Who's SN95 radiator/engine is running hot in the summer?
Old July 27th, 2010, 06:36 PM   #1
zdkel's Avatar
zdkel is on a distinguished road
Ive seen a few posts this past month, and I'm raising my hand too.
I have thought a lot about this. I think the radiant heat from the exhaust manifold (or headers) do alot for getting that temp needle past "M" and on to the "A" or even "L" in some cases.
Reason, why I have been checking my temp of the upper radiator hose, thermostat housing with an IR thermometer. What I notice, is with the fan on the temp stays well below the 185F opening temp of my thermostat - I jumped my high speed fan and withnessed this. On the alternative, the car once hot (running between "MA" for me) those same surface temps bounce between 195 and 205 with the fan coming on in low speed by ECM control.
Has anyone seen a drop in running temp by coating or insulating the exhaut manifold?
I'm thinking about doing this, with some wrap or something.
Thanks.
96 GT - PI Intake & cams, O/R h-pipe, Flowmasters - 40s, Short Throw Shifter, 3.73 FRPP gears.
Old July 27th, 2010, 07:45 PM   #2
1998 Mustang GT
13.046@107.49
cruizer will become famous soon enough
you could just run a colder thermostat. I run a 160 and my engine runs nice and cold all the time
98 Mustang GT 13.795 @ 98.87 N/A
Main mods: PI Swap, 3.73 gears, E85
My Mark VIII and T56 swap
Old July 27th, 2010, 08:43 PM   #3
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
Ditto. I have shorties and an o/r pipe and I don't have any cooling problems even when the outside temps are in the 100's.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old July 27th, 2010, 08:56 PM   #4
tfofkyle's Avatar
02 Mustang GT
tfofkyle will become famous soon enoughtfofkyle will become famous soon enough
from a 96 owner to another 96 owner - invest in a bigger radiator. its a problem on all 96 mustangs.
Old July 27th, 2010, 11:02 PM   #5
BAD98GT will become famous soon enoughBAD98GT will become famous soon enough
header wrap is some pretty good stuff for lowering the temps in the engine bay, which will help you out in the cooling part a lil bit. BUT its a bandage. just replace the radiator and put a lower stat and ur done.
have you tried cleaning the radiator with a pressure washer? or go to the carwash and clean it on rinse. i bet it'll help a lil more than the header wrap. also your coolant to water mixture plays a good part in cooling it during the summer. most of the time ill run 50/50 mix. but if your having probs then try a 30/70 mix. more water will help keep it cooler on hotter days, but if you run 100 % water then youll run a chance of the water starting to boil, which isnt good.
Old July 28th, 2010, 02:07 AM   #6
96 Mustang GT
B There 1 Day.
LoveStangs88 is on a distinguished road
+1 on the 96 running hot, mine gets on the MA on hot days i just got the coolant flushed about 2 months ago but my coolant light always pops on and off randomly everyday constantly before and after the flush and the cars always ran hot in the summer.
PI Manifold. FRPP. Steeda. Magnaflow. BBK. Accufab. RAM. MGW. MSD. NGK. NTK. Billet. J&M. Powerslot. Hawk. Walbro. Motul. Fel-Pro. Dupli-color.
Old July 29th, 2010, 02:38 AM   #7
Look Ma! My First Post!
5150Stang's Avatar
5150Stang is on a distinguished road
My 96 popped its top one time and ever since I have wanted to put a bigger radiator on. Time to start shopping,.
We have once again reminded people, that man is not free, unless government is limited. There is a clear cause and effect here that is as neat and predictable as a law of physics. As government expands liberty contracts. Ronald Reagan
Old July 29th, 2010, 12:47 PM   #8
sj408 will become famous soon enough
well im in vegas and i blew a radiator hose for some god awful reason so i replaced the tstat cause as we know they usually break under heavy temperatures, then i replaced my water pump... still over heating so i then replaced my radiator and i run pretty cool now but periodically it will jump up to the M and it scares the crap outta me but then it will drop back down...
anyone else experience the temp gauge jumping around like this??
Old July 29th, 2010, 12:58 PM   #9
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
sharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud of
iTrader: 10 reviews
SN95's run hot.
except mine, it runs cold
410rwhp 520rwtq @ 12.9 psi
Old July 29th, 2010, 05:53 PM   #10
zdkel's Avatar
Could that be an air pocket?
Old July 29th, 2010, 08:48 PM   #11
Originally Posted by sharkbait View Post
SN95's run hot.
knock on wood, mine dont have probs getting hot either
Old July 29th, 2010, 11:23 PM   #12
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
iTrader: 10 reviews
Yea mine runs by the N in normal. On hot days it goes to the O.
I just redid my coolant system not to long ago though. It used to sit at O all the time
Old July 31st, 2010, 09:15 AM   #13
tfofkyle's Avatar
02 Mustang GT
consider yourself lucky - mines almost blown the gaskets off 2 or 3 times. twice having to be towed home due to losing a ton of coolant out of the overflow cap. and one of those was not even a month or so after finishing my fresh head swap.
id be willing to bet your needle is incorrect or your coolant sensor is not reading correctly. you would have horrible gas mileage and power if your car stayed that low in the temperature range all the time. stock temp gauge is inaccurate, but not that bad.
Old July 31st, 2010, 01:17 PM   #14
tatertot99's Avatar
1997 Mustang GT Conv.
14.7@92
tatertot99 is on a distinguished road
Yep, no problems here either, knock on wood. SCT Livewire reads temps back to me and stays between 200 and 202 degrees in the heat of the day.
Old August 1st, 2010, 07:19 AM   #15
1996 Mustang GT Vert
Blower Head is on a distinguished road
I got tired of mine alway running warm and popped for a new water pump and radiator this summer and my car runs cooler now.
96 GT vert, Aftercooled Vortech, Lightning MAF,42# injectors, saleen cams, Bullitt intake, tune by Hitech, Magnaflow catback and O/R xpipe, Cobra brake upgrade, lowered bilstein suspension w/MM c/c plates and subframe connectors 3000 stall and 3.73's
Old October 18th, 2010, 07:33 PM   #16
zdkel's Avatar
Question
Bringing up an old-ish thread
So I ran my heater the other day on my way to work...[hey, I'm a Floridian, I get cold easy, but anyway]
My coolant is very orange in color since then. I'm thinking rusty heater core, by circulating the coolant through there flushed a bunch of rusty water into the engine block, radiator and catch bottle. I had done two partial flushes over the summer, but the coolant is far from green now.
Anyone else experience something similar? With the coolant the way it is, you think the car will run hotter/cooler?
Threads Similar to: Who's SN95 radiator/engine is running hot in the summer?
sn95 mustang radiator questions Speedstang302 96-98 10 December 6th, 2010 10:00 PM
Engine Running Hot but Temps Are Reading Normal? Pittbull 99-04 51 February 4th, 2010 09:27 AM
A Summer Day With My SN95 *Pics Woot* Handz Pictures 21 July 15th, 2009 08:44 PM
running hot jonnotch 5.0 Mustangs 8 May 13th, 2008 11:50 PM
Whats up with my AC? Put 1100.00 in it last summer blows hot 1911A1 5.0 Mustangs 7 May 28th, 2007 07:23 PM
