LinkBack (1) | Thread Tools |
#1
fuse panel for a 98
i need to if anybody has a diagram for my car so i can figure out the fuses in car and underhood
1969 Early Bronco 3.5" lift 37" swampers 1969 Early Bronco 2" lift half cab 1979 2.3t Cobra 1997 Black Cobra http://www.cardomain.com/ride/680999 http://www.myspace.com/beheivjer |
you mean these?
yes sir thank you very much
Look Ma! My First Post!
Do you happen to have a similar diagram for the 2002 GT. I am trying to locate my fuel pump fuse and my panel is square, it does not have the corner nicked off.
Zed |
i love this sight, there has yet to be a question i havn't found an answer to.
+2
always an answer and alot nicer than other forums
I also need a diagram of fuse box panel.. Please
#9 | |
48.47@ 12.58
what year?
Never mind all, the diagram just showed up. stupid me....
48.47@ 12.58
oh ok.
98, but I found it. but is it the fuse panel under the hood.
48.47@ 12.58
the pictures in this thread is indeed the fuse panel under the hood
HMUSN, I'm new to this site. trying to fix horn myself. There are two fuse panels, which one for horn. I did check all the ones under the dash. but not the hood.
48.47@ 12.58
it should be fuse number 10 under the hood.
I think it is the red fuse but i am not positive. if your fixing your horn is could be more than just the fuse btw. go into the tech section and take a look at my post "free online manuals" follow the directions and it will walk you through everything you need to know. I hope it helps. HMUSN
LinkBack to this Thread: http://www.moddedmustangs.com/forums/96-98/1714-fuse-panel-98-a.html
| Jeep Fuse Box Diagrams | This thread | Refback | October 10th, 2010 04:18 PM | |
Threads Similar to: fuse panel for a 98
| 98 v6 mustang fuse panel | 14perception88 | 96-98 | 1 | September 6th, 2007 01:49 AM |
| fuse box help.....anyone? | Bossman | 2005 - 2010 | 5 | February 8th, 2007 03:41 PM |
| Guys I Need The Fuse Panel Layouts For 1994 V6 Stang | Easy04_jm | General Tech | 1 | September 18th, 2006 04:34 PM |
| Fuse panel diagram and Mach 460 Wire Map | B0mb3r645 | Audio/Video | 1 | August 27th, 2006 01:38 AM |
