code p1443 help please?
Old July 14th, 2010, 03:12 PM   #1
sj408 will become famous soon enough
hey guys, so my 1996 gt has been throwing code p1443 which is relevant to evap emissions control system i do believe.
so after reading all the posts relevant to this code people are talking about replacing the purge valve due to it possibly being stuck open but none of these posts mentioned exactly my problem too because in my car it seems at a stop every once in a while i smell HEAVY gas anyone got any insight towards this?
Old July 14th, 2010, 03:27 PM   #2
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
97S281 has much to be proud of97S281 has much to be proud of97S281 has much to be proud of97S281 has much to be proud of97S281 has much to be proud of97S281 has much to be proud of97S281 has much to be proud of97S281 has much to be proud of97S281 has much to be proud of
iTrader: 18 reviews
The most common cause of an evap code is a loose gas cap. Then a loose or broken evap line. Then the valve, then the sensor, then the actual charcoal canister itself. If you are smelling fuel it may be a broken line. Trace the line going off the rear of your upper plenum to the canister then to the tank. If you don't find a break then one of the other three components may be bad.
MODS IN GARAGE
All SVO'D UP
Old July 14th, 2010, 03:33 PM   #3
partsbill's Avatar
partsbill will become famous soon enough
HW7 DTC P1443: CHECK THE VOLTAGE ON THE PURGE FLOW (PF) SENSOR CIRCUIT VOLTAGE WITH ENGINE RUNNING
Continuous Memory Diagnostic Trouble Code (DTC) P1443 indicates an incorrect evaporative system purge control valve flow.
Possible causes:
Obstructed, open or cracked hoses between EVAP canister purge valve and intake manifold.
Damaged EVAP canister purge valve.
Damaged PF sensor.
Key off.
Disconnect PF sensor.
Check for loose pins or broken wires by pulling moderately on the PF, VPWR and PWR GND circuits at PF sensor harness connector.
Repair as necessary.
Reconnect PF sensor.
Connect scan tool.
Key on, engine running.
Access EVAPPF PID.
Key off.
HW8 DTC P1443: VISUAL CHECK OF EVAPORATIVE EMISSION SYSTEM
Continuous Memory Diagnostic Trouble Code (DTC) P1443 indicates an Evaporative emission control system or evaporative canister purge valve (mechanical) malfunction.
Possible causes:
Damaged EVAP canister.
Pinched, plugged, blocked, cracked, cut or disconnected fuel vapor tubes/hoses between the fuel tank, EVAP canister, EVAP canister purge valve, purge flow (PF) sensor, and the engine intake manifold.
Damaged PF sensor.
EVAP CANISTER PURGE, or PF circuit shorted to VPWR.
Note: Fuel saturation of EVAP canister cannot be effectively checked by the canister weight or intensity of odor (smell).
Check for kinked or pinched fuel vapor tubes/hoses between EVAP canister, EVAP canister purge valve and engine intake manifold.
Check for cracked or smashed EVAP canister
06 Black GT 5sp/JLT II CAI/XCALSCT2/B a m a 93 Oct Race Tune/FRPP Stingers/Hurst Shifter/GT500 Spoiler//Steeda ultralite Springs & rear pan hard rod/Bullitt Strut tower brace/07 Gt manifold cover/Shelby Lip/Sequential
HURST CREW MEMBER #17
Old July 14th, 2010, 05:42 PM   #4
thanks guys, ill be troubleshooting this problem when i get home with the information you provided me with THANKS a million for the quick responses.
after reading im assuming due to the fuel smell thats its either a broken line or the valve is stuck open. ill let you know when i find out
Old July 15th, 2010, 08:30 PM   #5
brandywine112972's Avatar
1997 mustang gt
brandywine112972 is on a distinguished road
i have that exact same code and problem with my 97 gt. let me know what you do to fix yours, so i can check mine too.
Old July 15th, 2010, 10:01 PM   #6
The Hammer
G.T. Rags's Avatar
Millenium Falcon
G.T. Rags has a reputation beyond reputeG.T. Rags has a reputation beyond reputeG.T. Rags has a reputation beyond reputeG.T. Rags has a reputation beyond reputeG.T. Rags has a reputation beyond reputeG.T. Rags has a reputation beyond reputeG.T. Rags has a reputation beyond reputeG.T. Rags has a reputation beyond reputeG.T. Rags has a reputation beyond reputeG.T. Rags has a reputation beyond reputeG.T. Rags has a reputation beyond repute
what did you find was causing the issue
I would eat the peanuts out of her shit
Car Salesman Club - The Hammer
ModdedMustangs Conspiracy Group: President
Old July 16th, 2010, 01:35 PM   #7
well looked around and didnt see any cracked lines and due to the fact that the gas i smell is only intermittent and not all the time came to the conclusion its the purge valve.... now to replace and see! kinda dealing with overheating problems right now
Old July 26th, 2011, 10:25 PM   #8
Tony407 is on a distinguished road
Sorry to bring up a 1-year old thread, but I'm having similar issues. I haven't had that code, but I've been noticing a very strong gas smell through the HVAC air. I changed the purge solenoid but it hasn't helped. I changed the in-cabin air filter and fuel filter too.
