Squeak sound in front (brakes) - Page 2
Old August 16th, 2010, 07:42 PM   #21
bigjohnstud4200's Avatar
2000 GT 'vert
bigjohnstud4200 has a spectacular aura aboutbigjohnstud4200 has a spectacular aura aboutbigjohnstud4200 has a spectacular aura about
Originally Posted by 97S281 View Post
So you basically greased up your brakes???
WD40 will dry off 90% before the car even rolls.. the other 10% won't last after one application of the brakes (as far as wd40 between the pads and the rotors.)
I know everyone is talking about the anti-squeal stuff that you can apply to the pads? Personally, I would get brakes with anti-squealing backing already on them and then add Brake lube to all the metal contact points. make sure you wire brush everything clean first.
"...but don't say my car's topless, say the titties is out"
Nas
Originally Posted by thrashersonmomma09 View Post
( member as in person not as in cock although i do love cock)
Old August 16th, 2010, 07:57 PM   #22
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
Uh, wd40 doesn't evaporate like brake parts cleaner or alcohol man.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old August 16th, 2010, 08:50 PM   #23
97PonyGT's Avatar
1997 Mustang GT VERT
97PonyGT is on a distinguished road
Double Holy Cr_p
Ralph
http://www.cardomain.com/ride/3118377
Old August 16th, 2010, 08:52 PM   #24
2000 GT 'vert
Yeah, you're right.. was was thinking of how fast brake cleaner evaporates, but it still won't hold on long after the brakes are applied.
Nas
Old August 16th, 2010, 11:38 PM   #25
1998 Mustang GT
MustGT98allday will become famous soon enough
I have had this problem twice. First time it was when i replaced the pads and rotors all the way around I forgot to clean off the grease on the rotors from being packaged. It soaked into the pads and constantly squeaks. what a pain. Everynow and then i take off the rims and spin the rotor while spraying breakleen on it. gets better everytime. The second time it happened I just simple needed to grease my front end. problems solved
pi swapped and dropped sn95
Old August 17th, 2010, 04:26 PM   #26
Blake96GT's Avatar
1996 GT
Blake96GT is on a distinguished road
had same thing happen to my 2000 gt took the break pads off and calipers re greased everything no more squeek came bck a month later just bought new calipers and break pads and rotors no more squeek for 3 months then sold the car so who knows by now
Old August 17th, 2010, 08:06 PM   #27
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
Hahaha, It's probably squeeking worse than a 10 dollar whores bed springs on payday!!
MODS IN GARAGE
NCMM ORIGINAL
Old August 17th, 2010, 10:38 PM   #28
Blake96GT's Avatar
1996 GT
hahah i hear ya on tht damn car was a night mere
Old August 19th, 2010, 05:29 PM   #29
97mustanggt's Avatar
97GT & 97Snake & 00L
T.B.A
97mustanggt will become famous soon enough
ehh fuck yeah i forgot to put the anti squeak paddings on the rear breaks...ima spray the caliper with liquid grease or something to lazy to remove em haha
97 Cobra & 00 Lightning
Beauty & The Beast
I rev next to hybrids so they can hear me kill the environment
MM Cobra Club Member #77
MM Lightning Club Founder
Old August 19th, 2010, 07:14 PM   #30
rpetty's Avatar
rpetty is on a distinguished road
squeak
yeah i had a squeak.....thought was from the brakes....then Bam......Drivers side ball joint broke....luckly was in a parking lot
Old August 22nd, 2010, 11:35 PM   #31
2004 Mach 1 Torch Red
Keredstg is on a distinguished road
Well I took off my right front caliper looked at it and put it back on. No squeak since, weird, but not complaining.
Turns out I got some warped rotor issues anyway so I have a set of drilled an slotted ones on the way with Hawk pads. Will make sure to clean before assembly and apply lube to pad touch caliper points.
oh and inspect ball joints, yikes!
Old August 23rd, 2010, 06:34 PM   #32
1998 Mustang GT
jamaicanred is on a distinguished road
Damn Squeaking Brakes!!!
I had the exact same problem on my 98 GT front passenger side. Drove me crazy!!! Finally I couldn't take it anymore and pulled the rotors. Low and behold they were warped BIG TIME. Put on new rotors and problem was solved.
Old August 23rd, 2010, 06:55 PM   #33
2000 GT 'vert
I would suggest also replacing all of the brake hardware (the metal shim between the ends of the pads and caliper, etc). I think the kit is about 11 a wheel; remember to lube them also.
Nas
Old August 25th, 2010, 04:25 PM   #34
The rotors aren't in yet but to update the squeak came back in about 2 days. Crap....come on UPS!
Old June 16th, 2011, 10:46 PM   #35
97PonyGT's Avatar
Wink
Ok here goes ... I ended up ordering a whole new set of front new calipers/ brakets and pads ... changed everything .. went away for awhile but now it's back. I put anti-squeak grease nowhere, I put no anti-friction rubber goop anywhere. So ... I'm thinking now if my caliper was slightly bad before the change (and assuminig it was binding) would it cause the rotor to warp?
Now i'm thinking I need to get the rotors "turned" to see what gives.
Again, as soon as I slightly push the brakes it goes away....
Anyone ? Any thoughts ?
thanks
Ralph
Ralph
Old June 17th, 2011, 10:22 AM   #36
2000 GT 'vert
It's not a good idea to put new pads on without turning or replacing the rotors. Are the clips that go on the outside edges of the pads installed also?
Nas
Old June 17th, 2011, 10:25 AM   #37
97PonyGT's Avatar
Ok I did not know that about the rotors ...
You think it's too late to rurn them now ?? resurface I mean ...
as far as the clips .. not sure what you are referring to ...
thanks
Ralph
Ralph
Old June 17th, 2011, 10:33 AM   #38
2000 GT 'vert
thanks
Ralph
How many miles have you put on the new pads? Once they start to glaze to their surface, the rotors, there's really no going back. If you purchased pads that have a lifetime warranty, or even any warranty, I would swap them for new ones when I installed the new rotors or had them resurfaced. There are metal clips on the caliper in the groves where the pads slide.
Not the best picture, but... You need to grease the clips too.
Nas
Old June 17th, 2011, 10:34 AM   #39
97PonyGT's Avatar
i did about 1800 miles .... ok I see what you are talking about .. yes the "backplate" on the pads ... I see now ...
so am i screwed ? or ?
Ralph
Threads Similar to: Squeak sound in front (brakes)
Front Right Suspension Squeak jonwrong 99-04 2 March 1st, 2010 01:40 PM
Front End squeak? stang_soldier 99-04 4 November 25th, 2009 07:17 PM
Knock & Squeak Sound KrazyStang 99-04 0 November 17th, 2009 09:31 PM
brakes STILL squeak KevinJ99GT 99-04 13 May 31st, 2009 03:50 AM
front end squeak Fish 2005 - 2010 1 August 5th, 2008 08:44 PM
