2003 Mustang Gt
Slow
![]() iTrader: 2 reviews
Drag time
what are you 96-98 mustang gt's running at the quarter mile? with a good set of street drag radials and bolt ons?
409rwhp at 4500 rpms.Vortech V1 Intercooled,kurgan motorsports powerpipe, 3.12 pulley, all Mac Exhaust,Sct Tuner,Bolt Ons,Cobra Brakes,MM cc plates,Vis 2000 cobra r hood,MGW shifter,Strange 31 Spline axles,Eaton Possi |
1994 Mustang GT
a good bolt on npi GT with good tires and good driver should go around 13-14 depending on exact mods...
![]() 1998 Mustang GT- SOLD 2000 Jeep Wrangler 4" lift, Locker, Ford 8.8 and a shit ton of other junk- SOLD 1994 Mustang GT-306, E303.....
2003 Mustang Gt
Slow
npi? perfomance intake manifold? what if i ported and polished my heads?
Hooo Ha Ha
Youll be in the 14s.
Im boosted and running 13s all npi motor
![]() 410rwhp 520rwtq @ 12.9 psi |
1994 Mustang GT
npi (non performance improved )=1996-1998 mustang gt cams, heads, and intake then ford made PI ( performance improved) Heads, cams, and intake
Granny Shifter
Bolt on, npi's have been known to do mid to high 14's at 5800feet above sea level.
02 Mustang GT
a typical bolton, coupe, 5 speed, full weight, full npi car will go about 14.2 at sea level on street tires if it has the driver mod.
2003 Mustang Gt
Slow
i ran 16's with underdrive pulleys bolt ons and 4.10 gears. with big ass tires on the back. i was spinning sideways in 3rd gear tho
i didnt wanna do a burnout cause the tires are 400$ a piece
2001 Cobra
14.2@102 (I suck)
that means you REALLY have the wrong tires lol. The fastes i got mine was a 15.4 but i have like no mods...and my driver is in need of serious upgrades (yeah, i not the best)
![]() 2001 Cobra with SRA swap, modded for twisties ![]() MM Cobra Club Member #76 |
02 Mustang GT
you need at least a decent summer-only tire with 4.10s. i have to be surgical on my launch to not spin everything to the ground even with some extreme summer 255/45 meats (essentially nitto 555 knockoffs) and my 4.10s. and thank you for being honest thumbie, a lot of people arent willing to admit that. fwiw, the best drivers are also the worst on their trannies, and (like me) are probably going to have to replace or rebuild them a lot sooner than a less hard driver.
2003 Mustang Gt
Slow
i got 275/40/17 in front and 315/35/17 in rear and still couldnt grip shit. i even did a little burnout. it almost got totally sideways every time i hit second gear. and first gear wouldnt even go anywhere....
2001 Cobra
14.2@102 (I suck)
doing a little burnout helps a little no matter what tire you got. Those 10 second standstills however....save for drag radials. and dont drive through the water. and holy jesus 315 is a FAT tire
I ran 14.8, 14.85, and 14.93 bone stock. Have not been back to the track since the bolt-ons.
1996 mustang gt
13.07@104.66
i ran 14.704@94.32 with a 2.18 60' with bfg drag radials
02 Mustang GT
sounds like youre running something cheap. if its above 60* out, my 255's hook just fine, albeit burning half of 2nd gear off if i powershift, and a huge bark into 3rd.
2003 Mustang Gt
Slow
well i think it may be my driveshaft. when i put it on a lift there is loads of play in it. i can move it up and down. and it makes shitty sounds when driving
Bringing Yellow Back
i would fix that before you drag race, that could cause a huge acident, think if that fornt joint broke at 80mph and dropped down and jammed in the track it would either destroy the car and or flip you over lol. i would take car of that
![]() SOON TO BE 5.4 3V POWERD WITH A ROUSH CHARGER HELPING IT ![]() BAMA Performance Drag Team Member #4 |
1997 Mustang GT Conv.
14.7@92
I ran a 14.7 on some Nitto's, 4.10's, pulleys, BBK 78mm Throttle body and intake plenum, and the SCT Livewire.
Threads Similar to: Drag time
| Drag time | Danderson | 99-04 | 11 | February 16th, 2010 12:30 AM |
| First time at the drag strip... | Markac | 99-04 | 26 | October 20th, 2009 02:50 AM |
| Going to drag for the first time | Firaga | 5.0 Mustangs | 10 | July 12th, 2009 02:29 AM |
| V6 drag time | RedDevilGT | V6 Mustangs | 46 | March 25th, 2009 12:34 AM |
| first time drag racing | Toph6888 | Drag | 2 | April 16th, 2008 09:02 AM |
