 Old April 13th, 2010, 04:48 AM
zigbigadoru's Avatar
and the program that you use with this cable?
Originally Posted by XTCNAGT View Post
That's what you get for excercising.
You think my lungs and chest hurt when I drive down the road for a triple baconator? No. You know why? Cause I'm smart.
Time for a nap.
zigbigadoru is offline
post #8 of 13 Old April 15th, 2010, 02:23 AM Thread Starter
RacingRyan's Avatar
Just the free program that came with it... It's called OBD 2 scanner I think.
post #9 of 13 Old July 3rd, 2010, 12:50 AM
Hello, this is my first post here. I registered here to ask Ryan if he has found some software for the pc which will read ABS codes and maybe Airbag codes?
I have a jeep which needs abs repairs but need software which will read abs to pull the code.
Thank You for the help.
Turbo1002 is offline
post #10 of 13 Old July 5th, 2010, 08:53 AM
TTT
post #11 of 13 Old July 5th, 2010, 11:34 AM
You should register on a jeep forum for better help. I will tell you this though, if your airbag light is showing up on your jeep, it's probably a bad clockspring.
Perfectcircle is offline
post #12 of 13 Old March 8th, 2011, 08:32 AM
Send a message via Yahoo to finally03gt
Any body ever find software, I'd even be willing to pay for it, just want to know it works.
'03 GT Auto-BBK CAI,FRPP 3.73 Gears,SCT 4-bank chip
Cobra Calipers, 13" dimpled/slotted rotors & SS front lines,Eibach Pro Springs and Dampers,SR CC Plates,SR RLC,Prothane bushing kit,MM pan hard (not on yet),17x9 Silver Bullitt Wheels
finally03gt is offline
post #13 of 13 Old April 29th, 2011, 07:39 PM Thread Starter
RacingRyan's Avatar
^ You probably already found something by now but what I ended up using and still use today is the scantool.net software called ScanXL Professional. There are also free versions from torrents if you know what I mean.
Human Verification
LinkBack to this Thread: http://www.moddedmustangs.com/forums/96-98/160278-obd-2-laptop-pc-software-abs-airbags.html
OBD 2 Laptop PC Software For ABS And Airbags - Webfinder.hol.es This thread Refback December 6th, 2014 06:03 PM
Thread OBD 2 Laptop PC Software for ABS and Airbags?? | Forums at Modded Mustangs | BoardReader This thread Refback March 2nd, 2012 06:26 PM
Thread OBD 2 Laptop PC Software for ABS and Airbags?? | Forums at Modded Mustangs | Page 2 | BoardReader This thread Refback January 10th, 2012 03:17 PM
Thread OBD 2 Laptop PC Software for ABS and Airbags?? | Forums at Modded Mustangs | BoardReader This thread Refback December 7th, 2011 12:45 PM
obd abs software - forums post summary | BoardReader This thread Refback September 5th, 2010 12:09 AM
obd software - online conversations | BoardReader This thread Refback September 5th, 2010 12:05 AM
