4.6 truck motor
Old April 20th, 2010, 11:53 AM   #1
jasons_98gt's Avatar
1998 mustang GT
jasons_98gt is on a distinguished road
Send a message via Yahoo to jasons_98gt
4.6 truck motor
i was looking around on craigslist & come across a 4.6
for 150 bucks out of a 97 f150. It has almost 200k on it, has a leaking head gakset.
It has an 8 bolt flywheel, also was mated to a standard trans. Im thinking about buying it and freshen up the bottom end. Where can i find an 8 bolt auto flywheel, Im also guessing this is a windsor motor?
thanks
4.6 ford engine
Old April 20th, 2010, 09:45 PM   #2
1998 mustang GT
engine better work the guy sold it to me for 125 with delivery and found an 8 bolt auto flexplate.
so i will have a project here dissemble, and have some machine work done
Old April 20th, 2010, 09:55 PM   #3
96 gt
schardbody is on a distinguished road
isnt an 04 mach 1 crank 8 bolt? I think thats the flexplate most are using...
Old April 20th, 2010, 11:32 PM   #4
1998 mustang GT
i believe so,,nodular iron with autos and forged with standards
Old April 20th, 2010, 11:33 PM   #5
1998 mustang GT
i tore the pan off tonight, just to fiddle around and do a little inspection pretty clean inside looks like its been maintained for the most part head on the right side is warped some, probably where the leak was coming from.
Threads Similar to: 4.6 truck motor
2000 v6 motor change to explorer 4.0 motor v6must742 V6 Mustangs 29 May 25th, 2009 05:03 PM
How much boost can you put on a stock 4.6 v8 motor with out mesing up your motor? Jonathan General Tech 3 January 2nd, 2008 09:34 PM
need some help american motor to import motor wadepetersen V6 Mustangs 29 May 30th, 2007 09:26 AM
How do you find the motor code on a 88 5.0L motor? semihemi428 5.0 Mustangs 1 March 16th, 2007 04:56 PM
