Discussing gauges in the 96-98 Forum. can any1 help me w/ wiring? plz...
Old March 14th, 2007, 09:25 PM   #1
1998 GTvert
gauges
Old March 14th, 2007, 10:18 PM   #2
wraitherlx's Avatar
99 Cobra
what are you trying to do??? We need more info so that we can help you out.
Old March 15th, 2007, 07:55 PM   #3
1998 GTvert
http://i82.photobucket.com/albums/j2...03-07_1914.jpg
http://i82.photobucket.com/albums/j2...0/scan0002.jpg
http://i82.photobucket.com/albums/j2...0/scan0001.jpg
Old March 15th, 2007, 07:59 PM   #4
1998 GTvert
how should i run the wires?
Old March 15th, 2007, 08:07 PM   #5
wraitherlx's Avatar
99 Cobra
you should find a grommet and punch a hole through it big enough to run your wires, just be careful not to punch through any wires when you are doing it.
Old March 15th, 2007, 08:23 PM   #6
1998 GTvert
but as far as the wiring just split wires?
Old March 15th, 2007, 11:48 PM   #7
wraitherlx's Avatar
99 Cobra
you can if you want but the way that we do it at my job is that we strip the wire back and then we poke a hole through the bare wire, not cutting them, just opening them up, then take whatever you are trying to hook up strip the end back and slip it through the opening and wrap it around the wire and tape it up and you are done.
Old March 16th, 2007, 12:16 AM   #8
96Snaker's Avatar
1996 Cobra
13.98 @ 101
that sure is one crazy way to splice two wires together. Never heard of that method. Learn somethin new every day, thanks
The Cobra might be gone... but the blue blood still runneth thru my veins.
Snaker's Music
Snaker's Myspace
Old March 16th, 2007, 12:17 AM   #9
wraitherlx's Avatar
99 Cobra
you can either go to the fuse box to get your power or you can go to the ignition harness. I believe that you would have to take off the part of the dash under your steering column and then there will be a metal plate that you will need to take off then just look for the wires that are leading to your ignition cylinder and use those wires. Here are the wires that you will be looking for.
12volts constant (for memory)- Yellow wire at ignition harness
Ignition (if you want your guages to come on whenever you start the car)
- Tan/White at ignition harness
Parking lights (if you want your guages to only come on when you turn on your lights) - Brown behind drivers kick panel (make sure you test the wire)
Old March 24th, 2007, 03:43 PM   #10
1998 GTvert
o2 sensor/gauge
hook to the front o2 or the rear??? does it mattter
Old March 25th, 2007, 12:07 AM   #11
wraitherlx's Avatar
99 Cobra
i dont think that it matters
Threads Similar to: gauges
Red gauges. JSapit Visual 21 July 12th, 2007 02:03 PM
gauges perks Electronics 1 June 27th, 2007 12:13 PM
Gauges robert1805m 99-04 3 May 31st, 2007 02:44 AM
gauges KhaosGT 99-04 4 February 6th, 2007 08:48 PM
Gauges MikeyS281 Crazylegs Racing 2 October 16th, 2006 01:42 AM
