The Hammer
Millenium Falcon
rear end gear ratio
what is the stock rear end gear ratio for a 96-98 gt. r they the same for convertibles or dif? I've found multiple sites claiming 2.73, some r 3.08, and I believe a 3.23 was tossed up in there.
yes. Look at the tag on youre rear end of give me youre vin and i can tell you
91 LX, 5spd. Ex:Toyota/Ford tech Marine Machinery Technician, Department of Defense.
RLY SRS
I would say you prolly have 3.27's in there...But check the diff tag to make sure...
Proud American
Mine has 2.73!
96 GT
3.73 stock?
BBK cold air intake, flomaster 40 series, steeda tri ax short throw, bbk x pipe w/cats, black magic fan, 3.73 gears, bbk pulleys, 18/10 18/9 black bullitts black with chrome lip....
Proud American
no way! The lowest gear that the 96-98s had were 3.27 from the factory. There was also 2.73 but not 3.73s.
The Hammer
Millenium Falcon
my vin # is 1FLAP45X0TF192629
Proud American
That wont help, on your drivers door jab there will be a sticker and then at the bottom of it towards the right you will see AX. If the letter is an A then you have a 2.73 or a 3.08. If you have a C then you have 3.27.
I was also wrong I said that 2.73s and 3.27s were the only axles, but 3.08s were also avalible.
The Hammer
Millenium Falcon
i put the vin number up there because casper said with it, he'd be able to tell.
Proud American
Well I dont think that you can determine the rear gear ratio by just the vin I think you need to look at the sticker on the door jab. Not to mention it would be easier!
Worse case you can simply jack the rear of the car up and mark the tire and the ground, then have someone rotate the tire one full rotation, and while you are under, mark and look at the drive shaft and count how many rotations it turns. IE..3.27 would be if the driveshaft turned about 3 and a quarter turns. It's really not complicated, but it is a sure bet worse case.
#14 | ||
just do what mustang matt told you lol its so much easier, i think the 3.27's weremsort of uncommon though i am guessing you have 2.73
Mine says E....
is thatbut casper my vin is 1FALP42X4TF207816 if you could tell me too plz
My Axel code on the door of my 03 GT Convertible is LE, but on the rear end, I have a tag and one of the codes is 3L27, i'm assuming thats 3.27 limited slip?
Car feels like it has 2:73 to me, won't even break the rear tires and i've drive a good few mustangs, this seems to be the slowest for some reason. |
by the way, i was wondering if 3.73 is the best gear ratio...i like them but i was just wondering your guys opinion.
1998 mustang GT 4.6l-cobra R rims/Hood -vortec supercharger(10psi) could (30psi) -stage 2 cams-BBK shorty ceramic headers -Flowmaster dual exhaust 3 1/2 inch -3.73 gears-subframe connecters -goodyear eagle F1 -sct ford programmer |
Proud American
Get 4.10s!
Matt, you seem to be a huge proponent of the 4.10. Is there really a major advantage to the 4.10 over a 3.73?
96GTRagTop....sorry. Ford now has a 10 year limit to what i can see.
1badpony...3l27 means you have a locker rear end with 3.27 gears. If youre running a n/a car go 4.10's or 4.30's. If youre F.I. stick to a 3.55 or 3.73.
Threads Similar to: rear end gear ratio
| Gear ratio | 1BADSTANG | 5.0 Mustangs | 13 | September 17th, 2007 10:27 PM |
| Need help with the 3.55 Gear Ratio | Lil_M | Modular Mustangs | 5 | March 31st, 2007 10:22 AM |
| What gear ratio should I use? | Jackson | 5.0 Mustangs | 9 | March 22nd, 2007 11:35 PM |
| Gear Ratio | Exseque | 2005 - 2010 | 10 | March 9th, 2007 01:27 AM |
| Easy way to find out rear gear ratio. | Bill | 5.0 Mustangs | 12 | February 21st, 2007 06:54 PM |
