I am off work tomorrow so...
View Poll Results: Metal or Plastic heat shield
Metal 0 0%
Plastic 2 100.00%
Voters: 2. You may not vote on this poll
Old March 27th, 2007, 11:56 PM   #1
ujslost's Avatar
I might try an fab up that heat shield for us guys who took the air filter housing off. I just want opinions from you guys. So check the POLL!
I know I want to try and make it contour to the bottom of the hood so that it is pretty snug and blocks the engine heat while trapping in incoming cooler air. I know Im gonna use either some old weather stripping or some rubber heater hose split down the middle then mounted on top of the shield like the aftermarket ones to seal on the bottom of the hood. Plus Im thinking plastic, it should disapate heat quicker than a sheet metal type.
Old March 28th, 2007, 10:28 AM   #2
Proud American
MustangMatt96GT's Avatar
The metal will hold heat is and the plastic will do a better job to repel heat.
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Threads Similar to: I am off work tomorrow so...
tomorrow 93fourbangerstanger 2.3 Mustangs 6 September 25th, 2007 10:34 AM
Tomorrow acehogg69 The Clubhouse 15 September 3rd, 2007 11:41 AM
going tomorrow to check out 98 z28 GTblackprodigy The Clubhouse 32 August 9th, 2007 04:06 PM
First Run Tomorrow! Tony_90fox 5.0 Mustangs 4 October 14th, 2006 03:55 AM
