1996 MUSTANG GT
Cookie Needs Help! :)
Hey Y'all!! I Hope ya can help me.
When I was given my LIL' Red Addiction, my Cherry Pie I noticed the odometer & of course the tripometer was not working, so who cares- right? Well the other thing I noticed ( besides the fact that the entire front end needed rebuilding) was that when I put foot to ass at 40mph she would make a THDTHDTHDTHD sound (roll your tongue). Of course this is when OD should kick in, and she seemed to be catchin' Well now either OD is permanently on, or gone for good...so is the sound... Diagnostics, suggestions, & experiences accepted.... Just please don't hijack I wanna figure it out, and get 'er tight! ![]() Thanks Y'all!!
“I feel sorry for people who don't drink. When they wake up in the morning, that's as good as they're going to feel all day.” ~Frank Sinatra
only does it around 40mph??? check your trans fluid, change the filter. are you sure the ththththththt was coming from the trans?? if so it could of been a solenoid that got stuck.
Rollin' 18/ pushin' 2
I am having the same problem with the odometer in one of mine. The speed sensor sends a signal to the odometer and I was told that could be it. I checked it out and everything looks fine on it so I am going to swap it with one from one of the other cars that I know works. If that still doesn't fix it then ican rule that out. There is also a worm gear inside the cluster that goes bad and there is a kit to replace it. I didn't think it was that because I swapped out the cluster and still had the problem. Unfortunately, I got the replacement cluster off ebay so i can't be positive it worked on the replacement.
1996 MUSTANG GT
yeah I figure I have to get into the cluster
I REALLY hate that crap!! I don't think that has anything to do with the overdrive though...
1997 Mustang GT
N/A
Most likely the worm gear in the speedo for ur trip problems. Expensive lil bastards too. $25 a gear
I would imagine the two are totaly unrelated problems.
Threads Similar to: Cookie Needs Help! :)
| LMAO Cookie Monster with Rammstein | dr.gonzo! | The Clubhouse | 1 | January 9th, 2010 01:58 AM |
| Rammstein VS Cookie Monster | sickfox | The Clubhouse | 13 | December 9th, 2009 02:58 PM |
| fourtune cookie | White Thunder | The Clubhouse | 19 | July 10th, 2008 01:57 AM |
