Smelly Fists, Socking Cocks
Millenium Falcon
weird noise coming from my motor during initial warm up
when i cold start my car i'm hearing an odd noise coming from the drivers side of the motor. the noise is very speratic and its triggered different ways. if i rev it a little the noise becomes louder and when the rpms start to drop, the noise goes away, until the rpms level off at the idle. also the noise is present when in gear and motion. when i step down on the clutch to shift the noise goes away, but comes back when i go into gear. the noise goes away when the car is fully warmed up.
Also my coolant lite flickers on n off but i checked the levels and everythings ok. could it just be time to flush the system? by the way the cars a 96 GT 4.6 5spd with 63,500 miles |
could be the timing chain tensioners. They work off oil pressure. Could also be lash adjusters. Could also be the normal head tick noise. Hard to say
Coolant light could be a sticky sensor.
91 LX, 5spd. Ex:Toyota/Ford tech Marine Machinery Technician, Department of Defense.
i have the same problem with the coolant light, and i just had to get used to it, my local shop said it was in fact 90% chance of a sticky sensor like what casper said
EVO 8 @ 29psi
and again my coolant light does the same thing lol
2003 EVO 8 The shop built motor, Precision 6262 w/.82 hotside, tial 44mm wg, Buschur RACE 4" FMIC, Kelford 272s etc 524whp @25psi on straight pump gas. 640whp@33psi Pump+meth Race gas number soon. TheShopCt.com |
Just take off the overflow ( degas bottle ) and put a cleaner in it or straight water and shake it around a while. Run water through it and put coolant back in it.
this might be wayout in left field here but. Mine makes a noise all the time but its more noticeable when its cold. Its my thrown out bearing it makes irratic noise, till i push the clutch in it quits. Like i said this probly isnt your problem but if your like me any info in good info
1986 Mustang GT t-top time piece! |
Millenium Falcon
also i don't have n owners manual and my mechanic happens to be color blind, so it's basically the dumb leading the blind sometimes. we went to flush the coolant in my car and we weren't able to tell what color the antifreeze is. Where pretty sure it was green but it was so nasty we couldn't tell. Im sure someone on this site knows the correct color antifreeze to use.
#8 | |
Sorry. If he is color blind and youre not. Why wouldnt you tell him. Anyways, its supposed to be green. It might have come out yellow/brown.
Millenium Falcon
beleive me, i told him, but to me it looked like it was blueish brown, and that when i decided to post the ques up here.
Millenium Falcon
ujstlost do u think u could describe the noise. i tihnk u might be on to something
96 GT
my 96 gt does the same thing with the light
BBK cold air intake, flomaster 40 series, steeda tri ax short throw, bbk x pipe w/cats, black magic fan, 3.73 gears, bbk pulleys, 18/10 18/9 black bullitts black with chrome lip....
Proud American
It sounds like a bearing on one of your pullies is bad. Its a screeching noise! Good luck
Millenium Falcon
how do i go about fixing this, will a new set of pulley's do the job or do i need something else?
Proud American
I am sorry man, I was describing the Throw out bearing noise. Do not change your pullies. Is the noise a screeching noise really high pitched? If so then most like likey it is your Throw Out bearing. To get this fixed you will have to drop the tranny and unbolt your bellhousing. Once that is done inside of your bell houseing is your throw out bearing.
My 98 GT has the exact symptoms that you're describing (high-pitched squeak/screech). The noise only happens when the clutch pedal is not pressed. When I press in the clutch the noise goes away. Does this sound like the throw out bearing?
when I press my clutch pedal the squeeking, screeching, sound quits, but when Im sitting at idle in N no clutch pressed it makes those noises. im sure it does it all the time, but when i got the tranny in a gear and moving i just cant hear it for the engine or the exhaust. Its pretty loud when i warm it up in the mornings
Yep, that's what I'm getting too. I've been told that it's the throw out bearing, and while I'm in there I may as well do the clutch and pressure plate. I've decided to go for a Spec Stage 1 kit.
if you have the same problem as i do then yeah its the throw out bearing. I know mine is but Im not gonna replace it right now.
Millenium Falcon
so how do i go about changing the throwout baring. Should I just have new clutch installed or is there something else involved in this process?
Threads Similar to: weird noise coming from my motor during initial warm up
| weird noise? | mustang sallie | 96-98 | 4 | June 13th, 2007 12:23 PM |
| Weird noise... | Keegan_Vann | 99-04 | 19 | April 19th, 2007 05:12 PM |
| weird noise | k2boarder3187 | 96-98 | 3 | March 11th, 2007 12:32 PM |
| Weird poping sound coming... | silver stang | V6 Mustangs | 33 | March 1st, 2007 08:39 PM |
| weird noise | holtte | 99-04 | 4 | December 14th, 2006 01:23 PM |
