Turbos Or Supercharger
Ok i have a 97 gt with new heads, throttle body, intake, headers, xpiped, 373 gears, stage 2 clutch, short throw shifter, n some more and i am wanting to know if any one has some personal exp. with putting a turbo or turbos or a supercharger on a similar year stang and if you do what did i cost and what should i be looking forward to spending i was leaning toward a turbo and maybe spray it but im not sure and if you have any links or brand kits i need or anything of the sort lemme know
already have taken tons of ricers like srt4s accords si civics and have taken a ls1 camaro and the new camaros and challenger n chargers a srt8 jeep and g35s lol tons more just wanna beat my old ass dad with his 490 chevy lol |
if you have a stock bottom end, all of them can give you 100-125 more hp...
it's all depend on your goal and utilisation. If you plan to race your car everyday... forget nitrous it will cost you an arm and a leg for the refill. but if you plan to race only a few times per year, nitrous is cheaper and don't affect daily driving. I guess you have done the PI swap already ? if not, that should be done to get most of every other mods. i've a 98gt with a 5.4 32v with a 125hp wet kit with a NANO and it's kick ass. the only "down side" is the refill but with the nano you can use the complete bottle at full PSI everytime.
Addicted to adrenaline ![]() Forged 5.4 4v with B heads and nitrous. Tuned by me |
Priest of the Car Gods
There's a LOT of turbo vs supercharger threads on this site, and people with experience with both.
Long story short, you'll never get a straight answer as to which is better, as both are depending on the situation, your goals, and your resources.
Hooo Ha Ha
Yea iv got a 5.4 and im gonna go supercharger....
You just need to know what you want. Each has there ups and downs.
![]() 410rwhp 520rwtq @ 12.9 psi |
What mods are you running now? Those are some impressive kills for an NPI GT, provided you're not just blowing smoke up our asses.
BYAHHHH!
2001 Mustang GT
13.874
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
Like stated...there are your pros/cons. But for efficiency, you cant beat a turbo..hands down.
I can set you up with a Precision turbo and TurboSmart products
![]() Precision Turbo|TurboSmart|TeamZ|Strange|Hellion|BBK|SCT|Edge Converters|Fairbanks|CG Fabrications|Treadstone |
Rollin' 18/ pushin' 2
What kind of heads, intake and tb are you running? You stated they were new, I'm just curious as to what you put in there.
1998 Mustang GT
![]() iTrader: 2 reviews
seriously...impressive kills for those mods...go turrbooooooo
pi swapped and dropped sn95 |
07 Turbo Focus
12.93 @ 105mph
I'm partial to turbos.
1) It's easier to control the boost pressure. If you're ready to run more boost, just simply adjust the boost controller or wastegate. With a supercharger, you have to buy a new pulley and possibly a new belt. 2) Turbos are non-parasitic. They spool off the exhaust gases so they don't take away any of the engine's power to make power. 3) Turbos are easier on the engine. Turbos generally don't create as much heat as superchargers. Superchargers are like big heat guns. They call them "Heaton" for a reason. The disadvantage to turbos is the lag. Depending on the size, whether it's journal or ball bearing, and the location of the turbo along the exhaust, they can take a little bit to spool up. Superchargers are instant boost as soon as you tap the gas. These are just my thoughts on it. There's different strokes for different folks. EDIT: The image you see before you click play just so happens to be a Twin Turbo'd 2.0L Duratec Focus from SEMA 2006.
2007 Focus - 230/215, cams/head/manifold swap done, new #s soon ...going E85! 1985 Bronco - 351W & 4WD 1986 Mustang LX - 351W build in the works! David Michael Smith, 07/25/1956 - 12/08/2011 ...R.I.P dad! I miss you dearly! Last edited by RDY4WAR; September 9th, 2010 at 10:16 PM. |
#10 | |
BYAHHHH!
2001 Mustang GT
13.874
2)Yes but there is one exection to this rule. Backpressure is the only thing turbos have going against them. 3) PD blowers run hot...Centris are not as bad. Lag with the correct size turbo is pretty much not there. Lag by definition is from once you hit the gas to you first see boost. boost threshold is from once you see 1 psi to full boost. Thats what you want to come quickly.
