Squeak sound in front (brakes)
Old May 12th, 2010, 06:13 AM   #1
97PonyGT's Avatar
1997 Mustang GT VERT
97PonyGT is on a distinguished road
Question
Folks,
Last year I was able to isolate the problem to the front driver side (caliper, brake) assembly. I have changed the front pads, rotor etc. Squeak is still there. It does not squeak when I apply the brakes or when I turn left. I'm now thinking that the caliper holding braket is sligthly worn out making that the caliper sits in it's place but might be moving slightly as the car moves ... anyone else had this experience ?
Reason I suspect that is because I have removed the rotors and brake pads a few times, regreased things up with anti-brake squeak thingee grease and it temp. goes away ....
Let me know
Ralph
http://www.cardomain.com/ride/3118377
Old May 12th, 2010, 03:26 PM   #2
1998 mustang gt
LazyIAm is on a distinguished road
I had a squeak on my driver side front but I took the brakes off and put some lube on the pad where it touches the calipers and mine went away.
Old May 12th, 2010, 03:35 PM   #3
97mustanggt's Avatar
97GT & 97Snake & 00L
T.B.A
97mustanggt will become famous soon enough
i currently have a squeak on my front passanger it sux
97 Cobra & 00 Lightning
Beauty & The Beast
I rev next to hybrids so they can hear me kill the environment
MM Cobra Club Member #77
MM Lightning Club Founder
Old May 12th, 2010, 08:13 PM   #4
98mustangchris's Avatar
1998 Mustang Gt 5spd
98mustangchris is on a distinguished road
caliper is probably sticking. Also it might not be floating back and forth from rusted caliper bracket. It happened on mine. They are cheap. 20 bucks at autozone or the sort.
30kmiles,Vortech s/c,42lbinjectrs,svt fuelpump,90mm maf,o/r xpipe,MGW short throw shifter,snow performance water/meth injection,black chrome saleen wheels,daul flowmasters,dyno tune sct progrmr,CMS stage 2.5 blower cams,Manley valve springs/retainers
Old May 12th, 2010, 09:35 PM   #5
mazza89 is on a distinguished road
I'm going through the same thing right now. I thought it was the wear bars on the pad, but turns out the pads don't have wear indicators. They were low anyway so hopefully this fixes it. I am changing it tomorrow when I get the new rotors. I will let you know if this fixes it.
1996 Mustang GT, Underdrive pulleys, BBK cold air, PI intake swap, O/R H pipe, Borla Cat back, lowered 2 inches
Old May 13th, 2010, 12:18 PM   #6
T.B.A
both my front ones squeak i hate it so much, the only time they dont squeak is when i begin to apply the breaks.
Beauty & The Beast
Old May 13th, 2010, 01:29 PM   #7
97PonyGT's Avatar
thanks guys ... napa was 39.99 ... autozone .. 16.99
guess which ones I ordered ...
Later !
Ralph
Old July 14th, 2010, 10:19 PM   #8
97PonyGT's Avatar
Question
Brake Squeak
ok here goes ... still need help on this .
I changed the caliper Brakets on both front wheels .. it went away ... for about 2 weeks .. now it's back ...
WTF ??? Not sure what the hell it is anymore !!! ARGH
PLEASE HELP ... ANYONE !!! ??? !!!! ??
Ralph
Old July 14th, 2010, 10:52 PM   #9
BAD98GT will become famous soon enoughBAD98GT will become famous soon enough
exactly.....works like a charm
Old July 14th, 2010, 10:53 PM   #10
T.B.A
hey bro im about to change my front hub assembly both of them, ill let you know if the squeaking goes away
Beauty & The Beast
Old July 14th, 2010, 11:39 PM   #11
97PonyGT's Avatar
thanks guys ... I will be slapping on some goop on the brake pads to see if it will help .. I know its the driver front side only ...
stay tuned ...
Ralph
Old July 15th, 2010, 03:00 PM   #12
4eva4ord's Avatar
4eva4ord is on a distinguished road
I had a similar problem a few months back after changing rotors and pads all the way around but also just in the front driver side, i took my rotor and pad back to autozone claiming they had a defect got some new ones and same thing occured again. I tried lubing it up even went and lubed em all cause i figured maybe it was a different one and I was hearing something.
