1998 Mustang GT
![]() iTrader: 2 reviews
fuel injectors
So I found a good deal on some 24lb injectors. The question is will 24lb injectors that came from a cobra fit my 98 GT without modification? Will I have to change anything like my maf or tune or ignition items?
Heres a pic of them just to show you
pi swapped and dropped sn95 |
BYAHHHH!
2001 Mustang GT
13.874
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
thoughs are ev1 injectors. ev1 is a direct swap. Cobras use ev6 style injectors. you will need adaptors to make them work.
![]() Precision Turbo|TurboSmart|TeamZ|Strange|Hellion|BBK|SCT|Edge Converters|Fairbanks|CG Fabrications|Treadstone |
1998 Mustang GT
So the ones in the pics are ev1 and are a direct swap?
you will need a tune to make big injectors work, the pcm controls the time in which an injector is open. so a higher flow injector will flow more fuel during the same amount of time as a lower injector. Your pcm needs to be calibrated that or get a MAF that is for 24lb injectors. I have an extra MAF from a 96-98 Cobra that is calibrated for 24 lb injectors so you can swap 24lb directly in if you are interested.
Race car driving is alot like sex, every guy thinks hes good at it. 253.x/292.x <-- me tuning 13.41@104.76
BYAHHHH!
2001 Mustang GT
13.874
yes looks like they are a direct swap
1998 Mustang GT
Sweet. Is there anyway to know 100% if they are direct. Im not doubting you I just am careful about spending money on things. I would rather get the right ones the first time. and modularmustang I am interested in the MAF. PM me please with the cost. Are MAF's calibrated for more than fuel injectors?
1998 Mustang GT
Jus looked it up. Those are ev1 24lb injectors ford racing. Thanks for the info guys. And im still very interested now in the maf
one transform function per MAF, the 19lb maf will work with 19lb unless you change your tune in the pcm with a flash tuner. Ill PM you with the details on the MAF tomorrow.
1998 Mustang GT
so I found another set. The kid says they are for a 86-95 5.0 mustang. Will these fit my car also? Are they the same things
1998 Mustang GT
hellpppp
1998 Mustang GT
bump
2003 Mustang Gt
Slow
i dont think theyd fit, what was wrong with the others?
409rwhp at 4500 rpms.Vortech V1 Intercooled,kurgan motorsports powerpipe, 3.12 pulley, all Mac Exhaust,Sct Tuner,Bolt Ons,Cobra Brakes,MM cc plates,Vis 2000 cobra r hood,MGW shifter,Strange 31 Spline axles,Eaton Possi |
1998 Mustang GT
how much would you pay for the first ones? just seeing what other people would pay
BYAHHHH!
2001 Mustang GT
13.874
keep your stockers and when you need injectors do 42's or 60's
2003 Mustang Gt
Slow
good suggestions scott +rep
1997 Mustang GT
14.92 before current round of mods....
Any of those injectors shown will fit your car. I have heard of using larger injectors with a MAF that is "calibrated" to that # injectors, but from what I've read, if you start straying too far from the original size injectors, the PCM will not be able to handle it as efficiently. 19lb/hr to 24lb/hr is not too big of a jump so you may be able to get away with it.
The BEST way is to leave your MAF alone (unless you need the flow) and have the PCM tuned to the correct injector flow rate. The connector was thesame for the 5.0L and the earlier (pre 05) 4.6's. The connector is called the "minitimer" connector. I also agree that 42lb/hr or 60's would be a better upgrade. they are just about the same price, but leave you lots of overhead for future mods, so you don't have to buy injectors again. |
only buy 42lb+ when your going to use FI or Nitrous. Getting bigger then 24 or 30 while N/A is pointless as it getts very hard to tune for lower rpm with higher flow injectors. Like I said before the pcm controls the flow my pulsing the injector. So for a 19lb injector at idle its open for x milliseconds, but with a 60lb injector its cut down to 1/3 of that time.
So even if you plan on something larger in the future you should wait to install the 42lb+ injectors til you install your FI or else you will have a hell of a time dailing in the lower end.
BYAHHHH!
2001 Mustang GT
13.874
u wont need big injectors with a wet kit of nitrous/dirct. which imo is the only way to go
i heard wet puddles in the intake since the intake is designed for air. I dont know nitrous very well though... i heard the plate is better then the nozzle anyways, haha
Threads Similar to: fuel injectors
| fuel injectors | billx55 | 96-98 | 2 | June 14th, 2010 07:40 PM |
| SVT fuel pump, fuel injectors | Kennhyy3 | V6 Mustangs | 2 | December 19th, 2008 05:08 AM |
| Fuel Injectors | Mach Boy | 99-04 | 3 | November 7th, 2007 08:32 AM |
| Fuel Injectors/fuel pressure | 00silvergt | 99-04 | 4 | August 2nd, 2007 09:54 AM |
| New Fuel Injectors | 1998_svt_cobra | 96-98 | 22 | February 19th, 2007 09:24 AM |
