4.6 Stroker Kit
Old April 27th, 2010, 01:57 PM   #1
1998 Mustang GT
N/A
tyler1987 is on a distinguished road
4.6 Stroker Kit
Alright guys I am working on my 2nd build the dady build. I was looking for some kits and i notced a 5.0l kit for liek 1k so i was thinking seeing how i am going to the 5.0l can i just buy that and strok to that?
Then there was one.
Old April 27th, 2010, 07:47 PM   #2
BAzombie's Avatar
1996 GT Convertible
13.88@100.71
BAzombie will become famous soon enough
I've checked out some stroker kits. I beleive any "5.0L" kit is a stroker. That's how your getting the extra ci's.
Mods: Katzkin Leather, MMR stage II heads w/PI cams, PI intake, Accufab 75mm TB & Plenum, CAI, Ram HDX clutch, Pacesetter LT's & X pipe, Pypes hi-flo cats, Flowmaster cat back,3.73 gears, Sct SF3 tuner, Mamba M2's
Old April 27th, 2010, 07:54 PM   #3
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
I'm not sure i understand what your getting. Are you asking if the stroker kit for the 4.6 mod motor will stroke you out to a 5.0? ( Yes, that's what it's for but you should spend the extra $700 and get a forged kit)
Or are you saying your getting a 5.0 and want to know if the stroker kit will replace the internals? ( NO)
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old April 27th, 2010, 08:07 PM   #4
1998 Mustang GT
N/A
I have found a fully forged 5.0l kit but it is for a 5.0l but if i strok the 4.6l the 5.0l kit should work right? Here is the link to the kit. Let me know what you all think.
5.0 302 SMALL BLOCK FORD STROKER 331 347 KIT NEW : eBay Motors (item 230357080927 end time May-09-10 16:20:40 PDT)
Then there was one.
Old April 27th, 2010, 08:14 PM   #5
tfofkyle's Avatar
02 Mustang GT
tfofkyle will become famous soon enoughtfofkyle will become famous soon enough
no, you are not going to be able to put a 331 or a 347 stroker kit in your 4.6. even if its stroked to a 5.0.
Old April 27th, 2010, 09:33 PM   #6
wannabeimportkiller's Avatar
2012 Race Red GT/CS
wannabeimportkiller will become famous soon enough
Send a message via AIM to wannabeimportkiller
rofl wow. Ok what you want is this here......
ModMax - 4.6 and 5.4 Modular Experts just bc you stroke your 4.6 to a 5.0 doesnt make it a "5.0" ford motor. They are 2 completely different types of motor. The true "5.0" or 302 is a pushrod motor where ours isnt. It has overhead cams and what not. So again if youre wanting to forge/forge your 4.6 you need what is in that link or something like it. Hope that helped
2012 Race Red GT/CS
98 GT-Gone
NCMM ORIGINAL
Old April 27th, 2010, 09:47 PM   #7
tfofkyle's Avatar
02 Mustang GT
^ that modmax is some cheap stuff lol. at least direct him to mmr or something.
Old April 27th, 2010, 09:55 PM   #8
2012 Race Red GT/CS
I sowwy i was just using it as an example lol Summitracing.com sells eagles rotating assemblies (stroker kit)
2012 Race Red GT/CS
98 GT-Gone
NCMM ORIGINAL
Old April 28th, 2010, 12:34 AM   #9
1998 Mustang GT
N/A
So im not getting out of spending at least 2500 on a kit in other words. it's fine just trying to figure it all out.
Then there was one.
Old April 28th, 2010, 11:54 AM   #10
2012 Race Red GT/CS
Summit has one for around 16-1800 just doesn't have a forged crank
2012 Race Red GT/CS
98 GT-Gone
NCMM ORIGINAL
Old April 28th, 2010, 12:06 PM   #11
1998 Mustang GT
N/A
If i don't go witha forgerd crank is it a bad idea?
Then there was one.
