Discussing NPI to PI Intake Swap... in the 96-98 Forum. http://www.mcmaster.com/ctlg/DisplCt...MMainWidth=812 thats the link. Its part number 2525a215.... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
#141 | |
White99stang-
93 LX, H/C/I + Vortech |
#142 |
All Throttle with a Bottle
12.91@105.29 @ 5800 FT
![]() We expect shit to break, look foward to realizing exactly when it is happening, and than obsess about dropping plenty of cash to rebuild stronger, so we can try to run it hard as hell and break again. We are sick individuals.
#143 |
#144 |
#145 | |
White99stang-
#146 |
#147 |
Master of the Force
Millenium Falcon
"Just Living the Dream"
MSO smokes pole |
#148 | |
If you want spend 500 for some stage 1 npi cams, or go with pi for cheap.
White99stang-
#149 |
Master of the Force
Millenium Falcon
MSO smokes pole |
#150 |
Master of the Force
Millenium Falcon
"make sure you purchase nPI gaskets since these gaskets seal the water ports. Failure to seal the water ports can result in coolant leaking into the combustion chamber and subsequent engine failure, so be sure to use nPI gaskets. Although these gaskets effectively seal the water ports (a must), they do not completely seal the intake ports. You must use high temp silicone sealant (permatex) to seal these ports. AGAIN… only apply the permatex to the intake" This is an excert from there artical. Which way makes more sense to you guys, cause it does bring up a valid point. Edit...I went back to the site and started reading more in depth and found out the guy who did the write up based it off of this write up allready, just changed it up a little bit. Still, Wondering what some of ur opinions are about the gasket thing. |
#151 | |
Every single site about Sn-95 Mustangs and PI swaps you will find this way. I wanted to use PI gaskets because they SEAL the INTAKE ports....yup you have 8 port you need to seal if you use the other npi gaskets. Shit goes everywhere...and im all set with using SILICONE on my intake ports. I made this other way and other people have used it and came out on top. To each their own.
White99stang-
#152 |
Master of the Force
Millenium Falcon
MSO smokes pole |
#153 |
#154 |
Master of the Force
Millenium Falcon
I noticed a few of them who used the kit said they only gained 8-12 hp. One person said he did cams and intake an only gained 20 with a tune. Does the kit give less horsepoer then a regular intake? I haven't seen anyone mention anything like this and thought i'd bring it up. I'm gonna keep looking into it and see if i can find more information and results from other sn95ers
MSO smokes pole |
#155 |
#156 |
Master of the Force
Millenium Falcon
MSO smokes pole |
#157 | |
White99stang-
#158 |
#159 |
Also, a side note. Anyone attempting this...GET THE PI COOLANT TUBE! I read a couple places that people got away without using them and/or spent $90 on one. Also, 98 guys, check your PI nipple. Many of you won't have to change it as we all know, 98 is the 'mutt' of Mustangs. Here is the part # for the nipple and the PI coolant tube FOR $30! I almost spent $90+ like everyone else until I gave the guy a specific part number at the stealership..."oh...here it is....$32" F752-8555-AA = number for PI nipple ($6-10) XR32-18b402-AA = number for PI coolant tube ($30-35) |
#160 |
Look Ma! My First Post!
Threads Similar to: NPI to PI Intake Swap...
| Intake Manifold Swap help PLEASE!!! | 95kystang | V6 Mustangs | 30 | September 15th, 2007 12:11 PM |
| intake swap | jst854 | 96-98 | 8 | April 18th, 2007 10:15 PM |
| 98 Mustang GT Intake Swap Help... | Patterson98GT | 96-98 | 22 | April 18th, 2007 12:57 AM |
| 95' Mustang 5.0 HO intake swap for 93 cobra intake... | stang9587 | 5.0 Mustangs | 1 | April 3rd, 2007 06:20 AM |
| question about pi cam and intake swap | haloallstar | Modular Mustangs | 3 | March 12th, 2007 09:52 AM |
