EVAPORATIVE EMMISIONS CONTROL FAULT???
Old March 11th, 2007, 11:30 AM   #1
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all
iTrader: 13 reviews
I HAVE A 1997 SALEEN S281 AND HAVE BEEN HAVING PROBLEMS WITH THE CHECK ENGINE LIGHT. WHEN I GET IT READ IT SAYS" EVAPORATIVE EMMISIONS CONTROL MODULE FAULT". I HAVE REPLACED THE EEC VALVE, AND THE CHARCOAL FILTER BUT STILL GET THE LIGHT. WHAT ELSE IS THERE TO REPLACE WITH THIS SYSTEM EXCEPT THE HOSES, WHICH I CHECKED OVER AND THEY APPEAR TO BE FINE. NOW MY WIFE'S 1998 GT IS GETTING THE SAME CODE AND I DON'T KNOW WHAT ELSE TO DO. SHOULD I JUST PAY THE FORD DEALER SOME OUTRAGEOUS AMOUNT TO FIX SOMETHING MINOR LIKE THIS?
Old March 11th, 2007, 07:49 PM   #2
MM's Coffee Addict
96Snaker's Avatar
1999 SVT Cobra
441rwhp/393rwtq
96Snaker has a spectacular aura about96Snaker has a spectacular aura about
Send a message via AIM to 96Snaker
I too had the same data trouble code in my 96. I changed the PCV valve, no help. Then the charcoal filter, code was still there. There's a little sensor near the charcoal filter that I changed after that and the code went away, however I can't remember the things name - I'll try and look it up, or if all else fails, I'll take a picture of it today or tomorrow and post it up so you know what it looks like. PM chris (97cobra) - for I think he may still have the Ford part numbers of the parts I am referring to as he had this same problem awhile ago.
Vortech V2, intercooled @ 10psi. Maximum Motorsports supsension goodie bag car less roll cage. Built '04 IRS. Hodge-podge of Roush/Stalker panels.
Old March 11th, 2007, 11:19 PM   #3
jagstang96's Avatar
jagstang96 is on a distinguished road
there is a evap solenoid and another sensor in the same line, this line goes from the plenum to the charcoal canister replace both of them and this should fix your problem!! good luck
Old March 11th, 2007, 11:23 PM   #4
Boomer is on a distinguished road
Send a message via AIM to Boomer Send a message via Yahoo to Boomer
Just be sure to order the right color, I believe one is gree and the other is red.
Old March 11th, 2007, 11:23 PM   #5
jagstang96's Avatar
check this out http://www.moddedmustangs.com/forums...or-vt3022.html
Old March 11th, 2007, 11:24 PM   #6
jagstang96's Avatar
wow your post is super helpful
Old March 12th, 2007, 12:04 AM   #7
Sorry (it is sunday)I was refering to canister purge valve, I was suggesting replacing. Back 5 years ago I replaced mine and puchased the wrong one
Old March 12th, 2007, 02:54 PM   #8
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
THANK YOU ALL FOR ALL THE HELP. I WILL TRY IT OUT TODAY.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Threads Similar to: EVAPORATIVE EMMISIONS CONTROL FAULT???
P0442- Leak in Evaporative System Detected superbeef1000 99-04 2 October 17th, 2007 11:32 AM
My own dam fault maddymac07 The Clubhouse 13 June 21st, 2007 11:42 AM
Code P1443 Evaporative Emmision Control System Control Valve jagstang96 96-98 10 September 5th, 2006 08:26 PM
Purge Control Solenoid or Purge Control Valve fault kdevildog01 General Tech 3 July 17th, 2006 02:45 PM
Emmisions Control........ 97Cobra 96-98 0 June 10th, 2006 01:58 AM