Old April 28th, 2010, 01:26 PM   #12
zigbigadoru's Avatar
97 Mustang GT
slower than the speed of smell
zigbigadoru will become famous soon enoughzigbigadoru will become famous soon enough
not really....how many times have you seen guys here or elsewhere snapping a crank or cracking it? not often
Originally Posted by XTCNAGT View Post
That's what you get for excercising.
You think my lungs and chest hurt when I drive down the road for a triple baconator? No. You know why? Cause I'm smart.
Time for a nap.
Old April 28th, 2010, 02:10 PM   #13
1998 Mustang GT
N/A
haha good point man lol
Then there was one.
Old April 28th, 2010, 03:16 PM   #14
1998 Mustang GT
13.046@107.49
cruizer will become famous soon enough
Do you think it would be cheaper to just go 5.4 since most have forged cranks and then buying forged rods and pistons then forging a 4.6?
98 Mustang GT 13.795 @ 98.87 N/A
Main mods: PI Swap, 3.73 gears, E85
My Mark VIII and T56 swap
Old April 28th, 2010, 03:30 PM   #15
1998 Mustang GT
N/A
Well my old block is a 5.4 but been reading that 5.4 and 4.6 use the same intrunels is this not true? Are is tehre a way to tell if they are difrent for sure?
Then there was one.
Old April 28th, 2010, 04:46 PM   #16
1998 Mustang GT
13.046@107.49
Well the stroke in the 5.4 is much longer. Same bore though. So the connecting rods for the 5.4 need to be much longer than the connecting rods of the 4.6 and same with the stroke length of the crank. The pistons between the 4.6 and 5.4 are the same though
Old April 28th, 2010, 05:10 PM   #17
97 Mustang GT
5.4 is usually a good idea because more displacement=goooooood. anyway the rods and pistons are the same crappy powdered stuff ford used in the mustang so theyre garbage but from my knowledge the cranks are VERY stout and i have been told that they can withstand like 700hp or some crazy number like that.
Time for a nap.
Old April 28th, 2010, 07:14 PM   #18
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
Naw man, just build your 4.6. You can get a strroker kit on ebay for the 4.6 that will stroke it to a 5.0. Or you could keep your stock stroke and get a set of fully forged internals for around 1200 minus a crank. If your gonna forge the rest you should spend the extra money on the crank though. You can use any crank from a 4.6 cobra. They all have a forged kellog crank.
Why go through the trouble and expense of an entirely different engine when you can get all the power you want out of yours.
MODS IN GARAGE
NCMM ORIGINAL
Old April 28th, 2010, 08:56 PM   #19
97 Mustang GT
i wouldnt suggest stroking the 4.6 at all....in fact if youre going to stroke it then you SHOULD go with a 5.4 because by stroking the 4.6 you take away the advantage the 4.6 has over the 5.4. the equilibrium of the stroke vs. the bore, by stroking the 4.6 to a 5.0 you in essence are taking away its ability to rev higher and whatnot which is the advantage the 4.6 has over the 5.4. 5.4>5.0 because more displacement=goooooood like i said before.
either stick with 4.6 or go 5.4. there shouldnt really be a middle ground there
Time for a nap.
Old April 28th, 2010, 09:45 PM   #20
1997 MUSTANG GT
11.20@125
cmher18 is on a distinguished road
Im a Dealer for MMR If you need help with anything let me know i can try to help you save money. Im Leary with the above co...
Threads Similar to: 4.6 Stroker Kit
what is a 4.3 stroker kit? BlackStang59 V6 Mustangs 37 August 10th, 2009 04:29 AM
Stroker Kit for me? 87StangLX 5.0 Mustangs 1 March 22nd, 2009 11:22 PM
Stroker Kit scott98stang 4V / SVT 1 February 6th, 2008 07:18 AM
4.6L Stroker kit energiesource 99-04 9 November 1st, 2007 01:22 AM
Stroker Kit ScreaminYellow05 V6 Mustangs 41 January 30th, 2007 04:14 AM
