Discussing NPI to PI Intake Swap... in the 96-98 Forum. so casper how much of a hp increase do u think u gained?... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
#61 |
EVO 8 @ 29psi
96 Black GT Vortech 331hp sold http://i93.photobucket.com/albums/l4...der3187/35.jpg 2003 EVO 8 440awhp/440awtq @ 29psi w/ METH TheShopCt.com |
#62 |
13.023@103.46 @ 5800 FT
All casper did in that how to was the intake, so maybe 20 horsepower. But if you buy the whole set up that is on ebay then you can gain up to 55 horsepower.
![]() We expect shit to break, look foward to realizing exactly when it is happening, and than obsess about dropping plenty of cash to rebuild stronger, so we can try to run it hard as hell and break again. We are sick individuals.
#63 | |
yeah all that was is the intake, but i never got it dyno'd after. This weekend or next im putting in my PI cams. So im making the write up soon. Then im gettng it dyno'd after. With small amount of bolt ons i was at 226/291. Now i have PI cams, pI intake, plenum and tb and JLT CAI. So it will be a bit higher.
White99stang-
93 LX, H/C/I + Vortech |
#64 |
Casper are you going to post the step by step process with pictures on the cam swap.Would be great,I would attempt the cam swap on mine with something to go by.
#65 |
Well as I read again I see you said you will post a write up,stupid me.
#66 | |
yeah its ok. sometimes i dont read the post all the way either.
but yes i will have step by step and pictures. Because i know doing something without any help sucks, you should see me try to do simple html on the computer. I look like a retard. So yeah it will be up soon. I cant wait either I have a very good trick to doing stage 1 cams, and it involves special tools. But you can buy it. So just wait for the How-to and you'll be all set.
White99stang-
#67 |
Great,I get nervous when messing with the timing and timing chains.
#68 |
Damn! I cant wait for the write up, I get anxious just reading these threads man!
http://www.moddedmustangs.com/forums/vehicle-classifieds/86839-wtt-90-lx-hatch-red-black-north-alabama.html#post1394801 |
#69 |
looking forward to the cam sticky! somtime in the future im going to get my stock heads ported & polished with new cams and pi intake. the work you did for us will be extremely helpful. THANK YOU!!!
#70 |
I am getting my PI intake shipped out tommarow or Monday!! It came off of a 02 GT so it has the aluminum cross over!! 3 quick questions! Casper when I tap for the 2nd coolant temp sensor how do I keep the metal shavings from going into the coolant crossover? Also where is the 1st coolant temp sensor? Is it on the intake or more towards the radiator? And third What is the DPFE sensor? Thanks and if I have any more questions I will ask! I might even get a before and after dyno just to see what I gained!!
#71 | ||
The crossover is bolted to the intake, just take it off. They are both on the crossover DPFE sensor is a box, usually grey and has 2 metal pipes commg off from it and the rubber hoses go to the EGR pipe.
White99stang-
#72 |
after you tap the cross over, just spray it out with some water really good man.
#73 | |
I have tapped oil pans, heads, rear ends...pretty much everything
If you wanna be real careful, take youre Tap and get some wheel bearing grease and put it in the area of the tap of the empty space. Fill that thing full of grease. Then when you tap the grease will push up and it wont fall in. And thats Mr.Caspers Tip of the day
White99stang-
#74 |
Okay sounds good! Just to get this straight there is already on temp sensor on the PI intake in the same place as the NPI and then I will just tap for the other? Thanks and will my computer have to learn the new intake and make it run differently for a few minutes?
#75 |
yeah just tap on opposite side of the cross over for the other one. might have to lengthen wires. but casper might have another idea
#76 |
no I wont have to lenghtnent he wires! It will be in the same place!
#77 |
Ohh and what type of silicon should I use? I have some from my shifter install but I doubt that is the same stuff I should use thanks so much!
#78 |
let me know your honest opinon on how the power differance is matt when you get done. Im changing jobs next week and my old job owes me a vacation check and a 3 day check they held back when I hired in plus my normal payrol check so Im gonna buy something. Made a deal with the wife, i get hotrod toys and she gets some tanning bed minutes!
#79 |
I definatly will! I am looking forward to getting it on! I dont know but I might not get it on until after schools out the 17th of may! I also am thinking that I will get some before and after 1/4 mile times! But then again the times without the PI intake will be my first time at the track actually racing so the times will probably be flawed! Hell who knows I might find the urge to get a before and after dyno!
#80 |
is this the DPFE sensor?
Threads Similar to: NPI to PI Intake Swap...
| Intake Manifold Swap help PLEASE!!! | 95kystang | V6 Mustangs | 30 | September 15th, 2007 11:11 AM |
| intake swap | jst854 | 96-98 | 8 | April 18th, 2007 09:15 PM |
| 98 Mustang GT Intake Swap Help... | Patterson98GT | 96-98 | 22 | April 17th, 2007 11:57 PM |
| 95' Mustang 5.0 HO intake swap for 93 cobra intake... | stang9587 | 5.0 Mustangs | 1 | April 3rd, 2007 05:20 AM |
| question about pi cam and intake swap | haloallstar | Modular Mustangs | 3 | March 12th, 2007 08:52 AM |
