Discussing NPI to PI Intake Swap... in the 96-98 Forum. Usually it leaks right behind the alternator, THATS why its aluminum now. The thermostat area ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
#101 | |
Usually it leaks right behind the alternator, THATS why its aluminum now. The thermostat area sometimes cracks and just like you said the coolant fitting in the rear passengers side area cracks.
I have never seen a problem with the 99-01 1/2 except they have certain sides. So get a left and right.
White99stang-
93 LX, H/C/I + Vortech |
#102 |
All Throttle with a Bottle
12.91@105.29 @ 5800 FT
Thanks Matt! And I am going to take one of you pictures and color in where I think the silicon should go and then post it up here so you can tell me if I am doing it the correct way!
![]() We expect shit to break, look foward to realizing exactly when it is happening, and than obsess about dropping plenty of cash to rebuild stronger, so we can try to run it hard as hell and break again. We are sick individuals. I support the MM Staff
#103 | |
sounds like a plan
also i would tkae pics of mine, but i dont need to remove the intake for the cams.
White99stang-
#104 |
It cool that you cant take pictures!
Which is it like? Pic 1 or 2? 2 Shows the silicone going around the cooland passage on the flat part of the head where the gaskets and intake sit! Or in 1 I tried to show putting the silicone down in the passage and making it flush with the new gasket if you look at it from the top. I think it is picture 2, but 1 was what I was under the impression before now!
#105 |
On Probation
Millenium Falcon
"Just Living the Dream"
has anyone paid to have there intake manifold change my a shop? If so do they know how much it costs? I'm kinda afraid to undertake that myself.
#106 | |
Very simple Matty man, you take silicone and put it under the gasket on the head. Dont put it in the valley. But actually ON the head beneath the gasket. Like in youre second pic.
If you happen to stumble apon the links in the for sale section that Ujust posted, dont even click them. What a joke. The first monkey used it on the intake ports and the second dude is using the NPI gaskets.
White99stang-
#107 | |
96. I dont trust anyone with my car. Im a tech as well so i do it all myself.
but im gonna assume anywhere from 160-250 for labor. And they dont know about the NPI to PI install instructions.
White99stang-
#108 |
Okay that clears it up! It goes on the on the head! It is just basically making a better heavier duty gasket at that point! Thanks so much and I dont even know where those links you pointed out are! And ujslost showed me those cams for a 100 and I am considering those!
#109 |
On Probation
Millenium Falcon
my best friend is a tec and he's wary of doing it. he says he can do it but he doesn't want to do it for several legitimate reasons. I was going to bring it to the local mustang pro shop and have them work on it. I don't trust shops either, but I'm pretty much at a loss.
#110 |
Its pretty straight forward!
#111 |
Matt there is no need to do it like this is there? I just need to put some under the gasket by the coolant passage. Not all the way down the gasket and under the gasket by the coolant passage!
http://forums.stangnet.com/showthread.php?t=495410 I would be no where with out you!
#112 | ||
They are using NPI gaskets and putting silicone ALL over the intake ports. Its stupid. Just put 2 small dabs where i showed you on the coolant ports and you'll be all set.
White99stang-
#113 |
Okay I wont look at those anymore! I just wanted to makesure and well you helped me out there! I just got the intake un wrapped like a minute ago and it looks all nice and dandy! Thanks so much!
#114 |
Okay I got back from ford and toyota! The gasket part numbers I got are
YL3Z-9439-BA. I just want to make sure these will work! Thanks matt!
#115 | |
cool, should be fun for you. How much was the toyota silicone, we sell it for like 40 bucks. lol.
I put the PI cams in today. fun fun
White99stang-
#116 |
Normally the silicon is 25 bucks, but the lady cut me a deal for 18! Glad it wasnt 40! And how were the cams? Cant wait for the write up! Then maybe I will try the PI cams in NPI heads!
#117 |
ok i have a question i need answerd quick....im doing this swap my old coolant tube that runs under the intake had a rubber hose on it and is in the center on the block....do i just take it off and slip the new 1 on?
#118 |
Yeah just take it off ans slide the new tube in there. The only reason we need a new tube is because of the height of the intake in the valley of the motor. Just replace the tube so it looks like the picture that casper put up in his write up. I really dont know if you will still need the rubber hose, but just make sure that you have a good seal on it so it doesnt leak. My guess is that you will no longer need the rubber tube. Ask any more questions that you need and somebody will help you out!
#119 |
well im asking cuz the new tube dont fit on the the nipple that was on the old 1...it has no orings on it
#120 |
lol any 1 have caspers number so i can call him i really dont wanna go buy a new 1
Threads Similar to: NPI to PI Intake Swap...
| Intake Manifold Swap help PLEASE!!! | 95kystang | V6 Mustangs | 30 | September 15th, 2007 12:11 PM |
| intake swap | jst854 | 96-98 | 8 | April 18th, 2007 10:15 PM |
| 98 Mustang GT Intake Swap Help... | Patterson98GT | 96-98 | 22 | April 18th, 2007 12:57 AM |
| 95' Mustang 5.0 HO intake swap for 93 cobra intake... | stang9587 | 5.0 Mustangs | 1 | April 3rd, 2007 06:20 AM |
| question about pi cam and intake swap | haloallstar | Modular Mustangs | 3 | March 12th, 2007 09:52 AM |
