1998 Mustang GT
![]() iTrader: 2 reviews
creaking front end
So my car creaks like a bitch. sounds like a truck with bad leafs or something. It is the passenger side, not sure if its the front or back, most likely front. I have the day off tomorro so im gonna spend some time on it. Can anyone help me? What should I check out and what should I look for?
I apprecitate any help.
pi swapped and dropped sn95 |
1996 gt 97cobra boltons
sounds highpitched check front sway bar bushings, lower control arm bushings. you can take your sway bar off clean the bar and bushings with soap and water make sure you put lots of grease back on the bushings....
MM Cobra Club Member #32 |
my front end creeks also, I think mine is coming primarily from the passenger side of the car. When I replaced the front springs - it is obvious I need to replace lower ball joints, because dust boots were all but gone.
96 GT - PI Intake & cams, O/R h-pipe, Flowmasters - 40s, Short Throw Shifter, 3.73 FRPP gears. |
1996 Mustang GT Vert
![]() iTrader: 1 reviews
The prime spot for creaking from the front end is the lower ball joints.
96 GT vert, Aftercooled Vortech, Lightning MAF,42# injectors, saleen cams, Bullitt intake, tune by Hitech, Magnaflow catback and O/R xpipe, Cobra brake upgrade, lowered bilstein suspension w/MM c/c plates and subframe connectors 3000 stall and 3.73's |
Happened to me on the Cobra, then again my car would drift all over the place without turning the wheel. After replacing control arms and bushings all seemed right in the world again. But I replaced the ball joints while I had the time.
As long as your car isn't drifting without moving the wheel I'd think it's the ball joints. |
1998 Mustang GT
I found out that I can be sitting there and turn my wheel back nd forth and it creaks. So I am about to go check things out. Now can i replace it myself oor would I need a mechanic. The haynes repair manual says take the control arm off and go get it pressed out and the new one pressed in.
2003 Mustang Gt
Slow
go get your front end alligned
409rwhp at 4500 rpms.Vortech V1 Intercooled,kurgan motorsports powerpipe, 3.12 pulley, all Mac Exhaust,Sct Tuner,Bolt Ons,Cobra Brakes,MM cc plates,Vis 2000 cobra r hood,MGW shifter,Strange 31 Spline axles,Eaton Possi |
Rollin' 18/ pushin' 2
You cvan buy a ball joint press tool from Harbor freight tools for around $30 bucks and do it yourself.
1998 Mustang GT
getting the alignment as soon as i get the caster camber plates. My alignment is maxxed. And I was just there. Damm it. Ill go back and get one though. Thanks guys
If it making a creeking sound when you turn the wheel I would check the strut mounts. I just put new struts in mine and it made horrible creaking noise afterwards, turns out my strut mount on the passengers side is shot. have someone turn the wheel while you watch the strut mount under the hood, if its moving around alot or if the strut spindle is turning then its the strut mount.
![]() 1997 Mustang GT 04 PI 2V, bolt ons, gears, tune 255/292 www.covertmotorsports.net |
1998 Mustang GT
good idea with the strut mount. And im probably just going to replacee the ball joints tomorrow so that way they are done with. Are the oe replacements from my auto store good for my car, its lowered on eibach springs and struts? Does anyone know if I can get both ball joints with grease fittings?
#12 | |
1998 Mustang GT
no shake in the steering wheel. And sorry. I meant would the oe replacement ball joints be ok or should I upgrade. The oe ones are there now and have always been there so idk.
you can upgrade to a set of Steeda X2 Ball joints. They will will help correct the geometry from being lowered.
the steering rack bushings can be a trouble spot too, the sleeve of the bushing is sometimes too long, Kcliffy did a write up on mustangforums.com about it. Could be few things though, most like a grease issue though... Just grease everything that you can and see if it persists.
Race car driving is alot like sex, every guy thinks hes good at it. 253.x/292.x <-- me tuning 13.41@104.76
1998 Mustang GT
I did. I was under there and greased everything I saw that could be it. Still creaking. I did grease the ball joint a couple weeks ago and it went away and now its back. So im going to replace it tomorro and see what happens. Ill post how it went
1998 Mustang GT
So I got under the car and the ball joint seemed good. However, the outer tie rod end was shot. So today I replaced it, drove it, and......still creaking. So its back to the ball joint idea. Does anyone knoe about how long I have til it breaks? I dont have time nor the press to do it right away.
2003 Mustang Gt
Slow
tellin you man its 80$ for a front end allignment, my car did the same thing when i bought it
1998 Mustang GT
I cant...Went and paid that and they said they cant adjust it anymore because my car is to low. I need caster camber plates before im spending another $80
2003 Mustang Gt
Slow
because its too low? are these guys retards?? lol, mines damn low too and there was no problem
Threads Similar to: creaking front end
| Front Suspension Creaking Noise; I can't stand it! | jonwrong | 99-04 | 8 | November 2nd, 2011 11:07 PM |
| Back end sitting lower than front end? | Blown 97 GT | 96-98 | 31 | October 21st, 2009 03:45 PM |
| New Front End - Like? | Gunny | 2005 - 2010 | 10 | November 19th, 2007 09:07 PM |
| Creaking from front driver side | Hunt_chevs | General Tech | 0 | October 3rd, 2007 08:14 AM |
| Where can I get this front end? | fallstar01 | 99-04 | 14 | August 7th, 2006 05:46 PM |
