LinkBack (26) | Thread Tools |
#161
nice thread man this will help me out pretty soon .thanks
sold the stang
#162 |
GREAT article and it seems it's the only one on the web as well!
my car is stock w/ npi heads here's my delema, my 98 npi intake sprang all kinds of leaks seemingly out of nowhere and with zero warning [thanks ford] the conflicting info on the web is whether to use npi gaskets with the pi intake or not..I have seen articles that say you have to use npi gaskets and rtv the intake the bottom line is i really only want to do this swap once without leaks [had enough antifreeze leaks this year!] how has your swap held up over the years? and then there is the question: why is the npi replacement more costly than the pi?? I can't figure that one out. |
#163 |
Proud American
use pi gaskets and only put the silicon in these places!
#164 |
Hey thanks!
got it in and running well the first shot thanks to this set of pics and of course the op's install text and pics no friggin way did I come anywhere near the super fast 3 hr's it took the op mine was like 5 hours BUT!I did it all at night outside with a mini mag lite! lol [not kiddin'] for the record I did it the cheap/hack way without the correct coolant tube..just the hose and creativity but I want to say even though it does work I wouldn't suggest doing it that way, the problem here was my leak started getting stupid and ford didn't have the damned tube in stock nor did any ford dealer within driving distance. better hose than baked motor! now comes the waityinfg game to see how long it lasts...erm.. my helpful hint in this thread is simply to tell you where the cheapest PI intake was found... mustangs unlimited in manchester ct. for 179.00! and it's a ford racing part not a dorkman. thanks guys! |
#165 |
dpfe
what is a DPFE?
#166 |
DPFE =The EGR system is a Pressure Feedback EGR (PFE) or Differential PFE (DPFE) system, controlled by the Powertrain Control Module (PCM) and composed of the following components: PFE or DPFE sensor (also referred to as the backpressure transducer), EGR Vacuum Regulator (EVR) solenoid, EGR valve, and assorted hoses and tubing.
#167 |
i just got a pi intake from a 2002 gt but there is no aluminum crossover, it is all one piece. can i still tap a hole for my second sendor or wha t else can i do?
#168 |
Proud American
Dont use it. Go and get a intake with aluminum crossover unless you want to do this swap again in a year.
#169 |
The Hammer
Millenium Falcon
:homo
#170 |
isn't there any other alternative, like can i use a "t" fitting and put the temp sensor and switch in the same hole?
#171 |
Proud American
sure but ur intake is going to crack and you will have to replace it. You are also going to hvave to extend your wires on that sensor to make them long enough.
#172 |
i dont have many other choices, i cant take it back, so i'll have to either sell it or use it...unless u can think of a better idea of how to fix it...i'm changing it in the first place cause my old npi intake is cracked and leaking on my alternator...crap...
#173 |
Proud American
well ur PI intake with out the aluminum will crack too.
#174 |
what causes the cracking, heat or over torqueing the bolts, or are they just not a good quality part?
#175 |
Proud American
Not very quality at all!
#176 |
well, can i go ahead and tap for teh sensor and use it till it cracks or will a tap ruin it?
#177 |
Proud American
tap will ruin it!
#178 |
thats waht i thought...damn
#179 |
I gotta agree, don't use it..just sell it off and get a ford PI intake w/ the alluminum cross over it looks better and more importantly it it won't leak
btw mine leaked on my alt. as well and I had to replace that TOO. shit! another reason these intakes crack is if you have ever washed thE engine down even while that intake was just a little warm THAT is enough to crack it..I suspect i cracked mine just that way oh, and .....plus they're JUNK! |
#180 |
do yu know where to get or how much a pi coolant tube is?
Threads Similar to: NPI to PI Intake Swap...
| Intake Manifold Swap help PLEASE!!! | 95kystang | V6 Mustangs | 30 | September 15th, 2007 11:11 AM |
| intake swap | jst854 | 96-98 | 8 | April 18th, 2007 09:15 PM |
| 98 Mustang GT Intake Swap Help... | Patterson98GT | 96-98 | 22 | April 17th, 2007 11:57 PM |
| 95' Mustang 5.0 HO intake swap for 93 cobra intake... | stang9587 | 5.0 Mustangs | 1 | April 3rd, 2007 05:20 AM |
| question about pi cam and intake swap | haloallstar | Modular Mustangs | 3 | March 12th, 2007 08:52 AM |
