Oil pressure?
Old April 8th, 2010, 01:12 PM   #1
red01's Avatar
red01 is on a distinguished road
Oil pressure?
just wanna make sure that my new motor is holding good pressure, not sure where it should be. At idle it holds around 25-30psi, cruising down the highway it sits around 65psi. when I go wot it will hold around 80psi and stay there as long as I shift quick, if not it will fall by maybe 1 0r 2 psi. Is this good pressure? im running 5/30.
1997 Mustang GT
04 PI 2V, bolt ons, gears, tune
255/292
www.covertmotorsports.net
Old April 8th, 2010, 08:13 PM   #2
jasons_98gt's Avatar
1998 mustang GT
jasons_98gt is on a distinguished road
Send a message via Yahoo to jasons_98gt
cold pressure on mine is 80lbs
engine hot at 1500 rpms its around 42
engine hot at 2000-2100 its about 62 lbs
at idle hot is about 12lbs (stop n go traffic)
rule of thumb 10 psi for every 1000 rpms
you should be just fine
Old April 8th, 2010, 08:14 PM   #3
13.3 @107 2.1 on street tires
will2045 is on a distinguished road
Send a message via AIM to will2045
sounds good to me
Old April 9th, 2010, 09:32 PM   #4
BAD98GT will become famous soon enoughBAD98GT will become famous soon enough
96,97,98 v8 - 20-45 lbs at 1500 rpm
96,97,98 v6 - 40-60 lbs at 2500 rpm
Old April 10th, 2010, 08:38 AM   #5
red01's Avatar
Sounds about right but I have a 04 PI motor,,,,any difference there?
1997 Mustang GT
255/292
Threads Similar to: Oil pressure?
No Oil Pressure !! ridebmxfbm 5.0 Mustangs 8 June 23rd, 2009 09:55 PM
Need Help with Oil Pressure RaceRelated 5.0 Mustangs 12 June 18th, 2009 12:14 AM
oil pressure yamaharider531 5.0 Mustangs 20 March 27th, 2009 02:57 PM
Oil Pressure... puppynut5 Classic Mustangs 7 September 12th, 2008 08:43 AM
oil pressure skid6 5.0 Mustangs 3 August 10th, 2007 11:50 AM
