Oil Cooler problem on 96 GT
Old September 8th, 2010, 03:31 PM   #1
hatingthiscarnow is on a distinguished road
I have a 96 GT and it came with an engine oil cooler from the factory. For some reason antifreeze is leaking out of the little hole. I changed the gasket that goes on the oil cooler, I changed the o-ring that goes on the block adapter, I even changed the gasket that goes behind the block adapter, even with all this anti-freeze is still leaking out. Could it be the oil cooler is no good anymore?
Old September 8th, 2010, 03:38 PM   #2
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
Did you look at where it meets up and make sure there was nothing wrong with it? No gouges or deep scratches that it could be weeping from?
I lol'd at your name btw.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old September 8th, 2010, 04:46 PM   #3
I didnt see any deep scratches, it looked to be in pretty good shape, other than a little dirty.
Old September 10th, 2010, 11:29 AM   #4
sn95mustanggt's Avatar
98 GT, 93 Ranger!
sn95mustanggt is an unknown quantity at this point
I have a leak from the same spot. is it just leaking coolant out or into the oil?
Old September 10th, 2010, 02:15 PM   #5
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
Did you use thermostat and waterpump gasket sealant when you changed it out? Also, I don't know if the oil cooler has a weep hole like a water pump does, but I know if your loosing coolant from the weep hole on a water pump it means the bearings are going bad. The oil cooler doesn't have any moving parts though so I don't know. I have never run into this problem before.
MODS IN GARAGE
NCMM ORIGINAL
Old September 14th, 2010, 08:07 PM   #6
I think I may have fixed this issue now. I put some rtv sealant around the gasket as well and no more coolant leak. Hopefully this will fix the issue. If not it may give me time to save for a new oil cooler. I may have to change my user name now I am no longer hating this car. Thanks for all the help
Threads Similar to: Oil Cooler problem on 96 GT
99 Cobra 4.6 Oil Cooler machined hole porting Oil? ocJB3 99-04 3 January 3rd, 2011 06:31 PM
Oil Cooler curtmoon 2005 - 2010 2 May 18th, 2010 07:02 AM
5.0 Oil Cooler ajr1230 5.0 Mustangs 0 March 18th, 2010 04:47 PM
Oil cooler chris1 4V / SVT 3 October 31st, 2008 01:53 PM
oil cooler serjo 99-04 15 March 5th, 2008 07:44 AM