I took it to a shop who stopped my squeak and has stayed gone for 6m months so far, but after charging me $110.53 they claimed it was because
i used some rtv black on my bolts in ordr to keep em from backing out and they said that was the cause....idk but hey they stopped the squeak so if you dont mind the bill
1997 Mustang project Car (engine pending)
2004 3.9L V6
Old July 16th, 2010, 09:21 AM   #13
97PonyGT's Avatar
Cool
Update
Ok .. here goes.
Went for a drive last night with my brother in law. He stuck his head out while I was driving and heard shit on his side (hoping here the Mother is not deaf ) ... and I still heard the squeak on my side. So it's def front driver side.
Ok ... I get back .. let the pony cool off ... then I jam my fingers past the mags to touch the brake pad ... and was able to move it along the rotor .... so that to me did not seem normal ... I try the same on the passenger side and no go ... it does not move.
So, this gets me thinking here ... I have a caliper that is staying to open or at least not flowing back and forth properly (cylinder). So here is my plan for this weekend ... I will bleed that side a little cause for some reason (just might be) there might be some air in there who knows . Then I will remove the brake pads and have my lovely assistant pump the brakes .... to see how the cylinder reacts .... then I will go from there ....
what you folks think ??
Ralph
Old July 16th, 2010, 11:10 AM   #14
sounds like you know what to look for.
yeah, i think its sounding like a bad/sticking caliper
Old July 16th, 2010, 04:36 PM   #15
T.B.A
i still havent changed my hub assembley but soon.
Beauty & The Beast
Old July 18th, 2010, 08:00 AM   #16
97PonyGT's Avatar
Wink
Update .....
Ok so yesterday afternoon bled the front caliper(driver side) figured I have nothing to lose. Nothhing special or spectacular ... removed the braked pads and applied that orange rubbery goo to the back of both brake pads. I also applied a very thin layer to the caliper itself ... where the pads touch the caliper - figured what the hell
Waited a good 15 minutes. Will be trying it sometime today ... weather permitting ... was one of those typical Quebec days yesterday - sun/rain and then rain/sun ....
Stay tuned ....
Ralph
Old August 16th, 2010, 03:21 PM   #17
2004 Mach 1 Torch Red
Keredstg is on a distinguished road
Did it work
So did it work? I'm thinking of using the glue your pad to the caliper stuff. I think that is what you are talking about when you say "orange rubbery goo."
I have a squesak squeak sqeak as the car goes down the road without brakes applied. Apply them and it goes away let off and it come back.
Old August 16th, 2010, 03:39 PM   #18
97PonyGT's Avatar
Wink
Let's just say it kinda worked. It went away up until the other day. It's not as bad now ... but I still hear it. This means the "goo" worked but the underlying problem is with the caliper itself. I'm pretty sure it's binding which means it has to be replaced. Since my car is not a daily driver and gets stored for about 6 months out of the year ... I suppose it's expected. Anyhow, like I said, for now it's masked but the problem is still there but def. MUCH better and quieter than before.
Hope this helps .
Ralph
Ralph
Old August 16th, 2010, 06:23 PM   #19
T.B.A
after chagning hubs and pads and disks turns out tha squeak from from the rear the other day i sparyed wd40 all over the caliper and the squeaking stoped, oh well lesson learned
Beauty & The Beast
Old August 16th, 2010, 06:50 PM   #20
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
So you basically greased up your brakes???
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Threads Similar to: Squeak sound in front (brakes)
Front Right Suspension Squeak jonwrong 99-04 2 March 1st, 2010 01:40 PM
Front End squeak? stang_soldier 99-04 4 November 25th, 2009 07:17 PM
Knock & Squeak Sound KrazyStang 99-04 0 November 17th, 2009 09:31 PM
brakes STILL squeak KevinJ99GT 99-04 13 May 31st, 2009 03:50 AM
front end squeak Fish 2005 - 2010 1 August 5th, 2008 08:44 PM
