1996 Mustang gt
Does your A/C overheat your Mustang?
My 96 Stang dosent overheat anymore in this Texas weather but only when i turn on my A/C. Which i think is wierd because it turn on my fan, which should keep the temp in check. Any ideas on what it might be or if this happens alot to this year mustang.
1998 mustang gt
IM in tampa its usually pretty hot here too... ive owned my stang for about a year now and have always had cooling issues... replaced almost everything i can and yet it is within check sometimes either at a stop light in stop and go traffic/with ac going my guage starts to creep up... but as soon as i get going back to normal
P.I. Heads/Cams, PI Intake, 80mm maf, CAI, ported C&L plenum, ported 70mm proproducts throttle body, 3.73 gears, manifold back {no cats} custom exhaust/side pipes, msd coils, Taylor 409 wires, two row aluminum radiator...SCT Livewire bamachips tuned |
1996 Mustang gt
Well I'm just driving highway and I'm getting plenty of air thru the radiator but it still overheats and throws out the water.
1996 Mustang GT coupe
11.99@113.93mph
FoMoCo actually had a TSB on the 1996 GT's and Cobra's that addressed this problem in southern states and it inclueded a larger radiator and a/c condensor, different coolant fan, removal of the honeycomb grill (notice 1997 and 1998 dont have a grill), some air deflectors and more...to sea if yours had this done, look at the lower radiator mounts and sea if thev've been moved outwards @2" on each side....there are several things you can do on your own, like cleaning out the fins on the a/c condensor and radiator of bugs and debris, adding a bottle of Red Line Water Wetter, having the computer programed to turn the fans on sooner....also make sure the low and high speeds on the coolant fan are working..
Thumbdinger.com Fish With Protection
1998 GT suckaaa
4 tickets @ 1 stop
i have no ac. wish i did
Military Crew
Completely stock... I promise. ![]() |
1996 mustang gt
im in ky it dont overheat it but it makes it run hotter. going 55+ its fine but in town at start an stop its gets pretty warm
1996 ford mustang gt 4.6 auto cervini's ram air hood, CDC side exit exhaust....more to come
how hot is to hot? My car will sometimes get up to 230 driving around town. I have a mechanical temp gauge so I dont know how acurate it really is. Car has never overheated or lost any coolant.
![]() 1997 Mustang GT 04 PI 2V, bolt ons, gears, tune 255/292 www.covertmotorsports.net |
Hooo Ha Ha
Yea i deleted the ac....
![]() 410rwhp 520rwtq @ 12.9 psi |
2001 Bullitt
My a/c blows ice cold, and doesn't overheat nothing!!!! It just boggs the motor..lol
![]() Bullitt Crew #16 MM + Cleavage Club #16 http://www.youtube.com/watch?v=NviuotZgIgg |
02 Mustang GT
my ac keeps my motor cooler regardless of sitting still/running at speed/etc. thats at about 80-85* temps though. once you get into the 90's mine gets dangerously hot if you do anything but turn the heat on full blast.
1996 Mustang gt
Well i know that the fans turns on automatically at 220 degrees and when the arrow hits the "R" in NORMAL on the temp gauge but when i turn on the A/C it hits the "A" but when it hits the "M" the water start to throw out. Im thinking of buying a bigger radiator but not to sure if this will solved my promblem i just want A/C because of this texas weather where temps can hit 90 to 100 and putting my windows down really dont help cuz of the hot air lol
1998 mustang gt
it does seem to be an epic struggle to keep my beast cool... next im gonna get a better electric fan... but in regards to the question of how hot is too hot??? anybody know of a reasonable figure degree wise how hot is dangerous?
1996 Mustang gt
i think its past 220 degrees is overheating
96 Mustang GT
B There 1 Day.
Out here in colorado mines always running on the A-L when its 90+ outside with the AC on. I usually try not to use it unless im starting to sweat. But with summer here i think my next mods are gonna be a PI intake manifold and a 170 degree thermostat and probably some new coolant sensors since my coolant light is always turning on and off at the most random moments. Iv read alot of topics about people changing the radiator and having no results. Even the mishimotos dont seem to help anyone. Im just glad my interior isnt leather.
![]() PI Manifold. FRPP. Steeda. Magnaflow. BBK. Accufab. RAM. MGW. MSD. NGK. NTK. Billet. J&M. Powerslot. Hawk. Walbro. Motul. Fel-Pro. Dupli-color. |
1996 Mustang gt
black leather is the worst in texas, it burns my ass
#16 | |
N/A
If parts ain't flyin', You ain't tryin'. |
I used to have the same problem. With the a/c off, gauge would be in the bottom quarter when moving and halfway when stationary. With the a/c on however, it'll linger in the upper regions of the gauge and break through the glassboard when at idle. Turned out it was my core plugs, and a less than satisfactory coolant mixture. After getting those things fixed she ran like a dream, up until my evaporator core went bust, I can't use a/c now. And to add fuel to fire, after swapping my rack and pinion for a manual one, the temperature always seems to be too high now. Must've damaged a hose or something..better get that looked at
#18 | |
Do you know the number of the TSB? Im getting ready to go through my 96 and check for all the mods, this is one I'm defiantly interested in looking up as I'll be in Phoenix soon. |
Rollin' 18/ pushin' 2
+1 My A/C cuts my car off. It is a problem with the tune. I got a delete kit it's just too damn hot out right now to put it in. Go figure right?
Threads Similar to: Does your A/C overheat your Mustang?
| obvious overheat... but how bad? | jarhedch | 96-98 | 6 | May 2nd, 2010 11:35 PM |
| can udps overheat my car ? | unblock | 99-04 | 29 | June 21st, 2009 01:46 PM |
| car overheat when a/c is on | unblock | 99-04 | 9 | May 27th, 2009 08:14 PM |
| Overheat | shadowgames81 | All Other Vehicles | 3 | October 3rd, 2006 07:05 PM |
| Overheat and Shake! | TorqueMonster | V6 Mustangs | 4 | August 19th, 2006 08:25 AM |