Recently, the fuel gauge has been whacked as well. Whenever I make a turn or accelerate the needles quickly moves to empty and then returns to normal after several seconds.
Did you ever find a solution?
Tony
06 GT Coupe - Ford Racing Handling Pack - Kenne Bell 2.6L S/C
Old July 27th, 2011, 12:12 AM   #9
you know i kinda just gave up on it and i only run it on max air so it re circulates and i dont smell the gas. it comes on intermittently when im on the highway.
car still runs great though
Old July 27th, 2011, 03:35 AM   #10
Hmmm. Well, I'm not ready to give up yet. I'm really not enjoying the smell, and it detracts from the driving experience. Not to mention my girlfriend will NOT put up with the gas odor.
Tony
Old July 27th, 2011, 08:54 AM   #11
1997 cougar 4.6 1/2PI
TooFast4theFUZZ
OptionalStang will become famous soon enough
well, atleast gas doesnt smell bad like shit....better to smell gas han buring oil..egh?
Old July 27th, 2011, 09:44 PM   #12
Speedstang302's Avatar
13.64@101mph
mine through that exact code when the filler neck to seal went bad...but granted i was pissing gallons of 93 out the side on turns...this you should notice
1990 GT- GT40p Heads| Anderson N41 cam| Crane 1.6 RR's| Trickflow Intake|Mac 1 3/4 Longtubes| VRS O/R X-Pipe| SLP LM1 Catback|MGW Short Throw| Aluminum d/s| 3.73's.....still slow....
Old July 28th, 2011, 01:48 AM   #13
Tony
lol i know what you mean, i just keep the windows up and put air on re circulate. no gas smell. Sounds like you need a new girlfriend lol
Old July 28th, 2011, 02:37 AM   #14
I love my cars more than most things in life, but my girlfriend and my dog are two exceptions. Plus, I can't stand the smell myself. LOL
Tony
Old July 28th, 2011, 04:22 AM   #15
Tony
ha just messing, im the same way. Is your engine light go on and off with this code? mine only comes on during say a freeway drive.
if ya ever figure yours out let me know.
Old July 28th, 2011, 04:41 AM   #16
Yes, it does. And the problem is getting worse. Now the tank goes to empty every time I pull in or out of my steep driveway too.
I may have to bite the bullet and take it to the dealership.
Tony
Old August 3rd, 2011, 04:31 AM   #17
Vect0rmask's Avatar
1996 Mustang GT Convt.
Vect0rmask is on a distinguished road
Send a message via Yahoo to Vect0rmask
Im dealing with the same thing as well, has anyone figured out this mystery? Im looking up evap systems now because I'm not familiar with working on them, if I learn anything helpful I'll post it up.
Old August 3rd, 2011, 05:24 AM   #18
As I've mentioned before, I've been having problems with my gas gauge. Well, I ran the car out of gas last week because I couldn't tell how much gas I had left. Filled it up & drove it home and bought a bottle of Lucas Upper Cylinder Lubrication & Injector Cleaner and put it in the tank. I then took it out for a drive and it ran like total crap for about 10 minutes (might have got some sediment from the bottom of the gas tank?) and then it cleared right up. I haven't had the gas smell since. Don't ask my how or why, but my gas gauge has been working 100% now too.
Just FYI.
Tony
Old May 29th, 2012, 03:58 PM   #19
Regular.
1998 Mustang v6, 3.8l.
quick6hjl is on a distinguished road
My "check engine" light came on two days ago. I don't smell gas, Ive checked my gas cap & everything. Took it down to Auto Zone & it came back p1443 code. Its a 1998 v6 3.8l mustang. I dont want to put a bunch of money out on it, if it doesnt fix it. Any ideas to what is wrong?
thank you.
Halie.
Old August 19th, 2012, 07:31 PM   #20
Rich2279's Avatar
'98 Mustang GT
Rich2279 will become famous soon enough
Just had my engine light come on due to a code P1443. Time to diag. the evap. system.
'98 Mustang GT-- Money Pit
http://www.cardomain.com/ride/394916...ng-gt-coupe-2d
Threads Similar to: code p1443 help please?
CEL Code P1443 MustangMo V6 Mustangs 8 August 7th, 2008 04:40 AM
Sluggish and Pinging P1443 Code ? kevnsue 96-98 6 October 31st, 2007 08:53 PM
Code P1443 After using seafoam!??! 97redgt Modular Mustangs 3 September 28th, 2007 02:22 PM
rough idling, code p1443 cyrax01 96-98 6 August 22nd, 2006 10:44 PM
Code P1443 ? Please help 97Cobra 96-98 2 April 16th, 2006 05:47 PM