#11 | |
07 Turbo Focus
12.93 @ 105mph
I have a Garrett GT28RS ball bearing .64a/r turbo on the Focus with 2.5" stainless catless turbo-back. A 3rd gear pull from 1500rpm, I see 1psi by 1800rpm and 11psi (full boost) by 2800rpm. In 95+* heat, I was seeing just 120* IATs peak with the FMIC, and it makes an ungodly amount of torque (for what it is).
2007 Focus - 230/215, cams/head/manifold swap done, new #s soon ...going E85! 1985 Bronco - 351W & 4WD 1986 Mustang LX - 351W build in the works! David Michael Smith, 07/25/1956 - 12/08/2011 ...R.I.P dad! I miss you dearly! |
#12 | |
BYAHHHH!
2001 Mustang GT
13.874
The backpressure from the manifolds to the turbo can be reduced by a larger A/R...also helps with heat. Just takes a little longer to build that boost but will help up top. And YES a catless turbo system is the best way to go. The best turbo exhuast is no exhuast. An atmo. wastegate is a good idea too. You have a very good spool time! "Turbos make torque, torque makes fun" quote by Corky Bell
#13 | |
07 Turbo Focus
12.93 @ 105mph
![]() The Focus hits full boost by 2800rpm but doesn't reach max torque until 5400rpm and max hp at 7100rpm. lol At least that's based on other dynos with a similar setup. I'm yet to dyno mine. My tune's a bit more aggressive than the average so I'm not sure where I'd be.
BYAHHHH!
2001 Mustang GT
13.874
you should have max torque before that.
BYAHHHH!
2001 Mustang GT
13.874
maybe i am thinking v8 mustang and not your Focus motor
07 Turbo Focus
12.93 @ 105mph
Most start to make torque about 4k and pull strong from about 4600-6200 and then plane out to redline about 7300. The stock cams are meant for economy so low-end torque is not it's fancy. I can feel it in mine. Snapping it to the floor from 5k in 3rd gear will slam you back in the seat.
A guy with the same setup I have made 232whp/219wtq on CA 91 octane and 11psi. He was running 10.8:1 AFR and 12* spark advance. I'm running on 93 octane at 11psi, 11.6:1 AFR and 16* spark advance. I got detonation at 18* around 6500rpm so I set the tune at 16* advanced for a little clearance. I'm guessing I'm around 245whp/235wtq I'd like to believe.
2007 Focus - 230/215, cams/head/manifold swap done, new #s soon ...going E85! 1985 Bronco - 351W & 4WD 1986 Mustang LX - 351W build in the works! David Michael Smith, 07/25/1956 - 12/08/2011 ...R.I.P dad! I miss you dearly! Last edited by RDY4WAR; September 9th, 2010 at 11:50 PM. |
BYAHHHH!
2001 Mustang GT
13.874
very nice man! I cant wait till mine is done!
07 Turbo Focus
12.93 @ 105mph
Boost is addictive! Whether you go turbocharged or supercharged, boost is addictive!
Look Ma! My First Post!
turbo or supercharger it depends on what you intend to use it for Drag strip only supercharger all the way instant power positive boost look at what top fuel cars are running block raceing supercharger daily driver and a bit of hot rodding Turbo better mileage and great performance Booste is addictive I run A kenny bell Mamoth supercharger on my 08 gt 18psi boost but I am only in the boost once in awhile the rest of the time I never see boost except on race day then I want it right now we run 1/8 mile here not many can hang with this set up
BYAHHHH!
2001 Mustang GT
13.874
turbos DO NOT give you better gas milage. Thats a myth.
Threads Similar to: Turbos Or Supercharger
| turbos | King of 951 | 99-04 | 1 | August 5th, 2010 06:24 PM |
| JY Turbos | Stang6er | V6 Mustangs | 6 | February 2nd, 2010 08:08 AM |
| Turbos On A V6 | myPONYisHARD | V6 Mustangs | 29 | December 18th, 2007 07:36 PM |
| turbos | aaddmm18 | 99-04 | 2 | March 25th, 2007 02:05 PM |
| Any turbos? | 99modular | 99-04 | 5 | July 20th, 2006 07:55 PM |
