Fuel Pressure Problem, Need Help.
Old August 18th, 2010, 09:26 PM   #1
1998 Mustang GT
silversocks162 is on a distinguished road
I have a mostly stock 98 GT and I cant keep my fuel pressure high enough in the fuel lines and fuel rail to start the car, let alone run the engine. I used a fuel pressure tester and it hardly makes 10 lbs when it should be at 35 - 40lbs. Ive already replaced the fuel pump, fuel filter, and the fuel pressure regulator. I have no idea where to look now. Any ideas?
Old August 19th, 2010, 07:23 AM   #2
Nintee7GTee's Avatar
1997 Mustang GT
None
Nintee7GTee is on a distinguished road
If you turn the car off and on repeatedly, does the pressure get any higher?
97 GT, Hand built Long tubes , MSD coils, 9.5 MM wires, JLT Cai(P.O.S), Now BBK Fender exit polished. Flowmaster 44's, SCT tuner(decent) :-(
Old August 19th, 2010, 11:39 AM   #3
1998 Mustang GT
Yes for a little while, then as soon as I turn the ignition of the fuel pressure drops rapidly. Almost as if the fuel pressure regulator is not keeping fuel in the fuel rails, but I already replaced that part.
Old August 19th, 2010, 05:01 PM   #4
1997 Mustang GT
None
it is possible they sold you a bad regulator. I had that problem once with my ranger, i went through the fuel system completely before returning back to the regulator, it was faulty.
Old August 20th, 2010, 02:59 PM   #5
1998 Mustang GT
Well I had them re-order a new one and I swaped it out for the "faulty" regulator today and the car still doesnt start. Is it possible that one of my fuel injectors is broken and is letting all of the fuel pressure drain into that cylinder?
Old August 20th, 2010, 05:24 PM   #6
1997 Mustang GT
None
Well, I would say if it doesnt have a hard ping in the topend while turning it over, it's not likely. Unless one of the nozzle tips blew off and went out the exhaust valve, you can get a nozzle and oring kit, in sets, and pull the rails and see.
Old August 30th, 2010, 07:01 PM   #7
1998 Mustang GT
I found the problem. Turns out that I didnt reconnect the fuel line to the fuel pump correctly. This also solves my starting problem because the o-rings are worn out in this connection and the fuel pressure slowly drops to 0 after a while. But ill fix that soon.
Thanks for all your help Nintee7GTee!
Old August 30th, 2010, 09:55 PM   #8
1997 Mustang GT
None
I'm glad you got it fixed! I just talked to a guy a few minutes ago with the same issue! Bad seals! I was gonna post, but you beat me to it! Lmao
If you run across anything, hit me up
Old September 12th, 2010, 10:09 PM   #9
1998 Mustang GT
You wouldnt happen to know where I could find a seal to fix that problem would you? Or at least have a good place to start looking for one?
Old September 12th, 2010, 11:49 PM   #10
mystk96's Avatar
2005 trd tacoma sport
mystk96 will become famous soon enough
not trying to thread jack but my 96 cobra has an issue that if you free rev it the first rev it will rev second rev it will bog down third rev it will stall. when driving the car say i go from 2nd to 3rd hell 1st to second at say 3000 rpm it will bog down for a second then pick back up.
i replaced the fuel pressure regulator, fuel pump, and fuel filter
the fuel pressure regulator is another new one.
i havent driven the car long enough to know if it was a faulty fpr...
being that the car is a return style fuel system i took the rubber boot off the return line due to it being corroded any ideas on what the issue could be
oh at full throttle the car is fine.
i did the test from the exhaust and the passenger side holds up the dollar bill but the drivers side doesnt keep the dollar bill up theres a popping in the exhaust.
the car does have hollowed resonators and a exhaust leak on the passenger side collector on the header
exhaust is
frpp shorties
bassani x-pipe
flowdisaster 3 chamber
Threads Similar to: Fuel Pressure Problem, Need Help.
Fuel Pressure Problem 2006YellowGT 2005 - 2010 6 June 10th, 2010 03:19 PM
Fuel Pressure Problem andres0286 99-04 12 March 2nd, 2010 11:48 PM
Fuel Pressure Regulator Leaking Fuel Buttaz V6 Mustangs 4 August 17th, 2007 11:41 AM
1990 5.0 Fuel Pressure Problem RMBillings 5.0 Mustangs 2 August 4th, 2007 10:50 PM
No fuel pressure, Fuel gauge went above full and stayed. woodz72 96-98 6 July 10th, 2007 06:58 PM
