1996 GT
5th grind on rebuilt trans
Just bought my first mustang a few days ago so naturally im new to this site. I have searched this so please dont flame. Like the title says i bought it from the owner who said that the trans and rear had been rebuilt about 6-7months ago along with a replaced clutch. All gears shift fine and everything feels very tight but if i dont ease into 5th it will grind. I do have issues getting into reverse but it isnt a grind. The obvious answer in my mind would be the 5th gear synchro. However i find it hard to believe that a synchro has a half year life span. Id just like to know if any other issues would cause this grind other than the sychro. Any direction would be much appreciated. I do believe it has a short throw shifter installed.
they mustangs really suck as far as the reverse issues,
try to adjust the clutch a lil bit |
1996 GT
Correct me if im wrong but wouldnt every gear grind if it were a clutch engagement issue?
no, sometimes it wont pull the fork all the way to fully disengage the clutch. i had a similar issue but mine only grinded in 2nd gears sometimes, i purchased an adjustable cable, firewall adjuster and a double hook quadrant, installed it and 2nd stop grinding. my problem was the factory adjuster wouldnt allow the clutch to fully disengage in 2nd gear, but now its all good
1996 GT
Ill check that out and thanks for the advice ill throw you some rep. If you dont mind me asking. How much did that run you? Also is there anyway i could check and make sure it was a clutch issue before i spend the money? The clutch doesnt seem to drag at all and starts engaging after a few inches of relief.
i got it all for $120, im not sure how/if you can check it without removing it.
mine starts to engage maybe about an inch of relief and disengages when i push the pedal in about 2 inches |
Threads Similar to: 5th grind on rebuilt trans
| 5th gear grind...why? | wade29 | 99-04 | 11 | July 5th, 2010 02:32 AM |
| 5th gear grind | xBIGxWHITEx | V6 Mustangs | 10 | July 5th, 2009 12:43 AM |
| Rebuilt AOD trans not working? | confizzy | 5.0 Mustangs | 9 | May 23rd, 2009 08:19 AM |
| newbie here,with a grind in 5th gear | fnoblitt | V6 Mustangs | 2 | June 18th, 2008 12:28 AM |
| 5th gear grind on 5 speed | emgjsdk1 | V6 Mustangs | 9 | August 22nd, 2007 05:54 PM |
